Hey guys!
Is it possible to use just one Tradfri dimmer item for both Alexa voice activation and OH UI?
I have a bulb using the white spectrum. As far as I see it, using only the Dimmer item on the color_temperature channel does the job for Alexa - I can toggle on/off and brightness via voice, change the color temperature via voice (warmer/colder) and via pre-defined settings in the Alexa app (not mandatory for me).
Dimmer gKidsCeilingLamp "Sternchenlampe" <light> (gKidsRoom) ["Lightbulb"] {alexa="PowerState,Brightness,ColorTemperature" [binding="tradfri:white"], channel="tradfri:0220:gwdcefcabd3323:65541:color_temperature"}
Obviously in OH this only gives me control for the color_temperature temperature slider connected to the item.
Whats the best way to go here?
- Create 1 item for Alexa as defined above and 1 group (semantic equipment tag for OH) + 2 items (
color_temperature,brightness) for OH → basically redundant - Create 1 group (endpoint for Alexa with tag
Lightas well as semantic equipment tag for OH) + 2 items in that group (color_temperature,brightness) as described in the docs → that would however give me additional items in Alexa like “Helligkeit” for the brightness.
I actually did it like this since I wrote about it with @jeshab years ago
But having those 2 extra Alexa items always somewhat bothered me… So maybe there is… - A 3rd way I’m missing right now
Thanks in advance!
