I noticed that if I look at the same device in habmin and paper they show different configurations.
For instance, parameter 4 Invert Switch is set to enable in paper, disable in habmin.
Also in the file you mentioned all the zwave devices have the same hex code c5b6926a. Based on other entries in the file I’m guessing that is the uid for the zstick?
"zwave:device:c5b6926a:node3": {
"class": "org.eclipse.smarthome.core.thing.internal.ThingImpl",
"value": {
"label": "Z-Wave Node 3: NZW39 Dimming Plug",
"bridgeUID": {
"segments": [
"zwave",
"serial_zstick",
"c5b6926a"
"channels": [
"acceptedItemType": "Dimmer",
"kind": "STATE",
"uid": {
"segments": [
"zwave",
"device",
"c5b6926a",
"node3",
"switch_dimmer"
"channelTypeUID": {
"segments": [
"zwave",
"switch_dimmer"
"label": "Dimmer",
"description": "The brightness channel allows to control the brightness of a light. It is also possible to switch the light on and off.",
"configuration": {
"properties": {
"config_restoreLastValue": true
"properties": {
"binding:Command:OnOffType": "SWITCH_MULTILEVEL,BASIC",
"binding:*:PercentType": "SWITCH_MULTILEVEL,BASIC"
"defaultTags": []
"acceptedItemType": "Number",
"kind": "STATE",
"uid": {
"segments": [
"zwave",
"device",
"c5b6926a",
"node3",
"scene_number"
"channelTypeUID": {
"segments": [
"zwave",
"scene_number"
"label": "Scene Number",
"description": "Triggers when a scene button is pressed",
"configuration": {
"properties": {}
"properties": {
"binding:*:DecimalType": "CENTRAL_SCENE"
"defaultTags": []
"configuration": {
"properties": {
"group_1": [
"node_1_0"
"group_2": [],
"config_6_1_00000008": 0,
"config_1_1": 1,
"switchall_mode": 255,
"config_2_1": 1,
"action_reinit": false,
"config_6_1_00000004": 0,
"config_7_1": 0,
"config_6_1_00000001": 1,
"config_8_1": 0,
"config_6_1_00000002": 0,
"config_9_1": 0,
"config_3_1": 1,
"config_4_1": 1,
"config_5_2": 0
"properties": {
"zwave_class_basic": "ROUTING_SLAVE",
"zwave_class_generic": "MULTILEVEL_SWITCH",
"zwave_frequent": "false",
"zwave_neighbours": "",
"modelId": "NZW39",
"zwave_version": "1.1",
"zwave_listening": "true",
"zwave_plus_devicetype": "LIGHT_DIMMER_SWITCH",
"manufacturerId": "015D",
"manufacturerRef": "2700:2700",
"dbReference": "770",
"zwave_deviceid": "9984",
"zwave_nodeid": "3",
"vendor": "Willis Electric Co., Ltd.",
"defaultAssociations": "1",
"zwave_routing": "true",
"zwave_beaming": "true",
"zwave_class_specific": "POWER_SWITCH_MULTILEVEL",
"zwave_manufacturer": "349",
"zwave_devicetype": "9984"
"uid": {
"segments": [
"zwave",
"device",
"c5b6926a",
"node3"
"thingTypeUID": {
"segments": [
"zwave",
"willis_nzw39_00_000"
