Regarding my question number 1, I found a strange thing: on the tablet (iPad, Safari) the items are correctly refreshed, but on the PC (using Firefox) the items are not refreshed.
Is there any reason for this behavior?
EDIT: the automatic refresh worked for a while on the iPad, but now it doesn’t work anymore…
Am I doing something wrong?
The automatic updates on openHAB 1 uses the Atmosphere support of the REST API which unfortunately has issues, not related to HABpanel; I tried for quite some time to make it work reliably without much success. I’ve since upgraded my setup to openHAB 2 which uses SSE and works way better.
(by the way, this thread is for the openHAB 2 bundle, if you’re on 1.8 use this one instead)
The Button widget sends a fixed value you specify to an item, if you want ON/OFF behavior there’s the Switch widget.
I should really rewrite the README file at some point
No, they should update. Try on a desktop browser like Chrome, hit F12 and check if there’s something on the Javascript console. The updates from server-side events are logged there.
Started playing with this tonight and its pretty cool. And really looking forward to the use of a color picker widget.
And then possibilities are setting groups? I have 6 color bulbs in my family room, 4 in a Ceiling Fan and then 2 in table lamps. If I could control them all and set different groups/scenes it would be awesome.
