HELP! Someone Hacked my system? Lights and other turning on and off randomly. OH3 Snapshot
Help!!
something weird is happening.
From two days my lights in home goes on and off, sprinkler system also and camera settings.
here is part of log from today:
2020-12-06 00:36:57.331 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-pod-tv/switch/cmd
2020-12-06 00:36:57.998 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command OFF
2020-12-06 00:36:58.010 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become OFF
2020-12-06 00:36:58.022 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik1/switch/cmd
2020-12-06 00:36:58.762 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:36:58.776 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:36:58.786 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:36:59.295 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command OFF
2020-12-06 00:36:59.310 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become OFF
2020-12-06 00:36:59.321 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik2/switch2/cmd
2020-12-06 00:37:00.044 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampki_dom_switch' received command OFF
2020-12-06 00:37:00.064 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampki_dom_switch' predicted to become OFF
2020-12-06 00:37:00.074 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic cmnd/lampkidom/POWER
2020-12-06 00:37:00.079 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from ON to OFF through lampki_dom_switch
2020-12-06 00:37:23.223 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_tv_switch' received command ON
2020-12-06 00:37:23.235 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_tv_switch' predicted to become ON
2020-12-06 00:37:23.243 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from OFF to ON through lampa_tv_switch
2020-12-06 00:37:23.244 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-pod-tv/switch/cmd
2020-12-06 00:37:23.624 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command ON
2020-12-06 00:37:23.636 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become ON
2020-12-06 00:37:23.646 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik1/switch/cmd
2020-12-06 00:37:24.063 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wiatrolap_switch' received command ON
2020-12-06 00:37:24.072 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wiatrolap_switch' predicted to become ON
2020-12-06 00:37:24.083 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch1/cmd
2020-12-06 00:37:24.907 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command ON
2020-12-06 00:37:24.916 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become ON
2020-12-06 00:37:24.928 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-sofa/switch/cmd
2020-12-06 00:37:26.026 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command ON
2020-12-06 00:37:26.034 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become ON
2020-12-06 00:37:26.052 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch2/cmd
2020-12-06 00:37:26.091 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_przedpokoj_switch' received command ON
2020-12-06 00:37:26.100 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_przedpokoj_switch' predicted to become ON
2020-12-06 00:37:26.110 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic cmnd/wlacznik-przedpokoj/POWER1
2020-12-06 00:37:26.247 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampki_dom_switch' received command ON
2020-12-06 00:37:26.252 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampki_dom_switch' predicted to become ON
2020-12-06 00:37:26.260 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic cmnd/lampkidom/POWER
2020-12-06 00:37:28.376 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_gniazdko_dimmer' received command 100
2020-12-06 00:37:28.390 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_gniazdko_dimmer' predicted to become 100
2020-12-06 00:37:49.793 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'nawadnianie_obwod1' received command ON
2020-12-06 00:37:49.810 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'nawadnianie_obwod1' predicted to become ON
2020-12-06 00:37:49.824 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /nawadnianie/switch1/cmd
2020-12-06 00:37:49.826 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych_zraszacze' changed from OFF to ON through nawadnianie_obwod1
2020-12-06 00:37:50.214 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'nawadnianie_obwod3' received command ON
2020-12-06 00:37:50.234 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'nawadnianie_obwod3' predicted to become ON
2020-12-06 00:37:50.257 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /nawadnianie/switch3/cmd
2020-12-06 00:37:51.013 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'nawadnianie_obwod2' received command ON
2020-12-06 00:37:51.028 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'nawadnianie_obwod2' predicted to become ON
2020-12-06 00:37:51.039 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /nawadnianie/switch2/cmd
2020-12-06 00:37:51.549 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'nawadnianie_obwod4' received command ON
2020-12-06 00:37:51.570 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'nawadnianie_obwod4' predicted to become ON
2020-12-06 00:37:51.584 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /nawadnianie/switch4/cmd
2020-12-06 00:37:52.116 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'SprinklerCycle' received command ON
2020-12-06 00:38:00.586 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_tv_switch' received command OFF
2020-12-06 00:38:00.591 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_tv_switch' predicted to become OFF
2020-12-06 00:38:00.604 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-pod-tv/switch/cmd
2020-12-06 00:38:00.971 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command OFF
2020-12-06 00:38:00.979 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become OFF
2020-12-06 00:38:00.997 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik1/switch/cmd
2020-12-06 00:38:01.422 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wiatrolap_switch' received command OFF
2020-12-06 00:38:01.433 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wiatrolap_switch' predicted to become OFF
2020-12-06 00:38:01.445 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik2/switch1/cmd
2020-12-06 00:38:02.591 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command OFF
2020-12-06 00:38:02.599 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become OFF
2020-12-06 00:38:02.612 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik2/switch2/cmd
2020-12-06 00:38:02.872 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command ON
2020-12-06 00:38:02.887 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become ON
2020-12-06 00:38:02.892 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch2/cmd
2020-12-06 00:38:03.244 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:38:03.251 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:38:03.260 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:38:03.597 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command ON
2020-12-06 00:38:03.606 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become ON
2020-12-06 00:38:03.616 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch2/cmd
2020-12-06 00:38:03.929 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_przedpokoj_switch' received command OFF
2020-12-06 00:38:03.937 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_przedpokoj_switch' predicted to become OFF
2020-12-06 00:38:03.950 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic cmnd/wlacznik-przedpokoj/POWER1
2020-12-06 00:38:04.311 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_przedpokoj_switch' received command ON
2020-12-06 00:38:04.319 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_przedpokoj_switch' predicted to become ON
2020-12-06 00:38:04.334 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic cmnd/wlacznik-przedpokoj/POWER1
2020-12-06 00:38:04.736 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command OFF
2020-12-06 00:38:04.745 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become OFF
2020-12-06 00:38:04.761 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik2/switch2/cmd
2020-12-06 00:38:05.077 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_przedpokoj_switch' received command OFF
2020-12-06 00:38:05.086 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_przedpokoj_switch' predicted to become OFF
2020-12-06 00:38:05.098 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic cmnd/wlacznik-przedpokoj/POWER1
2020-12-06 00:38:05.710 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampki_dom_switch' received command OFF
2020-12-06 00:38:05.722 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampki_dom_switch' predicted to become OFF
2020-12-06 00:38:05.731 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from ON to OFF through lampki_dom_switch
2020-12-06 00:38:05.735 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic cmnd/lampkidom/POWER
2020-12-06 00:38:30.841 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command ON
2020-12-06 00:38:30.849 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become ON
2020-12-06 00:38:30.861 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik1/switch/cmd
2020-12-06 00:38:30.861 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from OFF to ON through lampa_wyspa_switch
2020-12-06 00:38:40.835 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command OFF
2020-12-06 00:38:40.843 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become OFF
2020-12-06 00:38:40.852 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from ON to OFF through lampa_wyspa_switch
2020-12-06 00:38:40.858 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik1/switch/cmd
2020-12-06 00:38:41.195 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command ON
2020-12-06 00:38:41.205 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become ON
2020-12-06 00:38:41.215 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from OFF to ON through lampa_wyspa_switch
2020-12-06 00:38:56.863 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command OFF
2020-12-06 00:38:56.870 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become OFF
2020-12-06 00:38:56.875 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from ON to OFF through lampa_wyspa_switch
2020-12-06 00:38:56.886 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik1/switch/cmd
2020-12-06 00:39:11.008 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_tv_switch' received command ON
2020-12-06 00:39:11.014 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_tv_switch' predicted to become ON
2020-12-06 00:39:11.018 [INFO ] [ome.event.GroupItemStateChangedEvent] - Item 'ile_wlaczonych' changed from OFF to ON through lampa_tv_switch
2020-12-06 00:39:11.021 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-pod-tv/switch/cmd
2020-12-06 00:39:11.519 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wyspa_switch' received command ON
2020-12-06 00:39:11.529 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wyspa_switch' predicted to become ON
2020-12-06 00:39:11.590 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik1/switch/cmd
2020-12-06 00:39:12.042 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wiatrolap_switch' received command ON
2020-12-06 00:39:12.047 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wiatrolap_switch' predicted to become ON
2020-12-06 00:39:12.054 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch1/cmd
2020-12-06 00:39:13.179 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command ON
2020-12-06 00:39:13.189 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become ON
2020-12-06 00:39:13.201 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-sofa/switch/cmd
2020-12-06 00:39:13.844 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wejscie_switch' received command ON
2020-12-06 00:39:13.850 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wejscie_switch' predicted to become ON
2020-12-06 00:39:13.861 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch2/cmd
2020-12-06 00:39:14.283 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_przedpokoj_switch' received command ON
2020-12-06 00:39:14.292 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_przedpokoj_switch' predicted to become ON
2020-12-06 00:39:14.306 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic cmnd/wlacznik-przedpokoj/POWER1
2020-12-06 00:39:14.701 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampki_dom_switch' received command ON
2020-12-06 00:39:14.712 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampki_dom_switch' predicted to become ON
2020-12-06 00:39:14.723 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic cmnd/lampkidom/POWER
2020-12-06 00:39:57.316 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'pompa_dane_status' received command ON
2020-12-06 00:39:57.334 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'pompa_dane_status' predicted to become ON
2020-12-06 00:39:57.345 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic panasonic_heat_pump/SetHeatpump
2020-12-06 00:40:11.665 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'pompa_dane_status' received command ON
2020-12-06 00:40:11.675 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'pompa_dane_status' predicted to become ON
2020-12-06 00:40:11.689 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic panasonic_heat_pump/SetHeatpump
2020-12-06 00:40:16.311 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'pompa_dane_tryb' received command 0
2020-12-06 00:40:16.320 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'pompa_dane_tryb' predicted to become 0
2020-12-06 00:40:56.894 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:40:56.903 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:40:56.918 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:41:04.363 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command ON
2020-12-06 00:41:04.382 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become ON
2020-12-06 00:41:04.391 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-sofa/switch/cmd
2020-12-06 00:41:14.065 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:41:14.075 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:41:14.085 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:41:21.349 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command ON
2020-12-06 00:41:21.365 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-sofa/switch/cmd
2020-12-06 00:41:21.368 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become ON
2020-12-06 00:41:35.249 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:41:35.258 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:41:35.310 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:42:12.594 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command ON
2020-12-06 00:42:12.605 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become ON
2020-12-06 00:42:12.616 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /lampa-sofa/switch/cmd
2020-12-06 00:42:13.316 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wiatrolap_switch' received command OFF
2020-12-06 00:42:13.333 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wiatrolap_switch' predicted to become OFF
2020-12-06 00:42:13.348 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /wlacznik2/switch1/cmd
2020-12-06 00:42:37.411 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_gniazdko_dimmer' received command 100
2020-12-06 00:42:37.427 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_gniazdko_dimmer' predicted to become 100
2020-12-06 00:42:38.289 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_wiatrolap_switch' received command ON
2020-12-06 00:42:38.299 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value ON to topic /wlacznik2/switch1/cmd
2020-12-06 00:42:38.301 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_wiatrolap_switch' predicted to become ON
2020-12-06 00:42:49.575 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'lampa_sofa_switch' received command OFF
2020-12-06 00:42:49.591 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value OFF to topic /lampa-sofa/switch/cmd
2020-12-06 00:42:49.592 [INFO ] [rthome.event.ItemStatePredictedEvent] - Item 'lampa_sofa_switch' predicted to become OFF
2020-12-06 00:43:21.037 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:21.071 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:22.168 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:22.183 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:22.378 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:22.395 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:22.558 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:22.573 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:22.749 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:22.766 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:22.926 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:22.943 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:23.108 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:23.129 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:23.304 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:23.320 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:23.529 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:23.545 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:23.913 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:23.930 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:24.073 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:24.088 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:24.301 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:24.317 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:24.505 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:24.522 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:24.694 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:24.710 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:24.934 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:24.951 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:25.095 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:25.108 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:25.515 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:25.533 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:25.750 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:25.768 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:25.922 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:25.936 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:26.146 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:26.160 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:26.329 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:26.345 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
2020-12-06 00:43:26.537 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'Cam02_Audio_Test' received command audio_test
2020-12-06 00:43:26.554 [DEBUG] [qtt.generic.AbstractMQTTThingHandler] - Successfully published value audio_test to topic myhome/dafang2/set
I didnt did any of this. WTF?!?!?! Someone hacked into my system and plays with my items?
Lights, sprinker system, camera play sound…
Have you done any port forwarding? By this I mean adding ports to open in your router/modem? When this happens, does turning off your modem or pulling the cable that gives you internet access stop the issue or does it continue? I would not be so quick to assume it is a hacker as it may be a bug or a rule not written correctly. Try changing from the snapshot to a milestone build.
What is your system platform? (without this info do not expect much help) How to ask a good question / Help Us Help You
What did you do two days ago?
What makes you think your system has been hacked?
Is it connected to the Internet?
If you really think this is true read
So first of all it happens after 03-04pm.
Yesterday when I was downstairs at midnight it started blinking lights like crazy, and as You se in logs it started to try to send voice signal to camera which is placed in this are where I was.
After over half hour it stopped and didn’t happened throu all night till now.
I have open few ports on router for openHAB.
My system is on rpi4. OpenHABian. Everything updated.
OpenHAB 3.0 latest snapshot.
I use Nginx which allows only user with password for connecting to openHAB.
In nginx I allow only connection to openHAB.
Strange is that almost overything of that things Turing on and off are Mqtt things. Only xiaomi dimmer is from from xiaomi binding.
I use groups for lights, sprinklers and camera
Settings. Maybe that’s the problem?
Only two Xiaomi cameras were on open ports without passwords.
So now I turned them off,
Changed openHAB password to very strong (set by apple keys).
I checked in other PC that without password I can’t get to openHAB, and change anything.
Rpi4 is on open port from outside but for ash and ftp You need password.
What did I do two days ago…
Updated to latest snapshot.
Updated whole rpi4 throu apt.
On latest snapshot I see that few rules are not working as they should.
But lights rules are working ok.
I see mqtt in your log. Is that driving this? If so, have a look at the log file of your mqtt broker.
Do You know where to find mqtt logs? I will check them
Well I don’t know your system. Are you using mosquitto as a broker?
Yes. Everything set by openhabian-config.
It was working over 2 years.
Month ago update to OH3.
But not everything of this turning on and off items are mqtt. Dimmer light is xiaomi binding. But it is in same group as other mqtt lights.
The logs might be in /var/log/mosquitto I don’t use openhabian myself. However I believe it forces you to use a password. Have a look at your logs.
I found something like this in log file:
2020-12-06 03:54:00.272 [WARN ] [ore.io.rest.auth.internal.AuthFilter] - Unauthorized API request: Error while processing JWT token
That means that someone tried to get into my system?
I have no idea. What log file is this?
I can’t speak to this. What did the mosquitto log files say?
there is nothing but client connections. and there are only connections from inside of net.
Dear Kamil
It might be a hacked system or just some kind of weird malfunction.
  • Check if there is any kind of processes out of openHAB that are consuming unuasual high memory / CPU.
  • Check if there are processes / services running of which you are sure they shouldn’t
I suspect that a hacker would not drive the operations of OH in such a way. i.e. it would be to obvious. Most of these kind are in the meaned to use the hijacked system for other purposes.
It took me about a week to find the source process
Regards
Stefan
You should never open ports let alone to devices with poorly updated firmware. openHAB has the Free cloud So you don’t need to open any ports.
This may not be relevant to your particular situation, but at one point I added a Zwave Steinel outdoor floodlight to my system and it caused all manner of “weird” behaviour with my OpenHab setup (other devices turning on, not responding to commands, etc). Once I removed it, everything else returned to normal. So, is it possible you added some new device that could be messing the rest up?
hmmm
I didnt add anything new, but one of my sonoff switch is reseting once in few days. maybe this time something else went wrong?
But strange is that whole day nothing happens. Only after dark.
I have one rule to turn on 3 lights after dark, ant turn off all lights after 1:00am. but newer had problems with it. And even if this is the problem that doesnt explain what is happening with other items.
