HabPanel: Change Color Based on Item-State
I have multiple widgets in my HabPanel wich show states of some items (e.g. Battery (Off->okay; On->empty)).
Is it possible to change the background color of the Widget based on the state (e.g. OFF->Green; On->Red)?
I’m a complete Newbie in OpenHab. Thanks for your help.
Greetings from Germany
I don’t think that you can do this for the “standard” widgets (like switch etc)
You could try to use a template and do the following:
<div style="position: absolute;
            top: 0;
            bottom: 0;
            left: -10px; right: -10px;
            background: url('../static/HomeR/Ground_Floor.png');
            background-size: cover;
            background-repeat: no-repeat;">
	<div ng-if="itemValue('SP7000_State')=='Disarmed'">
  	<img ng-src="../static/HomeR/Motion/Disarmed.png" style="position: absolute; top: 5%; left: 55%" />
	</div>
  	<div ng-if="itemValue('SP7000_State')!='Disarmed'">
  	<img ng-src="../static/HomeR/Motion/Armed.png" style="position: absolute; top: 5%; left: 55%" />
	</div>
</div>
In this example, I change the image (not the background) based on the state of my item (it’s String type)
Maybe you can play with the ng-if code and change the background too… not sure
Have a look here
If you want to keep things simple, the standard Button widget can also act as a Switch.
Just set it up like so:
  • Action type to Alternate item between 2 states
  • Command value to ON
  • Alternate command value to OFF
There are options in the Active and Inactive tab to configure colors for the “active” state (ON in this case) and others.
Thanks. To use a button… very simple idea.
Hello @ysc,
Very helpful hint!
I needed a few days to find this out.
This should be way easier.
For Windows:
Commandvalue: OPEN
Alternate command value: CLOSED
View: disable “show value”
Inactive-Tab: both to “transparent”
Active-Tab: Background to red, Label to black.
Stay healthy!
