I am trying to add a Heatit Z-Temp2 battery powered Z-Wave thermostat to my system.
The thermostat is discovered by OpenHab when scanning for new Thing. It is added as Thing with Identifier = zwave:device:601426fd42:node4 and default Label = Z-Wave Node 004. It reports to be online.
However, the Thing Type states that:
This device has not been fully discovered by the binding. There are a few
possible reasons for this -:
- The device is not in the database. If the device attributes show that this
device has a valid manufacturer ID, device ID and type, then this is likely
the case (eg. you see a label like "Z-Wave node 1 (0082:6015:020D::2.0)").
Even if the device appears to be in the database, some manufacturers use
multiple sets of references for different regions or versions, and your
device references may not be in the database. In either case, the database
must be updated and you should raise an issue to get this addressed.
- The device initialisation is not complete. Once the device is included into
the network, the binding must interrogate it to find out what type of device
it is. One part of this process is to get the manufacturer information required
to identify the device, and until this is done, the device will remain unknown.
For mains powered devices, this will occur quickly, however for battery
devices the device must be woken up a number of times to allow the
discovery phase to complete. This must be performed with the device close
to the controller.
The unit is described here:
https://github.com/openhab/org.openhab.binding.zwave/blob/6170064fc207f0d07de9f5206a335c3f0fb31dd5/doc/thermofloor/heatIt4512666_0_0.md?plain=1#L3
Doesn’t that mean it is in the databse?
And I have waited for several days now for the discovery to finish. Nothing happens.
Any ideas?
