Some more information on this.
Server logs from openhab:
2016-02-26 10:16:49.028 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=VERSION] Room[null] Device[null] Serial[wifilink] Type[VERSION] Poll[-1] 2016-02-26 10:16:49.032 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_IP] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_IP] Poll[-1] 2016-02-26 10:16:49.035 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_DUSK_TIME] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_DUSK_TIME] Poll[-1] 2016-02-26 10:16:49.044 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_DAWN_TIME] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_DAWN_TIME] Poll[-1] 2016-02-26 10:16:49.047 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_UPTIME] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_UPTIME] Poll[-1] 2016-02-26 10:16:49.050 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_LONGITUDE] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_LONGITUDE] Poll[-1] 2016-02-26 10:16:49.053 [INFO ] [htwaveRfGenericBindingProvider] - ConfigString[serial=wifilink,type=WIFILINK_LATITUDE] Room[null] Device[null] Serial[wifilink] Type[WIFILINK_LATITUDE] Poll[-1] 2016-02-26 10:16:49.113 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: IP[192.168.1.102] 2016-02-26 10:16:49.116 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: ReceivePort[9761] 2016-02-26 10:16:49.118 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Port[9760] 2016-02-26 10:16:49.120 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Register On Startup[true] 2016-02-26 10:16:49.123 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Send Delay [2000] 2016-02-26 10:16:49.125 [INFO ] [.l.internal.LightwaveRfBinding] - LightwaveBinding: Timeout for Ok Messages [1000] 2016-02-26 10:16:49.152 [INFO ] [l.internal.LightwaveRfWifiLink] - Starting LightwaveRfWifiLink Connection 2016-02-26 10:16:50.179 [INFO ] [.b.l.i.LightwaveRfSenderThread] - Ok message not received for 100,!F*p, retrying again. Retry count 2 2016-02-26 10:16:53.777 [INFO ] [.b.l.i.LightwaveRfSenderThread] - Ok message not received for 100,!F*p, retrying again. Retry count 3 2016-02-26 10:16:56.780 [INFO ] [.b.l.i.LightwaveRfSenderThread] - Ok message not received for 100,!F*p, retrying again. Retry count 4 2016-02-26 10:17:00.793 [INFO ] [.b.l.i.LightwaveRfSenderThread] - Ok message not received for 100,!F*p, retrying again. Retry count 5 2016-02-26 10:17:03.796 [ERROR] [.b.l.i.LightwaveRfSenderThread] - Unable to send message 100,!F*p after 5 attemps giving up
UDP tcpdump at the same time
10:16:49.179032 IP (tos 0x0, ttl 64, id 47521, offset 0, flags [DF], proto UDP (17), length 37) 192.168.1.142.56113 > 192.168.1.102.9760: [udp sum ok] UDP, length 9 10:16:49.282427 IP (tos 0x0, ttl 100, id 39219, offset 0, flags [none], proto UDP (17), length 45) 192.168.1.102.9760 > 192.168.1.142.9761: [udp sum ok] UDP, length 17 10:16:52.776920 IP (tos 0x0, ttl 64, id 47845, offset 0, flags [DF], proto UDP (17), length 37) 192.168.1.142.56113 > 192.168.1.102.9760: [udp sum ok] UDP, length 9 10:16:52.880272 IP (tos 0x0, ttl 100, id 39221, offset 0, flags [none], proto UDP (17), length 45) 192.168.1.102.9760 > 192.168.1.142.9761: [udp sum ok] UDP, length 17 10:16:55.779793 IP (tos 0x0, ttl 64, id 48129, offset 0, flags [DF], proto UDP (17), length 37) 192.168.1.142.56113 > 192.168.1.102.9760: [udp sum ok] UDP, length 9 10:16:55.883156 IP (tos 0x0, ttl 100, id 39223, offset 0, flags [none], proto UDP (17), length 45) 192.168.1.102.9760 > 192.168.1.142.9761: [udp sum ok] UDP, length 17 10:16:59.792749 IP (tos 0x0, ttl 64, id 48370, offset 0, flags [DF], proto UDP (17), length 37) 192.168.1.142.56113 > 192.168.1.102.9760: [udp sum ok] UDP, length 9 10:16:59.896066 IP (tos 0x0, ttl 100, id 39225, offset 0, flags [none], proto UDP (17), length 45) 192.168.1.102.9760 > 192.168.1.142.9761: [udp sum ok] UDP, length 17 10:17:02.795683 IP (tos 0x0, ttl 64, id 48519, offset 0, flags [DF], proto UDP (17), length 37) 192.168.1.142.56113 > 192.168.1.102.9760: [udp sum ok] UDP, length 9 10:17:02.899096 IP (tos 0x0, ttl 100, id 39226, offset 0, flags [none], proto UDP (17), length 45) 192.168.1.102.9760 > 192.168.1.142.9761: [udp sum ok] UDP, length 17 10:17:03.046930 IP (tos 0x0, ttl 100, id 39227, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 255.255.255.255.9761: [udp sum ok] UDP, length 155 10:17:03.053428 IP (tos 0x0, ttl 100, id 39228, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 192.168.1.142.9761: [udp sum ok] UDP, length 155 10:17:18.150791 IP (tos 0x0, ttl 100, id 39234, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 255.255.255.255.9761: [udp sum ok] UDP, length 155 10:17:18.157298 IP (tos 0x0, ttl 100, id 39235, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 192.168.1.142.9761: [udp sum ok] UDP, length 155 10:17:33.255412 IP (tos 0x0, ttl 100, id 39239, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 255.255.255.255.9761: [udp sum ok] UDP, length 155 10:17:33.261924 IP (tos 0x0, ttl 100, id 39240, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 192.168.1.142.9761: [udp sum ok] UDP, length 155 10:17:48.359248 IP (tos 0x0, ttl 100, id 39246, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 255.255.255.255.9761: [udp sum ok] UDP, length 155 10:17:48.365739 IP (tos 0x0, ttl 100, id 39247, offset 0, flags [none], proto UDP (17), length 183) 192.168.1.102.4096 > 192.168.1.142.9761: [udp sum ok] UDP, length 155
