Hi all,
New to OpenHAB and the first thing I am trying is failing. Bind my LightwaveRF Lighwave Link.
My issue is VERY similar to:
Each time I Start the OpenHAB server I get:
2016-10-22 15:16:54.119 [INFO ] [.b.l.i.LightwaveRFSenderThread] - Ok message not received for 100,!F*p
, retrying again. Retry count 2
My config is:
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: IP[255.255.255.255]
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: ReceivePort[9761]
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Port[9760]
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Register On Startup[true]
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Delay [2000]
2016-10-22 15:16:51.071 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Timeout for Ok Messages [3000]
I have tried:
- Direct IP for the Link / Broadcast IP
- Swapping Tx/Rx ports
- Firewall is turned off on PC (Windows 10), that is currently hosting the server.
I’m running out of hair to pull out - suggestions lovingly received.
thanks
Gavin
