Just left over from when I had Simple Mode turned on in Paper UI.
Hey folks anyone got it working? I have the same problem - I am only getting currentActivity updates, no channels get triggered ![]()
Yes, still working fine here ![]()
19-Mär-2018 21:59:31.603 [INFO ] [org.eclipse.smarthome.model.script.EXTRA ] - HARMONY: Hub is going off...
19-Mär-2018 21:59:33.879 [INFO ] [org.eclipse.smarthome.model.script.EXTRA ] - HARMONY: Hub is off - no activity
Edit: ok, did not read your post exactly: I just catch the events, but have no usecase for it, so did not check if the trigger works … maybe I’ll try it later.
2nd Edit: the logging gets triggered by the channel, so yes, it is still working ![]()
No, I never got the channels to trigger. I tried reinstalling the Harmony binding two weeks ago and still have the same problem. ![]()
@bjsjr I have the same problem.
Just got a new harmony hub.
running OH 2.2 release version. Installed the harmony binding form paper UI. Added an item linked to the Current Activity channel.
I can see changes to the Current Activity Channel but I never get anything reported on the Activity Starting trigger or the Activity Started trigger.
@sihui - you seem to have the magic tough while the rest of us are having no luck. ![]()
Yeah, but no idea what causes this, sorry ![]()
The only thing not mentioned in this thread: I have my Harmony remote connected to Alexa, via openHAB and also via Alexa skill. But that should not make any difference …
@mcqwerty Still a no go for me.
I ended up working around the problem using openhab rules based on Current Activity instead of Activity Starting. I’m guessing it just adds a couple of seconds to the start of the rule.
I have a similar workround in place but I don’t like the flakiness of the situation. If the events work for some and not others and we don’t know why then it doesn’t instil a lot of confidence in me, especially when deciding whether or not to invest in more Harmony hardware.
Hi all,
I am experimenting with openHAB2 (2.2.0) since a few days and also have the problem, that the two activityStarting/Started events of my Harmony Hub Binding won’t fire.
I did some research with the debug outputs and in the source code of the Harmony Hub binding as well as the lib net.whistlingfish.harmony (which is used by the binding to communicate with the Hub).
In my log (tail) there are the following debug lines when starting an activity named “Radio”:
2018-04-05 23:06:42.404 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTING, error=-1
2018-04-05 23:06:42.734 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTED, error=-1
2018-04-05 23:06:42.743 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=START_ACTIVITY_FINISHED, id=29418203, status=UNKNOWN, error=200
2018-04-05 23:06:42.745 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - listener[org.openhab.binding.harmonyhub.handler.HarmonyHubHandler$1@ed9d83] notified: Activity[29418203]:Radio
2018-04-05 23:06:42.796 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTED, error=-1
These lines are apparently thrown by the lib whistlingfish, but there are no debug entries of the binding. So you can see, that the events should be triggered by receiving the events with type “STATE_DIGEST”.
In the source code of the library in file HarmonyClient.java in line 211 I found the location where the events apparently get discarded:
if (event.getErrorCode() == 200 && id != null) {
switch (event.getEventType()) {
case START_ACTIVITY_FINISHED:
updateCurrentActivity(getConfig().getActivityById(id));
break;
case STATE_DIGEST:
updateActivityStatus(getConfig().getActivityById(id), event.getActivityStatus());
break;
default:
break;
In my log entries, the “error” is always “200” when receiving a STATE_DIGEST typed message.
So it never comes to “updateActivityStatus” to fire the events.
Either the library is not correct or different Hubs are reacting differently?!
Can anyone of you confirm this on his/her machine or give different examples?
Cheers
Jonathan
@ppieczul implemented these activity triggers in the Harmony Binding with:
https://github.com/openhab/openhab2-addons/pull/2678
Can you help us solving this issue?
Hi. I will check tomorrow (or is it today but during the daytime), obviously the error code equal to -1 is not expected but for some reasons it occurs and only on some installations. May be some bug or correct behavior, no idea. A workaround will be simple, but let me try to find the root cause.
Since I don’t see the same problem on my installation, also after upgrading the most recent snapshot, I have to ask for some help.
@elektrolubach could you please install this binding: Dropbox
It has extra logging added to the whistlingfish library, and paste the logs that follow STATE_DIGEST: start message.
In case of a successful trigger it looks like that:
2018-04-07 12:58:36.222 [DEBUG] [ingfish.harmony.protocol.EventStanza] - STATE_DIGEST: start
2018-04-07 12:58:36.223 [DEBUG] [ingfish.harmony.protocol.EventStanza] - CONTENT: {"sleepTimerId":-1,"runningZoneList":[],"configVersion":148,"activityId":"17316451","errorCode":"200","syncStatus":0,"time":1523055230,"stateVersion":584,"tzOffset":"7200","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"7200","isSetupComplete":true,"contentVersion":112,"wifiStatus":1,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","activityStatus":2,"runningActivityList":"17316451","tz":"CET-1CEST,M3.5.0,M10.4.0\/3","activitySetupState":false,"updates":{"100":"4.14.112","97":"4.14.112"},"hubUpdate":false,"sequence":false,"accountId":"7394939"}
2018-04-07 12:58:36.223 [DEBUG] [ingfish.harmony.protocol.EventStanza] - READ VALUE: ID=17316451, STATUS=2, ERRORCODE=200
2018-04-07 12:58:36.224 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=17316451, status=ACTIVITY_IS_STARTED, error=200
Pawel
Hi Pawel,
thanks for the really quick answer to this. I replaced the 2.2.0-version with the one provided by you and get the following debug output:
2018-04-07 21:17:10.339 [DEBUG] [ingfish.harmony.protocol.EventStanza] - STATE_DIGEST: start
2018-04-07 21:17:10.343 [DEBUG] [ingfish.harmony.protocol.EventStanza] - CONTENT: {"sleepTimerId":-1,"runningZoneList":[],"configVersion":207,"activityId":"29418203","syncStatus":0,"time":1523047602,"stateVersion":344,"tzOffset":"7200","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"7200","isSetupComplete":true,"contentVersion":90,"wifiStatus":1,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","activityStatus":1,"runningActivityList":"","tz":"CET-1CEST,M3.5.0,M10.4.0\/3","activitySetupState":false,"updates":{"97":"4.13.100"},"hubUpdate":false,"sequence":false,"accountId":"6835756"}
2018-04-07 21:17:10.347 [DEBUG] [ingfish.harmony.protocol.EventStanza] - READ VALUE: ID=29418203, STATUS=1, ERRORCODE=null
2018-04-07 21:17:10.350 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTING, error=-1
2018-04-07 21:17:10.668 [DEBUG] [ingfish.harmony.protocol.EventStanza] - STATE_DIGEST: start
2018-04-07 21:17:10.671 [DEBUG] [ingfish.harmony.protocol.EventStanza] - CONTENT: {"sleepTimerId":-1,"runningZoneList":[],"configVersion":207,"activityId":"29418203","syncStatus":0,"time":1523047602,"stateVersion":345,"tzOffset":"7200","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"7200","isSetupComplete":true,"contentVersion":90,"wifiStatus":1,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","activityStatus":2,"runningActivityList":"","tz":"CET-1CEST,M3.5.0,M10.4.0\/3","activitySetupState":false,"updates":{"97":"4.13.100"},"hubUpdate":false,"sequence":false,"accountId":"6835756"}
2018-04-07 21:17:10.678 [DEBUG] [ingfish.harmony.protocol.EventStanza] - READ VALUE: ID=29418203, STATUS=2, ERRORCODE=null
2018-04-07 21:17:10.680 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTED, error=-1
2018-04-07 21:17:10.698 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=START_ACTIVITY_FINISHED, id=29418203, status=UNKNOWN, error=200
2018-04-07 21:17:10.702 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - listener[org.openhab.binding.harmonyhub.handler.HarmonyHubHandler$1@e8c74e] notified: Activity[29418203]:Radio
2018-04-07 21:17:10.731 [DEBUG] [ingfish.harmony.protocol.EventStanza] - STATE_DIGEST: start
2018-04-07 21:17:10.740 [DEBUG] [ingfish.harmony.protocol.EventStanza] - CONTENT: {"sleepTimerId":-1,"runningZoneList":[],"configVersion":207,"activityId":"29418203","syncStatus":0,"time":1523047602,"stateVersion":346,"tzOffset":"7200","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"7200","isSetupComplete":true,"contentVersion":90,"wifiStatus":1,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","activityStatus":2,"runningActivityList":"29418203","tz":"CET-1CEST,M3.5.0,M10.4.0\/3","activitySetupState":false,"updates":{"97":"4.13.100"},"hubUpdate":false,"sequence":false,"accountId":"6835756"}
2018-04-07 21:17:10.745 [DEBUG] [ingfish.harmony.protocol.EventStanza] - READ VALUE: ID=29418203, STATUS=2, ERRORCODE=null
2018-04-07 21:17:10.747 [DEBUG] [.whistlingfish.harmony.HarmonyClient] - Received event: type=STATE_DIGEST, id=29418203, status=ACTIVITY_IS_STARTED, error=-1
It seams, the ERRORCODE is always “null” in my setup.
At least the Hub-SwVersion is equal, the other version strings I think are irrelevant, because referenced to the setup of the harmony activities.
Thanks again a lot for your help!
Regards
Jonathan
Great. It looks like for some reason the event received from the hub does not contain this one field: errorCode.
There is no documentation to that protocol. I think I can assume that lack of explicit errorCode means errorCode = 200 = everything is ok. I made such changes here:
You can try and use this version until the code gets merged.
Interesting case! Thanks for your help debugging it so far!
Pawel
Thanks for the quick bugfix.
Unfortunately the binding won’t install throwing a lot of exceptions during installation process. The first being this one:
2018-04-07 23:09:51.078 [ERROR] [org.openhab.binding.harmonyhub ] - [org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory(32)] Error during instantiation of the implementation object
java.lang.Error: Unresolved compilation problems:
The import org.osgi.framework cannot be resolved
The import com.google cannot be resolved
Sets cannot be resolved
ServiceRegistration cannot be resolved to a type
BundleContext cannot be resolved to a type
at org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory.<init>(HarmonyHubHandlerFactory.java:38) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
at java.lang.Class.newInstance(Class.java:442) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:237) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:403) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) [42:org.apache.felix.scr:2.0.12]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Any ideas?
Thanks!
Jonathan
Remove all instances from addons dir and uninstall all instances from karaf console. Copy the jar again. If does not help restart openHAB. Practically can’t be binding related if previous version installed correctly - this one is basically the same except for the hub library.
I did all that, but it won’t install.
If I copy the first jar (2.3.0-SNAPSHOT) the installation runs through without problems, the Hub gets initialised correctly.
With the second jar (2.3.0-SNAPTSHOT2) I always get the error messages.
This is the full list of all appearing messages including the stack trace:
trace.txt.xml (153.3 KB)
(remove xml extension - only for upload limitation)
Thanks in advance.
Jonathan
@elektrolubach I am sorry, I have not checked because it was a rebuild and indeed it does not install. I simply rebuilt it again and checked that it installs this time, here is the version: Dropbox
Sorry for the trouble.
Hi @ppieczul,
thanks again for the quick support with the new version.
First, the triggers are working great!
Only one thing could be better - in my opinion:
When powering off an activity there is only the trigger “PowerOff starting”.
The “PowerOff started” is not available if I get the code of the whistlingfish lib correctly?
I need a trigger of the Harmony Hub when the PowerOff procedure has ended to switch off a WLAN socket. A workaround - or maybe the better way - is to use the item state update trigger from “ActivityXYZ” to “PowerOff”!?
Some topics are still not working completely well:
- During installation, some other exceptions appeared in the log, see file trace2.txt.xml (40.7 KB)
- The auto discovery function for the Hub doesn’t work anymore - I had to manually add the hub; for the devices the discovery function works properly
- In the control window of the item “Current Activity” there was a selection list of all available activities until version 2.3.0-SNAPSHOT; in the current version 2.3.0-SNAPSHOT-3 there is only a text box with a checkmark at the end (I have to type the activity name)
Also upon startup there is standing NULL as activity name
Maybe topic 2 and 3 are caused by topic 1?
Thanks!
Regards
Jonathan
@elektrolubach it will probably be solved when you use the JAR with a more recent openHAB 2.3.0 snapshot build.
See: Unit-Support, KNX 2, Karaf 4.1.5 Upgrade and more! - #6 by mhilbush
