fex
(Felix)
June 27, 2021, 5:36pm
1
Hi guys,
I just wrote my first custom list widget - but somehow I’m seemingly unable to arrange icon, label, stepper and chevron similar to the oh-list-item ’s (icon & label arranged on the left side, stepper / chevron on the right side). Any hints?
My custom widget:
Default arrangement that I want to achieve:
Code
uid: radiator_list
tags:
- list
- radiator
props:
parameters:
- description: Widget Title
label: Title
required: false
type: TEXT
- context: item
description: Radiator Item Group
label: Group
required: false
type: TEXT
parameterGroups: []
timestamp: Jun 26, 2021, 3:49:43 PM
component: f7-list-item
slots:
default:
- component: f7-row
slots:
default:
- component: f7-icon
f7: thermometer
color: '=(Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 18) ? "blue" : (Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 21) ? "green" : (Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 23) ? "orange" : "red"'
- component: Label
text: =props.title
- component: oh-stepper
item: =props.prefix + "_SetTemperature"
min: 15
max: 23
step: 0.5
autorepeat: true
autorepeatDynamic: true
- component: oh-button
iconF7: chevron_right
action: sheet
actionModal: widget:radiator_popup
actionModalConfig:
title: =props.title
prefix: =props.prefix
I’m not using the default oh-stepper-item list widget since I’m using a stepper and a button ( > ) to open a widget with additional settings / info. You can add actions to the oh-stepper-item , but then every click on the stepper buttons also opens the popup…:
uid: radiator_popup
tags:
- popup
- radiator
props:
parameters:
- context: title
label: Title
required: false
type: TEXT
- context: prefix
label: Group
required: false
type: TEXT
parameterGroups: []
timestamp: Jun 26, 2021, 3:46:20 PM
component: oh-list-card
title: =props.title
slots:
default:
- component: oh-list-item
title: Aktuelle Temperatur
icon: f7:thermometer
iconColor: '=(Number.parseFloat(items[props.prefix + "_ActualTemperature"].state) < 18) ? "blue" : (Number.parseFloat(items[props.prefix + "_ActualTemperature"].state) < 21) ? "green" : (Number.parseFloat(items[props.prefix + "_ActualTemperature"].state) < 23) ? "orange" : "red"'
after: =items[props.prefix + "_ActualTemperature"].state
action: analyzer
- component: oh-stepper-item
title: Zieltemperatur
iconColor: '=(Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 18) ? "blue" : (Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 21) ? "green" : (Number.parseFloat(items[props.prefix + "_SetTemperature"].state) < 23) ? "orange" : "red"'
min: 15
max: 23
step: 0.5
autorepeat: true
title: Boostmode
icon: f7:flame
iconColor: '=(Number.parseFloat(items[props.prefix + "_BoostState"].state) > 0) ? "orange" : "blue"'
action: command
actionItem: =props.prefix + "_BoostMode"
actionCommand: ON
badge: '=(Number.parseFloat(items[props.prefix + "_BoostState"].state) > 0) ? "Verlängern" : "Starten"'
badgeColor: '=(Number.parseFloat(items[props.prefix + "_BoostState"].state) > 0) ? "red" : "green"'
noChevron: true
title: Restdauer Boostmode
icon: f7:clock
after: =items[props.prefix + "_BoostState"].state
visible: =(Number.parseFloat(items[props.prefix + "_BoostState"].state) > 0)
title: Signalstärke
icon: f7:chart_bar
iconColor: '=(items[props.prefix + "_SignalStrength"].state == "kein Signal") ? "red": "orange"'
after: =items[props.prefix + "_SignalStrength"].displayState
visible: =(Number.parseFloat(items[props.prefix + "_SignalStrength"].state) < 3)
title: Batterie schwach
icon: f7:battery_25
iconColor: red
visible: =(items[props.prefix + "_LowBattery"].state == "ON")
I have to say our new MainUI is a nice additional rabbit hole to spend some weeks
Edit:
JustinG
(JustinG)
June 27, 2021, 6:33pm
2
Yes, this is possible. The trick is that in order for an list item to accordion the parent to that list item must have the accordionList: true
setting. With the default list widgets you don’t actually have access to the list that is the parent of these items so you have to insert something in between. The oh-repeater
is a perfect candidate for this because it allows you to give the list item a parent that doesn’t interfere with the rendering of the list item as part of a list. You just have to make sure that the settings you give the repeater only run once (so that you don’t duplicate your list item) and then you just ignore the repeaters loop
variable in the actual list item widget.
Here’s the version I use for the default widgets for my window blinds. This renders a set of accordion buttons in based on the preset commands I have for the blinds.
uid: widget_blinds_default
tags:
- default
- blinds
props:
parameters:
- description: Label to show
label: Item Label
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Apr 1, 2021, 8:46:30 PM
component: oh-repeater
for: dummyVar
in:
- nothing: here
accordionList: true
slots:
default:
icon: oh:blinds
title: =props.Label
after: =items[props.item].displayState
slots:
accordion:
- component: oh-repeater
sourceType: itemCommandOptions
itemOptions: =props.item
fragment: true
for: option
slots:
default:
text: =loop.option.label
raised: true
action: command
actionItem: =props.item
actionCommand: =loop.option.command
fex
(Felix)
June 28, 2021, 5:58am
3
Oh, this is great. After some confusion why only the first collapsed list item would be shown (seems like accordions will only hide / show one item) and working around that one by adding a list ‘in between’, it actually works:
Collapsed:
Expanded:
Code:
uid: radiator_list_v2
tags:
- list
- radiator
props:
parameters:
label: Title
required: false
type: TEXT
- context: item
label: Group
required: false
type: TEXT
parameterGroups: []
timestamp: Jun 28, 2021, 7:46:09 AM
for: dummyVar
in:
- nothing: here
accordionList: true
slots:
default:
title: =props.title
min: 15
max: 23
step: 0.5
autorepeat: true
accordionItem: true
slots:
accordion:
mediaList: true
slots:
default:
action: analyzer
min: 15
max: 23
step: 0.5
autorepeat: true
title: Boostmode
icon: f7:flame
action: command
actionCommand: ON
noChevron: true
icon: f7:clock
title: Signalstärke
icon: f7:chart_bar
icon: f7:battery_25
iconColor: red
- component: f7-list-item
divider: true
title: Zieltemperatur bei Abwesenheit
subtitle: global - gilt für alle Räume
iconColor: '=(Number.parseFloat(items.HeatingAbsence_SetTemperature.state) < 18.5) ? "green" : "red"'
item: HeatingAbsence_SetTemperature
min: 15
max: 23
step: 0.5
autorepeat: true
title: Zieltemperatur Nachts
iconColor: '=(Number.parseFloat(items.HeatingNight_SetTemperature.state) < 18.5) ? "green" : "red"'
item: HeatingNight_SetTemperature
min: 15
max: 23
step: 0.5
autorepeat: true
Now I just have to find out how to move the stepper item in line with the title (first pic / collapsed view)
Any ideas?
JustinG
(JustinG)
June 28, 2021, 2:51pm
4
Odd. That appears to be a some bug with the stepper widget when the accordion chevron is drawn. You probably will have to make your base item a regular oh-list-item
and then add a oh-stepper
to the after
slot of that item.
for: dummyVar
in:
- nothing: here
accordionList: true
slots:
default:
title: =props.title
slots:
after:
min: 15
max: 23
step: 0.5
autorepeat: true
style:
padding-right: 10px
accordion:
mediaList: true
slots:
default:
#etc...etc
fex
(Felix)
June 28, 2021, 6:06pm
5
That works
EDIT: Nope, thats not a good solution. It looks like it should - but every click on the stepper now also expands / collapses the accordion item Bug or feature?
EDIT 2: And one additional problem - the first entry of the collapsable items, Aktuelle Temperatur should open the default analyzer widget - but it doesn’t. Any ideas why?
action: analyzer
JustinG
(JustinG)
June 29, 2021, 2:48am
6
Hmmm… that’s interesting. The expected behavior when a list item is an accordion is that clicking anywhere on the list item should trigger the expand/collapse. I had assumed that the extra widget would override that, not work in parallel. However, that appears to be the f7 behavior and not an OH bug. You may just not be able to accomplish both the stepper and the accordion in the same list item.
I don’t know if that’s the complete widget definition, but it looks like you are missing the actionAnalyzerItems
key.
fex
(Felix)
June 29, 2021, 5:47am
7
That would make sense - have to test it as soon as I’m back from work
fex
(Felix)
June 29, 2021, 5:09pm
8
Nope, neither actionAnalyzerItems
or actionAnalyzerCoordSystem
does fix the problem
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems: =props.prefix + "_ActualTemperature"
Mark_VG
(Mark)
June 29, 2021, 5:20pm
9
Have you tried:
actionAnalyzerItems: =items[props.prefix + "_ActualTemperature"]
fex
(Felix)
June 29, 2021, 5:24pm
10
Same result - nothing happens when I click on the list item.
Mark_VG
(Mark)
June 29, 2021, 6:50pm
11
In the working example I have the syntax looks like:
action: analyzer
- Partition3_Armed
Battling with the expression though
JustinG
(JustinG)
June 29, 2021, 7:27pm
12
actionAnalyzerItems requires an array. There are two ways to do that here:
- element 1
- element 2
- element 3
But as far as I know you won’t be able to use expression to dynamically generate item names that way. The other option is a single line array using brackets in an expression:
actionAnalyzerItems: =[element 1, element 2, element 3]
Because this is already an expression you can build whatever you need for each element, so in this case you want something like:
actionAnalyzerItems: =[props.prefix + "_ActualTemperature"]
fex
(Felix)
June 30, 2021, 5:57am
13
JustinG:
That does the trick
I know that feeling
So for now there is only one open problem How to bring accordionList
and oh-stepper
together in a way that:
everything is in the same row like this
but without interference between the stepper buttons and the expand/collapse action?
fex
(Felix)
July 7, 2021, 6:17pm
14
So my new idea is to discard the accordion list and to just set a switch to ON / OFF to decide if the additional settings / infos should be visible - see this topic .
