Grafana is not working after upgrade procedure in openhab-config
I’m running OH3.2 w Grafana and it was working very well. From time to time I’m using at openhab-config the upgrade function to have new packages installed. I did so last weekend and since there, Grafana is not reachable any longer (ip:3000).
OH is running and I can see at ip:9001 the log, same for ip:8080 with the data (also the history is working… so influxDB should work).
Any indications to check further why grafana is not working?
Thanks for help, René
see Grafana won't start anymore after update to 8.5.0
