GPSTracker with Life360, OwnTracks and GPSLogger integration
A local version with accuracy support. It works locally for me but could you also check before the push? If it’s OK I’ll include it in the same PR. Thx
Very nice! I deleted my thing and let the binding re-discover it and the new channel was available.
It gives the correct value. Thank you so much!!
Hi @gbicskei,
I tried your binding to connect via https://myopenhab.org/gpstracker/owntracks
But get in owntracks only an 403 error.
The login credentials I’m using are OK so I was wondering if I just miss something here.
Matt
Try https://home.myopenhab.org/gpstracker/owntracks
That works for me
Thanks a lot, that did the trick
Matt
Hi all,
i downloaded the jar from @gbicskei link and updated my config as in this threat described. But i have no luck with the switches.
I can send coordinates via Postman and my openHAB are good with it. But the switches still don’t turn on (or off).
Thing config is created via PaperUI and my Items look like this:
Location locationNils "Nils GPS" {channel="gpstracker:tracker:ni:lastLocation"}
Switch atWorkNils "Nils arbeiten [%s]" {channel="gpstracker:tracker:ni:regionTrigger" [profile="gpstracker:trigger-geofence", regionName="Work"]}
Switch atHomeNils "Nils zuhause [%s]" {channel="gpstracker:tracker:ni:regionTrigger" [profile="gpstracker:trigger-geofence", regionName="Home"]}
What can i do?
Where did you define Home and Work regions? On your phone or by defining distance channels? A log would be useful as well to be able to help (from the binding start till the second received message). This is the updated documentation. Did you do the configuration based on this?
I have defined distance channels via PaperUI. I test the switch with OwnTracks Location.
Where can i finde the logs you required for troubleshooting?
All i configured was with help of the old and new documentation.
userdata/logs/openhab.log
Make sure to set the trace level described in the documentation.
Sorry but i am new to logging. Where do i set
log:set TRACE oprg.openhab.binding.gpstracker
Here is the Logfile from openHAB start to some recieved coordinations (i know its very long, but i dont know where to cut):
2018-10-08 14:57:19.595 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Deactivating GPSTracker Binding
2018-10-08 14:57:19.605 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - GPSTracker callback servlet stopped on /gpstracker/owntracks
2018-10-08 14:57:19.613 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - GPSTracker callback servlet stopped on /gpstracker/gpslogger
2018-10-08 14:57:19.625 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.config.core.ConfigOptionProvider}={service.id=193, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=61} - org.openhab.binding.gpstracker
2018-10-08 14:57:19.634 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent UNREGISTERING - {javax.servlet.ServletContext}={osgi.web.version=2.4.0.201810051834, osgi.web.contextpath=/, service.id=194, osgi.web.symbolicname=org.openhab.binding.gpstracker, service.bundleid=265, service.scope=singleton, osgi.web.contextname=default} - org.openhab.binding.gpstracker
2018-10-08 14:57:19.645 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService, org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService}={service.id=162, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService, component.id=60} - org.openhab.binding.gpstracker
2018-10-08 14:57:19.662 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.profiles.ProfileFactory, org.eclipse.smarthome.core.thing.profiles.ProfileAdvisor, org.eclipse.smarthome.core.thing.profiles.ProfileTypeProvider}={service.id=163, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.profile.GPSTrackerProfileFactory, component.id=62} - org.openhab.binding.gpstracker
2018-10-08 14:57:19.667 [DEBUG] [org.openhab.binding.gpstracker      ] - BundleEvent STOPPING - org.openhab.binding.gpstracker
2018-10-08 14:57:19.673 [DEBUG] [org.openhab.binding.gpstracker      ] - BundleEvent STOPPED - org.openhab.binding.gpstracker
2018-10-08 14:57:20.148 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Deleting weatherJob-home
2018-10-08 14:57:20.393 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-10-08 14:57:20.445 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 76bf09f3-1800-4ed5-bbd5-e5f032dd76e4, base URL = http://localhost:8080)
2018-10-08 14:57:20.732 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2018-10-08 14:57:20.814 [INFO ] [b.core.service.AbstractActiveService] - CalDav Loader has been shut down
2018-10-08 14:57:20.872 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-10-08 14:57:20.921 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been shut down
2018-10-08 14:57:22.225 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-10-08 14:57:22.289 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-10-08 14:57:22.338 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-10-08 14:58:41.375 [INFO ] [llet.internal.PushbulletAPIConnector] - ===========================================================================
2018-10-08 14:58:41.418 [INFO ] [llet.internal.PushbulletAPIConnector] - Configured 1 bots
2018-10-08 14:58:41.421 [INFO ] [llet.internal.PushbulletAPIConnector] -   Bot: DEFAULT=PushbulletBot {name='DEFAULT', token='o.5IC59lWejuU1VWSxmQ0jZH7WiMjRY4v5'}
2018-10-08 14:58:41.424 [INFO ] [llet.internal.PushbulletAPIConnector] - ===========================================================================
2018-10-08 14:58:41.479 [INFO ] [egram.internal.TelegramActionService] - Bot achterhome_bot loaded from config file
2018-10-08 14:58:42.459 [INFO ] [.io.caldav.internal.CalDavLoaderImpl] - CalDAV IO is properly configured.
2018-10-08 14:58:42.475 [INFO ] [b.core.service.AbstractActiveService] - CalDav Loader has been started
2018-10-08 14:58:42.673 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService, org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService}={service.id=161, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService, component.id=60} - org.openhab.binding.gpstracker
2018-10-08 14:58:42.682 [DEBUG] [org.openhab.binding.gpstracker      ] - BundleEvent STARTING - org.openhab.binding.gpstracker
2018-10-08 14:58:42.687 [DEBUG] [org.openhab.binding.gpstracker      ] - BundleEvent STARTED - org.openhab.binding.gpstracker
2018-10-08 14:58:42.735 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.profiles.ProfileFactory, org.eclipse.smarthome.core.thing.profiles.ProfileAdvisor, org.eclipse.smarthome.core.thing.profiles.ProfileTypeProvider}={service.id=162, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.profile.GPSTrackerProfileFactory, component.id=62} - org.openhab.binding.gpstracker
2018-10-08 14:58:42.739 [DEBUG] [org.openhab.binding.gpstracker      ] - BundleEvent [unknown:512] - org.openhab.binding.gpstracker
2018-10-08 14:58:43.098 [INFO ] [.io.caldav.internal.CalDavLoaderImpl] - reload job scheduled for: Abfallkalender
2018-10-08 14:58:45.088 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-10-08 14:58:46.184 [WARN ] [g.dispatch.internal.ConfigDispatcher] - Could not parse line 'expose5sm_nils,sm_lisa,akt_temp_wz,LGTV'
2018-10-08 14:58:48.442 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Initializing callback servlets
2018-10-08 14:58:48.511 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.version=2.4.0.201810051834, osgi.web.contextpath=/, service.id=200, osgi.web.symbolicname=org.openhab.binding.gpstracker, service.bundleid=265, service.scope=singleton, osgi.web.contextname=default} - org.openhab.binding.gpstracker
2018-10-08 14:58:48.520 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/owntracks
2018-10-08 14:58:48.543 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/gpslogger
2018-10-08 14:58:48.550 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Deactivating GPSTracker Binding
2018-10-08 14:58:48.565 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - GPSTracker callback servlet stopped on /gpstracker/owntracks
2018-10-08 14:58:48.581 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - GPSTracker callback servlet stopped on /gpstracker/gpslogger
2018-10-08 14:58:48.600 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Initializing callback servlets
2018-10-08 14:58:48.615 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/owntracks
2018-10-08 14:58:48.690 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/gpslogger
2018-10-08 14:58:48.699 [DEBUG] [org.openhab.binding.gpstracker      ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.config.core.ConfigOptionProvider}={service.id=199, service.bundleid=265, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=61} - org.openhab.binding.gpstracker
2018-10-08 14:58:49.401 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.21:8080
2018-10-08 14:58:49.407 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.21:8443
2018-10-08 14:58:53.759 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 76bf09f3-1800-4ed5-bbd5-e5f032dd76e4, base URL = http://localhost:8080)
2018-10-08 14:58:56.994 [WARN ] [arketplace.internal.MarketplaceProxy] - Failed downloading Marketplace entries:  : Received fatal alert: handshake_failure
2018-10-08 14:58:57.000 [WARN ] [arketplace.internal.MarketplaceProxy] - Retrying again in a minute
2018-10-08 14:58:57.542 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: 273719@www.neuss.mein-abfallkalender.de(Restmüll-Grau@08.10.2018/00:00-09.10.2018/00:00)
2018-10-08 14:59:04.280 [INFO ] [nhab.io.caldav.internal.job.EventJob] - event BEGIN for: 273719@www.neuss.mein-abfallkalender.de(Restmüll-Grau@08.10.2018/00:00-09.10.2018/00:00)
2018-10-08 14:59:11.221 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2018-10-08 14:59:11.461 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'flur.items'
2018-10-08 14:59:11.851 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wohnzimmer.items'
2018-10-08 14:59:12.033 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kinderzimmer.items'
2018-10-08 14:59:12.106 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'keller.items'
2018-10-08 14:59:12.171 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'schlafzimmer.items'
2018-10-08 14:59:12.327 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2018-10-08 14:59:18.936 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-10-08 14:59:24.550 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '1_alarmeinstellungen.rules'
2018-10-08 14:59:24.919 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'WZ_beleuchtung.rules' has errors, therefore ignoring it: [55,3]: missing '}' at 'else'
2018-10-08 14:59:26.551 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'KE_trockner_status.rules'
2018-10-08 14:59:26.842 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'FLUR_haustuer.rules'
2018-10-08 14:59:30.128 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WZ_temperatur.rules'
2018-10-08 14:59:31.799 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WZ_Steam.rules'
2018-10-08 14:59:33.461 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '1_systemstart.rules'
2018-10-08 14:59:34.017 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '2_battery_level_things.rules'
2018-10-08 14:59:36.452 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '1_anwesenheit.rules'
2018-10-08 14:59:36.581 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'WZ_tv-on.rules'
2018-10-08 14:59:36.867 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'FLUR_Lampe.rules'
2018-10-08 14:59:37.793 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zuhause.sitemap'
2018-10-08 14:59:37.871 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MeinHaus.sitemap'
2018-10-08 14:59:37.948 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'eg_wz_hue_wandR_color' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: ID segment '`ue' contains
2018-10-08 14:59:38.359 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wohnzimmer.things'
2018-10-08 14:59:40.604 [WARN ] [org.pcap4j.util.PropertiesLoader    ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
2018-10-08 14:59:40.620 [WARN ] [org.pcap4j.util.PropertiesLoader    ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
2018-10-08 14:59:40.623 [WARN ] [org.pcap4j.util.PropertiesLoader    ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
2018-10-08 14:59:40.631 [WARN ] [org.pcap4j.util.PropertiesLoader    ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
2018-10-08 14:59:40.872 [WARN ] [org.pcap4j.util.PropertiesLoader    ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
2018-10-08 14:59:40.947 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-10-08 14:59:41.084 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-10-08 14:59:41.163 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-10-08 14:59:41.165 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-10-08 14:59:41.425 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2018-10-08 14:59:44.315 [WARN ] [.serialmessage.ZWaveCommandProcessor] - SerialMessage class null is not implemented!
2018-10-08 14:59:44.319 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = -- (0xa)
2018-10-08 14:59:44.322 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 4: Not initialized (ie node unknown), ignoring message.
2018-10-08 14:59:44.325 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 4: Not initialized (ie node unknown), ignoring message.
2018-10-08 14:59:46.679 [DEBUG] [cker.internal.handler.TrackerHandler] - Tracker handler created: ni
2018-10-08 14:59:46.757 [DEBUG] [cker.internal.handler.TrackerHandler] - System location is not set. Skipping system distance channel setup.
2018-10-08 14:59:51.946 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2018-10-08 14:59:56.142 [INFO ] [b.core.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2018-10-08 14:59:58.403 [WARN ] [arketplace.internal.MarketplaceProxy] - Failed downloading Marketplace entries:  : Received fatal alert: handshake_failure
2018-10-08 14:59:58.407 [WARN ] [arketplace.internal.MarketplaceProxy] - Retrying again in a minute
2018-10-08 15:00:00.495 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-10-08 15:00:01.603 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-10-08 15:00:01.866 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-10-08 15:00:07.219 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Trockner Status': The name 'ke_tro_state' cannot be resolved to an item or type; line 23, column 7, length 12
2018-10-08 15:00:17.393 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=OPENWEATHERMAP,apiKey=e04945e46d813bdb5abe5b62f0ecec7]
2018-10-08 15:00:17.396 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=FORECASTIO,apiKey=17e1692c47ac60739585a1e47f421316]
2018-10-08 15:00:17.400 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=OPENWEATHERMAP,language=de,updateInterval=15,latitude=51.21217,longitude=6.67025,woeid=<null>,locationId=home2,name=home2]
2018-10-08 15:00:17.403 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=FORECASTIO,language=de,updateInterval=30,latitude=51.21217,longitude=6.67025,woeid=<null>,locationId=home,name=home]
2018-10-08 15:00:19.443 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-10-08 15:00:21.942 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Disabling weather locationId 'home2', no binding available
2018-10-08 15:00:21.950 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 30 minutes
2018-10-08 15:00:23.604 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"batt":58,"lon":6.792351534426075,"acc":65,"p":101.53367614746094,"vac":28,"lat":51.248504638671875,"topic":"owntracks\/achternbosch@outlook.com\/7E79EE4E-8591-4801-BC8D-9EF5EF20B588","t":"p","conn":"w","tst":1539003619,"alt":36,"_type":"location","tid":"ni"}
2018-10-08 15:00:23.616 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker ni from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@144b6b0
2018-10-08 15:00:23.621 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 58
2018-10-08 15:00:23.632 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 51.248504638671875,6.792351534426075
2018-10-08 15:00:23.644 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-10-08T15:00:19.000+0200
2018-10-08 15:00:23.647 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker ni
2018-10-08 15:00:23.658 [TRACE] [cker.internal.handler.TrackerHandler] - Region SE center distance from tracker location 51.248504638671875,6.792351534426075 is 10161.330418743293m
2018-10-08 15:00:23.662 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:23.668 [TRACE] [cker.internal.handler.TrackerHandler] - Region Work center distance from tracker location 51.248504638671875,6.792351534426075 is 38.200180243254756m
2018-10-08 15:00:23.671 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:23.676 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 51.248504638671875,6.792351534426075 is 9729.363769802856m
2018-10-08 15:00:23.678 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:24.671 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"batt":57,"lon":6.7923487854074986,"acc":65,"p":101.54381561279297,"vac":10,"lat":51.248504638671875,"topic":"owntracks\/achternbosch@outlook.com\/7E79EE4E-8591-4801-BC8D-9EF5EF20B588","t":"u","conn":"w","tst":1539003621,"alt":36,"_type":"location","tid":"ni"}
2018-10-08 15:00:24.678 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker ni from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@d2b982
2018-10-08 15:00:24.682 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 57
2018-10-08 15:00:24.692 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 51.248504638671875,6.7923487854074986
2018-10-08 15:00:24.698 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-10-08T15:00:21.000+0200
2018-10-08 15:00:24.701 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker ni
2018-10-08 15:00:24.706 [TRACE] [cker.internal.handler.TrackerHandler] - Region SE center distance from tracker location 51.248504638671875,6.7923487854074986 is 10161.14497085593m
2018-10-08 15:00:24.709 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:24.716 [TRACE] [cker.internal.handler.TrackerHandler] - Region Work center distance from tracker location 51.248504638671875,6.7923487854074986 is 38.011698698225544m
2018-10-08 15:00:24.719 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:24.725 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 51.248504638671875,6.7923487854074986 is 9729.186064170304m
2018-10-08 15:00:24.728 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:51.204 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"cog":7,"batt":57,"lon":6.7919542081717328,"acc":10,"p":101.54511260986328,"vel":0,"vac":4,"lat":51.24853515625,"topic":"owntracks\/achternbosch@outlook.com\/7E79EE4E-8591-4801-BC8D-9EF5EF20B588","t":"u","conn":"w","tst":1539003650,"alt":40,"_type":"location","tid":"ni"}
2018-10-08 15:00:51.209 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker ni from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@16c72f
2018-10-08 15:00:51.213 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 57
2018-10-08 15:00:51.217 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 51.24853515625,6.7919542081717328
2018-10-08 15:00:51.224 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-10-08T15:00:50.000+0200
2018-10-08 15:00:51.226 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker ni
2018-10-08 15:00:51.235 [TRACE] [cker.internal.handler.TrackerHandler] - Region SE center distance from tracker location 51.24853515625,6.7919542081717328 is 10135.382794101197m
2018-10-08 15:00:51.238 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:51.244 [TRACE] [cker.internal.handler.TrackerHandler] - Region Work center distance from tracker location 51.24853515625,6.7919542081717328 is 14.212219239259797m
2018-10-08 15:00:51.247 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:51.253 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 51.24853515625,6.7919542081717328 is 9704.956750857385m
2018-10-08 15:00:51.256 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:00:59.956 [WARN ] [arketplace.internal.MarketplaceProxy] - Failed downloading Marketplace entries:  : Received fatal alert: handshake_failure
2018-10-08 15:00:59.960 [WARN ] [arketplace.internal.MarketplaceProxy] - Retrying again in a minute
2018-10-08 15:01:05.483 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"_type":"transition","tid":"ni","acc":10.0,"desc":"home","event":"enter","lat":51.215809,"lon":6.662906,"tst":1527966973,"wtst":1524244195,"t":"c"}
2018-10-08 15:01:05.493 [DEBUG] [cker.internal.handler.TrackerHandler] - ConfigHelper transition event received: home
2018-10-08 15:01:05.497 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker ni from message: org.openhab.binding.gpstracker.internal.message.TransitionMessage@7eb0a8
2018-10-08 15:01:05.505 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 51.215809,6.662906
2018-10-08 15:01:05.511 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-06-02T21:16:13.000+0200
2018-10-08 15:01:05.514 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker ni
2018-10-08 15:01:05.536 [TRACE] [cker.internal.handler.TrackerHandler] - Region SE center distance from tracker location 51.215809,6.662906 is 1356.6265368117254m
2018-10-08 15:01:05.541 [TRACE] [cker.internal.handler.TrackerHandler] - Region Work center distance from tracker location 51.215809,6.662906 is 9691.956652963549m
2018-10-08 15:01:05.546 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 51.215809,6.662906 is 0.0m
2018-10-08 15:01:16.817 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"cog":7,"batt":57,"lon":6.7919542081717328,"acc":10,"p":101.54444885253906,"vel":0,"vac":4,"lat":51.24853515625,"topic":"owntracks\/achternbosch@outlook.com\/7E79EE4E-8591-4801-BC8D-9EF5EF20B588","t":"u","conn":"w","tst":1539003675,"alt":41,"_type":"location","tid":"ni"}
2018-10-08 15:01:16.821 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker ni from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@3e214d
2018-10-08 15:01:16.823 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 57
2018-10-08 15:01:16.828 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 51.24853515625,6.7919542081717328
2018-10-08 15:01:16.833 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-10-08T15:01:15.000+0200
2018-10-08 15:01:16.835 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker ni
2018-10-08 15:01:16.837 [TRACE] [cker.internal.handler.TrackerHandler] - Region SE center distance from tracker location 51.24853515625,6.7919542081717328 is 10135.382794101197m
2018-10-08 15:01:16.839 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:01:16.843 [TRACE] [cker.internal.handler.TrackerHandler] - Region Work center distance from tracker location 51.24853515625,6.7919542081717328 is 14.212219239259797m
2018-10-08 15:01:16.846 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:01:16.849 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 51.24853515625,6.7919542081717328 is 9704.956750857385m
2018-10-08 15:01:16.851 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-08 15:02:01.249 [WARN ] [arketplace.internal.MarketplaceProxy] - Failed
I hope this helps.
Are you sure you installed this version? I can’t see the new gpsAccuracy channel updating. Check pls. What version of OH are you running?
I downloaded the version from your Google Drive an installed it. My version of Openhab is 2.4-M4
This is my Things-Config:
There is no Accuracy channel and it should be there. Can you rediscover the thing? Is this the first version (downloaded form the google drive) of the binding you’ve installed? Or have you installed the previous builds from official snapshot? You should see something like this:
After rediscover i have the same channels as befor.
First i installed the binding via PaperUI. After reading this forum i uninstalled it via PaperUi and downloaded the jar, put it in the Addons folder an rebooted the pi. And now i have the binding installed (in the PaperUI binding Add-ons panel it is displayed as not installed).
Try Clear the Cache
This is your version:
2.4.0.201810051834
And this is the google drive version:
2.4.0.201810070814
Ok so how do i uninstall my version correct?
I would do the following:
  • Uninstall all GPStracker versions (PaperUI and addons folder as well)
  • Stop OH
  • Clear the cache (Delete the ./userdata/cache and ./userdata/tmp folder - CONTENT ONLY!)
  • Start OH without the binding
  • After the start copy the binding into addons and check the version
