Hi everyone hoping someone can fix one of my rules it used too work perfectly but stopped working quite awhile ago
it may have been when i updated too OH3 i remember some time based things needed editing
the rule starts but gives an error now instead of changing the lights too the state it was 7 days ago
TIA
rule "Sentry Mode All Lights"
Time cron " 0 0/1 * 1/1 * ? *" // Every 1 Min
if( Away_from_home.state == ON && DisableCentury.state == OFF ) {
if( SentryMode.state == ON ) {
logInfo("Sentry Mode Lights", "Changed lights to value of this time last week")
Ghouselights.members.forEach[light | light.sendCommand(light.historicState(now.minusDays(7)).state)]
2021-08-28 00:35:00.952 [INFO ] [core.model.script.Sentry Mode Lights] - Changed lights to value of this time last week
2021-08-28 00:35:00.957 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sentry Mode-2' failed: Could not invoke method: org.openhab.core.model.script.actions.BusEvent.sendCommand(org.openhab.core.items.Item,java.lang.String) on instance: null in Sentry Mode
That’s the part that isn’t working. Is light a real Item? Is persistence working? Is it returning something that can be used as a command?
Open it up and find out.
logInfo("Sentry Mode Lights", "Working with Item " + light.name)
var p = light.historicState(now.minusDays(7))
logInfo("Sentry Mode Lights", "Retrieved record {}", p)
light.sendCommand(p.state)]
Note that states are not commands, even if they look alike e.g. command ON is not state ON.
The simplest fix is usually just make sendCommand parse whatever it wants from a string light.sendCommand(p.state.toString)]
Hi again Rossko i have been working on other issues but have come back too try and fix this now I could really do with getting this running again either fix this rule or scrap it and implement it a new way
light isn’t an item its a call for the items that are part of the ghouselight group
//if( Away_from_home.state == ON && DisableCentury.state == OFF ) {
//Ghouselights.members.forEach[light | light.sendCommand(light.historicState(now.minusMinutes(1)).state)]
2022-01-17 16:55:00.491 [INFO ] [core.model.script.Sentry Mode Lights] - Working with Item KitchenMainLight1_Brightness
2022-01-17 16:55:00.496 [INFO ] [core.model.script.Sentry Mode Lights] - Retrieved record [FAILED toString()]
2022-01-17 16:55:00.496 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'SentryMode-2' failed: Could not invoke method: org.openhab.core.model.script.actions.BusEvent.sendCommand(org.openhab.core.items.Item,java.lang.String) on instance: null in SentryMode
This makes sense I had a feeling my persistence got damaged when I moved house items and things changed location’s names etc do you have any tips for troubleshooting the persistence?
I have my OH server running in hyper-v i have just took a snapshot so can run any commands or try anything you recommend if it doesn’t work can always restore the system too now
i have previously looked into the persistence thinking it was the issue but couldn’t find the problem and fix the issue
i added all the light items too a new group tried too run the rule with that same issue
deleted and reinstalled influx still the same so i came too a bit of a loss there
it was probably mistakes on my end so could do with some tips from someone more experienced
i’m running a few different persistence services influx,mapdb,rrd4j
It’s just a case of plodding through.
You’re requesting from default service - which is that? Have you configured what to store?
Use API explorer to see if it holds data for the Item.
Changing Item types will break it.
i dont know why this error was happening but it looks like theres not a problem with the persistence service
yes i didnt see the part you added on the end my bad sentry mode is now fixed 5 months later my bad again lol
thanks for your help on this and the other thing yesterday i would not have fixed these problems without your tips i really appretiate that
if( SentryMode.state == ON && DisableCentury.state == OFF ) {
logInfo("Sentry Mode", "Sentry Mode Ran Lights changed too historical state")
