Hi everyone i have been working on a status pannel for my setup its not going too plan what im trying too do is when a switch item changes to on it sends a text update to a string item
but some switch items are more important than others like test mode and it needs to be displayed if this is on no matter what else is on
some of my buttons work as expected and others not at all i have been trying to do this for days and input would be appretiated please ask if more info is needed
rule "System Status"
Item Away_from_home changed or
Item In_Bed changed or
Item Kids_Holiday_Mode_SCHOOL_HOLIDAY changed or
Item Weekend changed or
Item Test_Mode changed or
Item Movie_Mode_Enabled changed or
Item Disable_Amp_Rule changed or
Item Trigger_PowerOffLR changed or
Item Trigger_Tylers_TV changed
if( Away_from_home.state == OFF &&
In_Bed.state == OFF &&
Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == OFF &&
Weekend.state == OFF &&
Test_Mode.state == OFF &&
Movie_Mode_Enabled.state == OFF &&
Disable_Amp_Rule.state == OFF &&
Trigger_Tylers_TV.state == OFF &&
Trigger_PowerOffLR.state == OFF ) {
System_Status.sendCommand ("NORMAL")
if( Test_Mode.state == ON && //ITEM CHANGED TO DISPLAY
In_Bed.state == ON || // IF ANY OF THESE ARE ON SET TO ON AT THE SAME TIME DISPALY TO TEST MODE AS THESE ITEMS ARE LESS IMORTANT
Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == ON ||
Weekend.state == ON ||
Away_from_home.state == ON ||
Movie_Mode_Enabled.state == ON ||
Disable_Amp_Rule.state == ON ||
Trigger_Tylers_TV.state == ON ||
Trigger_PowerOffLR.state == ON ) {
System_Status.sendCommand ("TEST MODE")
if( Away_from_home.state == ON ) { // ITEM CHANGED TO DISPLAY
if( Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == ON || Weekend.state == ON ) { //IF ANY OF THESE ARE ON SET TO ON AT THE SAME TIME DISPALY TO TEST MODE AS THESE ITEMS ARE LESS IMORTANT
System_Status.sendCommand ("AWAY FROM HOME") //
} // SAME THEORY FOR ALL RULES BELOW
if( In_Bed.state == ON ) {
System_Status.sendCommand ("BEDTIME")
if( Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == ON && Weekend.state == ON) {
System_Status.sendCommand ("SCHOOL HOLIDAY")
if( Weekend.state == ON ) {
System_Status.sendCommand ("WEEKEND")
if( Movie_Mode_Enabled.state == ON ) {
System_Status.sendCommand ("MOVIE MODE")
if( Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == ON || Weekend.state == ON || Disable_Amp_Rule.state == ON ) {
if( Disable_Amp_Rule.state == ON ) {
System_Status.sendCommand ("AMP RULE DISABLED")
if( Trigger_Tylers_TV.state == ON ) {
System_Status.sendCommand ("KIDS SLEEP")
if( Kids_Holiday_Mode_SCHOOL_HOLIDAY.state == ON || Weekend.state == ON || Movie_Mode_Enabled.state == ON || Disable_Amp_Rule.state == ON ) {
if( Trigger_PowerOffLR.state == ON ) {
System_Status.sendCommand ("LR POWER OFF")
Weekend ON Shows weekend like it should turning on moviemode shows moviemode like it should because its more important than weekend but once you enable disable amp rule it shows amp disbled when it should say movie mode as movie mode is more important
(In_Bed.state == ON || // IF ANY OF THESE ARE ON SET TO ON AT THE SAME TIME DISPALY TO TEST MODE AS THESE ITEMS ARE LESS IMORTANT
Trigger_PowerOffLR.state == ON )) {
Thanks for the reply I have looked through the design patterns quite a few times now and before but this is the only approach to doing this that I can understand at the moment as my coding knowledge is very basic (although it’s improved drastically since I started this in Dec and didn’t know a single line of code)
I will edit the rule as you suggested without using the design pattern at the moment is that all y I u can see that’s wrong with it as you stated
I do edit all my rules as my knowledge advances one I understand more of the coding aspect I will be using the design patterns to cleanup and shorten my rules at a later date
I have got a huge list of things I still need to do alot of its beyond my ability atm
In your case, the && in your condition was get evaluated first between the two members and then all the ||. So you need to put all the || between () to get evaluated as one boolean and then the && will be evaluated.
Keep your list but don’t bite more than you can chew. If you feel that you can’t tackle a particular project then you are probably right. Try to break it down it small parts and then tackle these one by one. Best way to learn is by doing it yourself.
Good luck, enjoy and break things. The best fun is fixing them!!
I couldent agree more Openhab is extremely complicated, fun, rewarding project/hobby I have ever started its just helpful to have some input sometimes I can see me working on this for the rest of my life and I’m only 26 lol
I bet nearly everyone here has a list of things they want too add too openhab
I think I understand what you mean it was only comparing the values of the first two items I will try to fix that and post an update
I will be keeping the list i always reorder it into current next and future jobs I change them according to my skill level if I have learned something new that helps with a task I move it up the list complete it and mark it off
@opus
Not quite, if they are all OFF (unlikely but you never know) then the if statement will return false. So the conditional check is probably not the right one
However, you are right. If Test_Mode is ON then @Sharpy it doesn’t matter what the other states are, doesn’t it?
Correct,I didn’t want to rewrite your whole rule.
You need to “leave” the rule after an If-statement went into the TRUE branch instead of doing all checks one after the other.
There are several ways to kill that cat, nested if Statements or select case Statements.
To kill a cat is easy.
Writing rules for OH is more like skinning a cat!!
Ok, let’s simplify things one by one
Put all these items is a group:
Group:Switch:OR(ON,OFF) gStatus
First part of your rule becomes:
Member of gStatus changed
if(gStatus.state == OFF) {
return;
if(Test_Mode.state == ON {
return;
I suppose this needs to be at the top of the rule so it gets checked first and ends the rule before it gets to anything else then it wouldent matter what turned on while testmode was on because the return in the rule would end the rule before it got too check stuff like weekend and everything else
What would you do for the rest of the items in the rule write them how I wrote them in the first post?
