HarmonyClient is not connected
Since upgrading to M2 i have an issue when sending throught he harmony binding.
Hub says its online, commands still work through remote and Alexa.
Have I missed something simple in the update?
2019-08-31 08:53:22.524 [WARN ] [b.internal.handler.HarmonyHubHandler] - Cannot send command 'Watch TV' on harmonyhub:hub:HarmonyHub:currentActivity because HarmonyClient is not connected```
An uninstall and reinstall of the binding has fixed this
Unfortunately this hasn’t resolved my issue. If I uninstall and reinstall the binging it works immediately but very temporary before same issue - anyone else experiencing this behaviour?
I have the same issue M1 was fine.
M2 and M3 go offline and report
[b.internal.handler.HarmonyHubHandler] - Cannot send command ‘mycommand’ on harmonyhub:hub:Back:currentActivity because HarmonyClient is not connected
Weirdly mine seems to have come good on its own
Which are the harmony firmware version?
My hab has these (every 10 mins) and worked for a week
I restarted the binding after it would not connect
it works again after the restart but may have caused a bunch of couldnt stop http thread errors
2019-09-26 01:37:18.955 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-26 01:37:18.958 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 33025
2019-09-26 01:47:18.962 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-26 01:47:18.964 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 45845
2019-09-26 01:57:18.965 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-26 01:57:18.969 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 36473
2019-09-26 02:07:18.971 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-26 02:07:18.973 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 34059
tonight openhab couldnt control it.
so i restarted the binding (via exec binding)
2019-09-26 18:55:42.511 [INFO ] [script.openhabclientTrigger exec ON ] - Run:bundle:restart org.openhab.binding.harmonyhub
2019-09-26 18:55:52.051 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STOPPING - org.openhab.binding.harmonyhub
2019-09-26 18:55:52.061 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={service.id=368, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory, component.id=219} - org.openhab.binding.harmonyhub
2019-09-26 18:55:52.204 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=377, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-26 18:55:52.263 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: java.nio.channels.AsynchronousCloseException
at com.digitaldan.harmony.HarmonyClient.getDiscoveryFromHost(HarmonyClient.java:186) ~[?:?]
at com.digitaldan.harmony.HarmonyClient.connect(HarmonyClient.java:122) ~[?:?]
at org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler.connect(HarmonyHubHandler.java:281) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-09-26 18:55:52.270 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-26 18:55:57.268 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing ‘harmonyhub:hub:Back’ takes more than 5000ms.
2019-09-26 18:55:57.274 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=372, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.290 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=369, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.discovery.HarmonyHubDiscoveryService, component.id=220} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.295 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Stop HarmonyHub background discovery
2019-09-26 18:55:57.319 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STOPPED - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.323 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STARTING - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.327 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STARTED - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.341 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={service.id=517, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory, component.id=306} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.349 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=518, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.discovery.HarmonyHubDiscoveryService, component.id=307} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.352 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Start Harmony Hub background discovery
2019-09-26 18:55:57.353 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Start Scan
2019-09-26 18:55:57.355 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-26 18:55:57.356 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 34063
2019-09-26 18:55:57.390 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - HarmonyDeviceDiscoveryService org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@b010da
2019-09-26 18:55:57.394 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=519, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.423 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status UNKNOWN
2019-09-26 18:55:57.433 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - HarmonyDeviceDiscoveryService org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@121dc0d
2019-09-26 18:55:57.444 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=520, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-26 18:55:57.491 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status UNKNOWN
2019-09-26 18:55:57.822 [INFO ] [thome.model.script.openhabclient_Run] - Result:
2019-09-26 18:55:57.945 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 1929
2019-09-26 18:55:58.363 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192
1
2019-09-26 18:55:58.395 [INFO ] [thome.model.script.openhabclient_Run] - Runmore:bundle:status org.openhab.binding.harmonyhub
2019-09-26 18:55:59.317 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-26 18:55:59.319 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-09-26 18:55:59.802 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-26 18:55:59.804 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-26 18:56:01.072 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514647:buttonPress
2019-09-26 18:56:01.078 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48515108:buttonPress
2019-09-26 18:56:01.083 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514648:buttonPress
2019-09-26 18:56:01.088 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514646:buttonPress
2019-09-26 18:56:01.093 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-26 18:56:01.097 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-26 18:56:01.101 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-26 18:56:01.105 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-26 18:56:01.109 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-26 18:56:01.119 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-26 18:56:02.637 [INFO ] [thome.model.script.openhabclient_Run] - Result:Active
2019-09-26 18:56:22.284 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221219,5,main]
2019-09-26 18:56:22.287 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221216,5,main]
2019-09-26 18:56:22.290 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221266,5,main]
2019-09-26 18:56:22.292 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221120,5,main]
2019-09-26 18:56:22.295 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221192,5,main]
2019-09-26 18:56:22.297 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221307,5,main]
2019-09-26 18:56:22.300 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221227,5,main]
2019-09-26 18:56:22.303 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221158,5,main]
2019-09-26 18:56:22.305 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221119,5,main]
2019-09-26 18:56:22.308 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221184,5,main]
2019-09-26 18:56:22.310 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221260,5,main]
2019-09-26 18:56:22.312 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221153,5,main]
2019-09-26 18:56:22.315 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@224971]@1402d2f{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@224971-221121,5,main]
I’ll take a look, thanks. When the binding was not working, and before you restarted, did you see any errors in the logs?
2019-09-28 19:43:34.082 [INFO ] [e.smarthome.model.script.dodirectvtv] - Perform dodirectvtv Rule setting ON
2019-09-28 19:43:34.093 [INFO ] [ipse.smarthome.model.script.doLights] - Perform on-off - DirecTV setting ON DirecTV=ON DirecTV (Type=SwitchItem, State=ON, Label=DirecTV, Category=null, Tags=[Switchable], Groups=[FamilyRoom, Lights])
2019-09-28 19:43:34.138 [WARN ] [b.internal.handler.HarmonyHubHandler] - Cannot send command ‘DirecTV’ on harmonyhub:hub:Back:currentActivity because HarmonyClient is not connected
2019-09-28 19:44:13.876 [INFO ] [e.smarthome.model.script.dodirectvtv] - Perform dodirectvtv Rule setting ON
2019-09-28 19:44:13.887 [INFO ] [ipse.smarthome.model.script.doLights] - Perform on-off - DirecTV setting ON DirecTV=ON DirecTV (Type=SwitchItem, State=ON, Label=DirecTV, Category=null, Tags=[Switchable], Groups=[FamilyRoom, Lights])
2019-09-28 19:44:13.930 [WARN ] [b.internal.handler.HarmonyHubHandler] - Cannot send command ‘DirecTV’ on harmonyhub:hub:Back:currentActivity because HarmonyClient is not connected
2019-09-28 19:44:34.834 [INFO ] [rnal.service.RemoteControllerService] - Using WebSocket interface
2019-09-28 19:45:20.053 [INFO ] [clipse.smarthome.model.script.Office] - sensor_1_motion changed ON
2019-09-28 19:45:20.084 [INFO ] [clipse.smarthome.model.script.Office] - sensor_1_motion ON light should be on
2019-09-28 19:45:20.121 [INFO ] [ipse.smarthome.model.script.doLights] - Perform on-off - Office setting ON DeskSwitch=ON DeskSwitch (Type=SwitchItem, State=ON, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 19:45:20.125 [INFO ] [model.script.MemberofAllItemschanged] - DeskSwitch=ON previousState=OFF DeskSwitch (Type=SwitchItem, State=ON, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 19:46:50.601 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 19:46:50.605 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 35027
2019-09-28 19:47:19.445 [INFO ] [clipse.smarthome.model.script.Office] - sensor_1_motion changed OFF
2019-09-28 19:49:51.676 [WARN ] [org.eclipse.jetty.io.ManagedSelector] - java.nio.channels.ClosedSelectorException
2019-09-28 19:49:51.679 [WARN ] [l.protocol.RemoteControllerWebSocket] - WebSocketClient failure: java.lang.InterruptedException
2019-09-28 19:56:50.607 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 19:56:50.610 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 35003
2019-09-28 19:58:28.179 [INFO ] [model.script.MemberofAllItemschanged] - DeskSwitch=OFF previousState=ON DeskSwitch (Type=SwitchItem, State=OFF, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 19:58:28.195 [INFO ] [ipse.smarthome.model.script.doLights] - Perform on-off - Office setting OFF DeskSwitch=OFF DeskSwitch (Type=SwitchItem, State=OFF, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 20:06:50.612 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 20:06:50.615 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 38257
2019-09-28 20:08:17.991 [INFO ] [lipse.smarthome.model.script.Weather] - Temperature evolved of -2.178 degrees.
2019-09-28 20:16:50.617 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 20:16:50.620 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 46467
2019-09-28 09:34:43.195 [INFO ] [rnal.service.RemoteControllerService] - Using None interface
2019-09-28 09:34:43.204 [INFO ] [rnal.service.RemoteControllerService] - Using None interface
2019-09-28 09:36:50.244 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 09:36:50.247 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 36665
2019-09-28 09:38:25.833 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:39:25.821 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:39:25.826 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=228}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1336977
2019-09-28 09:39:25.829 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1336977
at com.digitaldan.harmony.HarmonyClient.connect(HarmonyClient.java:119) ~[?:?]
2019-09-28 09:39:25.842 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:40:36.206 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:40:36.484 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 09:40:36.486 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 09:40:36.503 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 09:40:41.665 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 09:40:41.682 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 09:40:41.698 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 09:40:41.715 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 09:40:41.730 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 09:40:42.114 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 09:40:42.122 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 09:41:28.011 [INFO ] [model.script.MemberofAllItemschanged] - DeskSwitch=OFF previousState=ON DeskSwitch (Type=SwitchItem, State=OFF, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 09:41:28.016 [INFO ] [ipse.smarthome.model.script.doLights] - Perform on-off - Office setting OFF DeskSwitch=OFF DeskSwitch (Type=SwitchItem, State=OFF, Label=Office, Category=null, Tags=[thing=zwave:device:1685e5947ba:node3, Lighting], Groups=[AllItems, Office, Lights])
2019-09-28 09:43:46.597 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:44:46.589 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:44:46.594 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=241}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1ea9df1
2019-09-28 09:44:46.597 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1ea9df1
2019-09-28 09:44:46.609 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:45:56.850 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:45:57.159 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 09:45:57.161 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 09:45:57.177 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 09:46:02.346 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 09:46:02.356 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 09:46:02.368 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 09:46:02.378 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 09:46:02.389 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 09:46:02.399 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 09:46:02.409 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 09:46:50.250 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 09:46:50.253 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 34191
2019-09-28 09:51:26.220 [INFO ] [model.script.MemberofAllItemschanged] - BathroomFan=OFF previousState=ON BathroomFan (Type=SwitchItem, State=OFF, Label=Bathroom Fan, Category=null, Tags=[Fan, thing=zwave:device:1685e5947ba:node30, Switchable], Groups=[AllItems, FamilyRoom, Fan])
2019-09-28 09:51:47.405 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:52:47.395 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:52:47.400 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=257}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@153fd72
2019-09-28 09:52:47.402 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@153fd72
2019-09-28 09:52:47.412 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 09:53:57.925 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 09:53:58.197 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 09:53:58.199 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 09:53:58.241 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 09:54:03.372 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 09:54:03.383 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 09:54:03.394 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 09:54:03.405 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 09:54:03.416 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 09:54:03.426 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 09:54:03.437 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 09:56:50.256 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 09:56:50.258 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 41243
2019-09-28 09:59:48.373 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:00:48.365 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:00:48.370 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=271}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1e7c107
2019-09-28 10:00:48.373 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1e7c107
2019-09-28 10:00:48.386 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:01:58.900 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:01:59.185 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 10:01:59.188 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 10:01:59.211 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 10:02:04.372 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 10:02:04.385 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 10:02:04.395 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 10:02:04.405 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 10:02:04.415 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 10:02:04.426 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 10:02:04.437 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 10:06:50.261 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 10:06:50.264 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 37525
2019-09-28 10:26:50.280 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 37177
2019-09-28 10:31:52.360 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:32:52.354 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:32:52.358 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=326}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1868076
2019-09-28 10:32:52.361 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@1868076
2019-09-28 10:32:52.371 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:33:52.369 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:33:52.572 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 10:33:52.575 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 10:33:52.576 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 10:33:52.589 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 10:33:52.598 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 10:33:52.607 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 10:33:52.616 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 10:33:52.624 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 10:33:52.625 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 10:33:52.635 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 10:36:50.284 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-28 10:36:50.287 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 34407
2019-09-28 10:37:58.658 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:38:58.650 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:38:58.655 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=341}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@fd3b6e
2019-09-28 10:38:58.658 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@fd3b6e
2019-09-28 10:38:58.669 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:40:03.860 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:40:34.003 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37282,5,main]
2019-09-28 10:40:34.007 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37289,5,main]
2019-09-28 10:40:34.010 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37288,5,main]
2019-09-28 10:40:34.013 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37230,5,main]
2019-09-28 10:40:34.017 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37327,5,main]
2019-09-28 10:40:34.223 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37290,5,main]
2019-09-28 10:40:34.224 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37317,5,main]
2019-09-28 10:40:34.225 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37268,5,main]
2019-09-28 10:40:34.226 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37271,5,main]
2019-09-28 10:40:34.228 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37272,5,main]
2019-09-28 10:40:34.229 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37186,5,main]
2019-09-28 10:40:34.230 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37294,5,main]
2019-09-28 10:40:34.232 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37297,5,main]
2019-09-28 10:40:34.233 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37313,5,main]
2019-09-28 10:40:34.234 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37229,5,main]
2019-09-28 10:40:34.235 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37181,5,main]
2019-09-28 10:40:34.236 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37224,5,main]
2019-09-28 10:40:34.237 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37248,5,main]
2019-09-28 10:40:34.238 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37309,5,main]
2019-09-28 10:40:34.239 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37214,5,main]
2019-09-28 10:40:34.240 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37270,5,main]
2019-09-28 10:40:34.241 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37179,5,main]
2019-09-28 10:40:34.242 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37321,5,main]
2019-09-28 10:40:34.243 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37182,5,main]
2019-09-28 10:40:34.244 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37217,5,main]
2019-09-28 10:40:34.245 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37220,5,main]
2019-09-28 10:40:34.246 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37192,5,main]
2019-09-28 10:40:34.247 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37244,5,main]
2019-09-28 10:40:34.248 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=165<=200,i=0,r=-1,q=165}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-37338,5,main]
2019-09-28 10:40:34.300 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: Insufficient configured threads: required=200 < max=200 for QueuedThreadPool[HttpClient@1df9e50]@1e91160{STARTED,8<=168<=200,i=1,r=4,q=0}[ReservedThreadExecutor@2166ed{s=0/4,p=0}]
2019-09-28 10:40:34.307 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:41:35.603 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:41:35.848 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 10:41:35.850 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-28 10:41:35.873 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-28 10:41:35.944 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-28 10:41:35.954 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-28 10:41:35.963 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-28 10:41:35.970 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-28 10:41:35.978 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-28 10:41:35.989 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-28 10:41:35.996 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-28 10:43:56.015 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:44:56.101 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:44:56.105 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{FAILED,8<=0<=200,i=0,r=-1,q=358}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@11d2cd7
2019-09-28 10:44:56.108 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$170/970967@11d2cd7
2019-09-28 10:44:56.118 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-28 10:46:10.769 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-28 10:46:11.052 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-28 10:46:11.054 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
the prev were just while running (and flailing )
this is a bundle restart - and a reconnect - yay -
2019-09-29 08:01:16.781 [INFO ] [script.openhabclientTrigger exec ON ] - Run:bundle:restart org.openhab.binding.harmonyhub
2019-09-29 08:01:22.477 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STOPPING - org.openhab.binding.harmonyhub
2019-09-29 08:01:22.485 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={service.id=378, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory, component.id=219} - org.openhab.binding.harmonyhub
2019-09-29 08:01:22.632 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=380, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-29 08:01:22.689 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at 192.168.25.131
2019-09-29 08:01:22.696 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-09-29 08:01:27.697 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing ‘harmonyhub:hub:Back’ takes more than 5000ms.
2019-09-29 08:01:27.711 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=379, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.736 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=381, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.discovery.HarmonyHubDiscoveryService, component.id=220} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.748 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Stop HarmonyHub background discovery
2019-09-29 08:01:27.759 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STOPPED - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.771 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STARTING - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.812 [DEBUG] [org.openhab.binding.harmonyhub ] - BundleEvent STARTED - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.831 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={service.id=492, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.HarmonyHubHandlerFactory, component.id=286} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.844 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - HarmonyDeviceDiscoveryService org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@50cb9e
2019-09-29 08:01:27.847 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=493, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.872 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status UNKNOWN
2019-09-29 08:01:27.889 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - HarmonyDeviceDiscoveryService org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler@11c61
2019-09-29 08:01:27.893 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=494, service.bundleid=346, service.scope=singleton} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.916 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status UNKNOWN
2019-09-29 08:01:27.931 [DEBUG] [org.openhab.binding.harmonyhub ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=495, service.bundleid=346, service.scope=bundle, component.name=org.openhab.binding.harmonyhub.internal.discovery.HarmonyHubDiscoveryService, component.id=287} - org.openhab.binding.harmonyhub
2019-09-29 08:01:27.932 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.129
2019-09-29 08:01:27.935 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Start Harmony Hub background discovery
2019-09-29 08:01:27.937 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Start Scan
2019-09-29 08:01:27.941 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-09-29 08:01:27.942 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 46301
2019-09-29 08:01:28.401 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host 192.168.25.131
2019-09-29 08:01:29.780 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-29 08:01:29.781 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-09-29 08:01:29.784 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514647:buttonPress
2019-09-29 08:01:29.790 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514646:buttonPress
2019-09-29 08:01:29.794 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514648:buttonPress
2019-09-29 08:01:29.795 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48515108:buttonPress
2019-09-29 08:01:29.800 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Frontroom:currentActivity
2019-09-29 08:01:29.837 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-09-29 08:01:30.331 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-09-29 08:01:30.339 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-09-29 08:01:30.341 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-09-29 08:01:30.342 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-09-29 08:01:30.554 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-09-29 08:01:30.556 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-09-29 08:01:30.571 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-09-29 08:01:30.571 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-09-29 08:01:30.584 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-09-29 08:01:30.701 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to DirecTV
2019-09-29 08:01:52.713 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-38872,5,main]
2019-09-29 08:01:52.716 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-38740,5,main]
2019-09-29 08:01:52.719 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-38761,5,main]
2019-09-29 08:01:52.721 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1df9e50]@1e91160{STOPPING,8<=198<=200,i=0,r=-1,q=199}[NO_TRY] Couldn’t stop Thread[HttpClient@1df9e50-38877,5,main]
Hi, i made a small change to use the built in jetty client in OH, which may help. Can you try using a test version i have posted here ?
Hi - I have the same problem and I would love to test it - except I dont know how to. I downloaded the jar file to /usr/share/openhab2/addons (ref: Location of addons folder ) and OpenHAB only found the old/original binding binding-harmonyhub - 2.5.0.M2
(I also double-checked IP address in case that is an issue - my Hub is allocated fixed IP address in the network so it should not be the issue)
ok eventually I managed to work out how to do this…These are the steps I took
  1. removed Harmony related Things
  2. To uninstall the existing binding - I went into the console to remove it:
  • ssh -p 8101 openhab@localhost
  • default password = habopen
  • bundle:list |grep armony
  • bundle:uninstall xxx (the first digits of the returned line above - where you see the line number for line with Harmony/harmony)
  • logout
  1. Did the steps to clear cache
  • sudo systemctl stop openhab2
  • sudo openhab-cli clean-cache
  • sudo reboot
  1. after reboot - checked Paper UI - Things and Binding to make sure Harmony Binding is gone
  2. Go to /usr/share/openhab2/addons (or the appropriate addon directory as per openHAB on Linux | openHAB )
  3. sudo wget https://github.com/digitaldan/openhab2-addons/releases/download/harmony-2.5-jetty-fix-1/org.openhab.binding.harmonyhub-2.5.0-SNAPSHOT.jar
  4. OpenHab automatically detects the new binding, go to Paper UI, and you should be able to add your Harmony Hub from the Inbox
  5. I had to go to Configuration → Things to enable the Harmony Hub (the alarm clock icon)
  6. Done
if you want to confirm the version:
10. go back to console again (see Step2)
11. bundle:list |grep armony
12. you should see the version - I have “2.5.0.201909271708” - 20190927 should be the date Dan posted the update
Good luck, if you are reading this
@digitaldan Ive got the jar installed - ive found an uninstall and reinstall fixed the problem for the immediate - will monitor for a while and feed back if any issues.
@digitaldan
I’ve tried your test version also, but I get about 20-25 times a day:
Could not connect: Disconnected
2019-10-18 22:04:11.651 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-18 23:39:53.306 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 01:23:28.346 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 02:58:48.779 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 03:16:37.964 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 03:21:57.031 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 07:46:07.274 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 07:52:58.235 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 08:44:26.070 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 10:24:58.024 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 10:35:18.302 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 11:15:36.411 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 13:48:15.094 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 13:58:34.513 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 15:07:24.213 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 17:24:13.718 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
2019-10-19 17:29:33.051 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HarmonyHub' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Could not connect: Disconnected
One minute later it connects again. OK :slight_smile: That’s a feature, I know about it. But how to get rid of these errors?
After M4 - not better ( not sure if your http threading? commit made it into M4 )
( I had some stability under M3 - I deleted the things and then added Bridge definition in a things file - )
This is from M4
2019-10-21 15:31:29.796 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-10-21 15:31:29.800 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 33071
2019-10-21 15:32:46.273 [INFO ] [lipse.smarthome.model.script.Weather] - Temperature evolved of 0.44 degrees.
2019-10-21 15:41:29.804 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-10-21 15:41:29.807 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 40307
2019-10-21 15:51:29.810 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-10-21 15:51:29.812 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 37451
2019-10-21 15:58:55.751 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 15:59:55.737 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 15:59:55.741 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1a06430]@14a73ef{FAILED,8<=0<=200,i=0,r=-1,q=73}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@139bbca
2019-10-21 15:59:55.744 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at Harmonyfront
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@139bbca
2019-10-21 15:59:55.757 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:00:16.002 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:01:12.219 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:01:12.487 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:01:12.489 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-10-21 16:01:12.497 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:01:12.821 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514647:buttonPress
2019-10-21 16:01:12.826 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514648:buttonPress
2019-10-21 16:01:12.831 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514646:buttonPress
2019-10-21 16:01:12.836 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48515108:buttonPress
2019-10-21 16:01:12.841 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Frontroom:currentActivity
2019-10-21 16:01:15.991 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:01:15.995 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@126b46f]@1fdc24d{FAILED,8<=0<=200,i=0,r=-1,q=89}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@1e15a78
2019-10-21 16:01:15.997 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at HarmonyBack
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@1e15a78
2019-10-21 16:01:16.009 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:01:29.813 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-10-21 16:01:29.816 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 40345
2019-10-21 16:02:32.374 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:02:32.676 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:02:32.677 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-10-21 16:02:32.687 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:02:33.032 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-10-21 16:02:33.037 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-10-21 16:02:33.041 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-10-21 16:02:33.045 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-10-21 16:02:33.049 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-10-21 16:02:33.053 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-10-21 16:02:33.057 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-10-21 16:04:22.560 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:05:22.549 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:05:22.553 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1a06430]@14a73ef{FAILED,8<=0<=200,i=0,r=-1,q=88}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@11ee528
2019-10-21 16:05:22.556 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at Harmonyfront
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@11ee528
2019-10-21 16:05:22.567 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:05:42.744 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:06:33.073 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:06:33.214 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:06:33.234 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-10-21 16:06:33.243 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:06:33.374 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514648:buttonPress
2019-10-21 16:06:33.380 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514646:buttonPress
2019-10-21 16:06:33.385 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48515108:buttonPress
2019-10-21 16:06:33.391 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514647:buttonPress
2019-10-21 16:06:33.444 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Frontroom:currentActivity
2019-10-21 16:06:42.737 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:06:42.741 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@126b46f]@1fdc24d{FAILED,8<=0<=200,i=0,r=-1,q=100}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@66ae3a
2019-10-21 16:06:42.744 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at HarmonyBack
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@66ae3a
2019-10-21 16:06:42.755 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:07:53.280 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:07:53.481 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:07:53.482 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-10-21 16:07:53.491 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:07:53.625 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-10-21 16:07:53.630 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-10-21 16:07:53.634 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-10-21 16:07:53.634 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-10-21 16:07:53.638 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-10-21 16:07:53.638 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-10-21 16:07:53.642 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-10-21 16:09:43.325 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:10:43.315 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:10:43.319 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1a06430]@14a73ef{FAILED,8<=0<=200,i=0,r=-1,q=102}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@6422da
2019-10-21 16:10:43.326 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at Harmonyfront
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@6422da
2019-10-21 16:10:43.337 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:11:03.595 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:11:29.821 [DEBUG] [discovery.HarmonyHubDiscoveryService] - StartScan called
2019-10-21 16:11:29.824 [DEBUG] [discovery.HarmonyHubDiscoveryService] - Creating Harmony server on port 40699
2019-10-21 16:11:53.677 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:11:53.838 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:11:53.840 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-10-21 16:11:53.855 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:11:53.985 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514647:buttonPress
2019-10-21 16:11:53.991 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48515108:buttonPress
2019-10-21 16:11:53.997 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514648:buttonPress
2019-10-21 16:11:54.003 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Frontroom:48514646:buttonPress
2019-10-21 16:11:54.008 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Frontroom:currentActivity
2019-10-21 16:12:03.591 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:12:03.597 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@126b46f]@1fdc24d{FAILED,8<=0<=200,i=0,r=-1,q=116}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@19d0fe1
2019-10-21 16:12:03.600 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at HarmonyBack
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@19d0fe1
at org.openhab.binding.harmonyhub.internal.handler.HarmonyHubHandler.connect(HarmonyHubHandler.java:281) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-10-21 16:12:03.614 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:13:13.864 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host HarmonyBack
2019-10-21 16:13:14.054 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:13:14.056 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Back
2019-10-21 16:13:14.066 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
2019-10-21 16:13:14.170 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784987:buttonPress
2019-10-21 16:13:14.176 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31784988:buttonPress
2019-10-21 16:13:14.181 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785063:buttonPress
2019-10-21 16:13:14.185 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785142:buttonPress
2019-10-21 16:13:14.189 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785978:buttonPress
2019-10-21 16:13:14.194 [DEBUG] [nternal.handler.HarmonyDeviceHandler] - Updating harmonyhub:device:Back:31785011:buttonPress
2019-10-21 16:13:14.198 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating harmonyhub:hub:Back:currentActivity
2019-10-21 16:15:03.958 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:16:03.945 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:16:03.949 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - QueuedThreadPool[HttpClient@1a06430]@14a73ef{FAILED,8<=0<=200,i=0,r=-1,q=117}[NO_TRY] rejected org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@182f3e7
2019-10-21 16:16:03.953 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Could not connect to HarmonyHub at Harmonyfront
java.io.IOException: org.eclipse.jetty.io.ManagedSelector$$Lambda$169/14589188@182f3e7
2019-10-21 16:16:03.965 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:16:24.140 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status OFFLINE
2019-10-21 16:17:14.345 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Connecting: host Harmonyfront
2019-10-21 16:17:14.516 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating listeners with status ONLINE
2019-10-21 16:17:14.518 [DEBUG] [covery.HarmonyDeviceDiscoveryService] - getting devices on Frontroom
2019-10-21 16:17:14.528 [DEBUG] [b.internal.handler.HarmonyHubHandler] - Updating current activity to PowerOff
Hi. Did you manage to get this to work? I have a similar issue
thanks
I have a similar issue too , anybody got Harmonyhub working
I have harmony hub working on oh3
