- It might successfully restart the Pi. 2. I’ve never experienced symptoms like yours. My Pi hardware failures have only been due to worn out/faulty SD cards or iffy power supplies.
Hi @watou
My setup is less than three months old
Brand new everything
Official rpi psu
Sandisk class 10 16gb sdhc a1
It’s doesn’t really matter, if you have corrupted a critical area of the SD card while unplugging
Ok I need too add a button first otherwise I will just be corrupting card after card
But is there no way too check the health of the card like you can with a standard Hdd and wouldent there be more symtoms the system does seem too run fine apart from this one thing
Would my card be uncorrupted if I format it? Don’t want too throw it away
No. But you can still format it and use it for semi-permanent storage of non critical stuff
It all boils down to your willingness to accept risk. If your SD card got corrupted because of a power outage then the SD card is probably just fine. The problem with power outages is how SD cards work (the following is a gross simplification but it illustrates the problem). There are blocks of storage space on an SD card. Each block may have parts of more than one file in it. When you change a file and save it, everything that is in that block gets moved to a new block with the changes made. If the RPi loses power while writing the new block then not only does the file being written to get lost but all of the other files in that block get lost. Thus even though the only thing being written is your log file you can mangle system critical files like config files or executables.
The SD wearing out problem is different. In this case (again, a gross simplification) each block on the SD card has a finite amount of writes that it will support. Once you exceed that number of writes the block will no longer store new data. To avoid wearing out parts of the SD card too fast, the OS will spread out the writes and load balance them across all the available blocks. That greatly extends the life of the SD card. However, if you have a write heavy application (persistence, lots of logging, etc) eventually you will run out and blocks will wear out. When they wear out we can see some of the same problems described above. The OS thinks that the data was written but the block was worn out so the changes didn’t actually get changed. And as described above, any other parts of files that were in that same block didn’t get written as well and we have corruption.
SD cards wearing out is probably far less common than assumed. But loss of power corruption is very common.
But here on the forum we usually don’t have enough information to know which caused the problem. So we tend to assume the worse and assume the SD card is worn out. But most likely your SD card is fine and just needs a reformat. But there is always the chance that the it is worn out. So you have to decide it if the cost of a new SD card is worth the risk of using an SD card that might be worn out.
Thanks for that rich
I’m going too look at making my system more stable and reliable I’m going too add a switch too reboot the rasberry when it’s not working properly if it even responds enough for that, I’m also planning on moving over too Amanda backup from the other method I’m using this will keep my backups in a more recent state than I currently have.
Will just see what happens there
Did you ever look into this for me ?
I forgot. I just created a rule:
rule "Test InfluxDB"
System started
logInfo("Test", "Max temp for last 28 days is " + vWeather_Temp.maximumSince(now.minusDays(28)).state.toString)
createTimer(now.plusMinutes(5), [ | logInfo("Test", "Max temp for last 28 days is " + vWeather_Temp.maximumSince(now.minusDays(28)).state.toString) ])
Every time I run it I get a reasonable value as a result. This value gets updated every couple of minutes so as I run it I sometimes get a slightly different value which reflects that the temp changed over these five minutes 28 days ago.
My most recent run showed:
Max temp for last 28 days is 81.8
Max temp for last 28 days is 81.6
// restart OH
But I’ve over a year’s worth of data in this database. Maybe there is something weird going on since you are querying way before you have data in your database.
Thanks for that rich no worries about forgetting im pretty prone to it myself
Maby you are right about that seems too work for you
i would like too get this right as i would also like too add max temp like you have just posted
All I can suggest is don’t use a time you know is greater than the amount of data you have in the database and see if you get a consistent value. If you only have 5 days of data, don’t use more than now.minusDays(5). That will show if the problem is you are searching past where you have data.
i will edit the rule
how can i find when the first entry is?
Thanks for that
I have followed instructions and checked when my earliest persistence update was added looks like it was on Tue Jul 17 2018 23:27:00 GMT+0100 (British Summer Time)
I also changed my rule too only check 10 days back and restarted my system it changed again so im not sure whats wrong here
Nice Little Tool
