pune2001
(Pune2001)
March 3, 2019, 10:57am
1
After moving to the latest snapshot (#1545 ), I cannot access HABPanel in my installation. All other user interfaces (Paper, Basic) and all bindings work fine. I did clear the cache and restarted openHAB. The console shows that HABPanel is active:
271 │ Active │ 80 │ 2.5.0.201903021856 │ HABPanel user interface
Did I miss any relevant change that happened from 2.4 to 2.5?
rlkoshak
(Rich Koshak)
March 4, 2019, 2:40pm
2
Nothing I’m aware of. What error do you get in the browser when you try to go to it?
What errors do you see in the logs when you try to go to it?
pune2001
(Pune2001)
March 8, 2019, 6:27pm
3
When I try to go to HABPanel in the browser, I get “HTTP ERROR 404 - NOT FOUND”.
I uninstalled HABPanel via PAPER UI und re-installed it.
It shows up in PAPER UI:
but not in my browser:
In the log I see following error message after installing the binding:
2019-03-08 19:10:20.119 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-habpanel': Error restarting bundles:
Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.openhab.core.io.rest.sse.
No clue what this means. Any idea what I can do to get HABPanel up and running again?
rlkoshak
(Rich Koshak)
March 8, 2019, 6:33pm
4
What is means is HABpanel is not successfully installing.
Try Clear the Cache and reinstall HABpanel and see if the error goes away. If not we need to look into it some more.
wborn
(Wouter Born)
March 8, 2019, 7:25pm
5
Just restart openHAB and the exception probably no longer occurs.
It happens sometimes starting openHAB for the first time after an upgrade or initial installation.
See also openhab/openhab-core#597 and eclipse/smarthome#6682 .
pune2001
(Pune2001)
March 8, 2019, 8:14pm
6
Reinstalled HABPanel after clearing the cache. Restarted openHAB and the error went away:
2019-03-08 20:39:12.413 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
However, HABPanel still not showing up in the browser, nor does it appear in PAPER UI under CONFIGURATION -> SERVICES -> UI.
Any further ideas?
stolly82
(Stolly82)
June 10, 2019, 6:14pm
7
Hey,
now I have the same issue.
How did you solved this?
Thx Jan
pune2001
(Pune2001)
June 12, 2019, 4:17pm
8
I could not solve it so far. Therefore, and for other instability issues with 2.5, I moved back to 2.4 stable. Will give it another try soon.
stolly82
(Stolly82)
June 12, 2019, 4:59pm
9
Awesome!
Exact what I did to solve the issue
Ok, let’s wait for the stable version then.
Exactly the same, here. Made an apt-get upgrade to 2.5 and Habpanel shows the same “behaviour”. Anyone who has solved this, yet?
Celaeno1
(Alex)
December 31, 2019, 1:33am
11
Maybe this could be the reason?
You have to check EVERY first line in ALL .config files in ( /userdata/config/ and subfolders), if there are any of these entries:
especially: …/org/openhab/habpanel.config
WRONG:
:org.apache.felix.configadmin.revision:=“1.0”
or
:org.apache.felix.configadmin.revision:=“2.0”
or
:org.apache.felix.configadmin.revision:=“3.0”
…and so on…
CORRECT:
:org.apache.felix.configadmin.revision:=L"1"
or
:org.apache.felix.configadmin.revision:=L"2"
or
:org.apache.felix.configadmin.re…
Thank you! I tried without success.
Plus: I realized so many additional issues with the 2.5, that I downgraded to 2.4, again. (I could use my backup files for the configs, then…)
