I’m new to IOT and I decide to create my Smart Home step by step.
For the first step I decided set up a small z-wave network with some Smoke and temprature sensors.
My idea is to put some temperature e humidity detector in the house and track the temprature during the day with openHab.
I plan to use Everspring ST814 (http://www.everspring.com/ST814.aspx)
Then I will put a smoke sensor in the kitchen, FIBARO FGSD-002 Z-Wave Plus.
Be aware that the Everspring ST814 temperature/humidity sensor is close to junk. Tried out a few, did salt calibration to check out their humidity functions (search youtube for cigars, humidors, and humidity and you’ll find it). Results were that the humidity reported (from multiple copies) was essentially a random number and not in any way indicative of true humidity. Temperature worked decently well, but there are far cheaper options if you just want temperature. (Such as the monoprice passive infrared sensor that does temperature as well!)
your thermostat will have a sensor already. if you have a central heat, you could install intelligent trap to control the heat in some room.
But I don’t recommend to change the temp on your thermostat only for 1 room. you risk to have big temp difference on the others.
First I would play with openhab on my computer. it’s easy to modify and test. And when you have your config like you want. just transfert it to the new hardware.
so i think its possible. You could also install independent thermostat per room, change your valve for electronic one and plug your new thermostat to the valve. This way, if openhab bug, your house will not be cold of extremely hot. And if you bough z-wave thermostat you will be able to change the setpoint with openhab if needed.
These run fine with the Aeotec. I’m using the 4in1 with the Aeotec stick.
I would recommend that you get the 4 in 1 Motion/Door Sensor.
They are hardly more expensive but you can mount them on a Window or next to a Door.
