I’m Randi and I’m new to OpenHAB. I need help with my project.
I’m trying to make a Home Automation Full Simulation using some program as I mentioned above. I’m using modbus binding from @ssalonen in Modbus openHAB2 binding available for alpha testing. PLC that I will be using is modicon M221.
Here is my TwidoSuite Program Report :
doc2.pdf (1019.3 KB)
Here for the openHAB stuff :
modtest.things
Bridge modbus:tcp:localhostTCP [ host="192.168.0.105", port=502, id=1 ]{
Bridge poller coils [ start=0, length=2, refresh=1000, type="coil" ]
Thing data internalrelay [ readStart="0", readValueType="uint16" ]
Thing data light1on [ readStart="1", readValueType="bit" ]
Bridge poller coils [start=2, length=1, refresh=1000, type="coil" ]
Thing data terminalroom1on [ readStart="2", readValueType="bit", writeStart="2", writeValueType="bit", writeType="coil" ]
Bridge poller coils [start=3, length=2, refresh=1000, type="coil" ]
Thing data bathroom1on [ readStart="3", readValueType="bit" ]
Thing data light2on [ readStart="4", readValueType="bit" ]
Bridge poller coils [start=5, length=1, refresh=1000, type="coil" ]
Thing data terminalroom2on [ readStart="5", readValueType="bit", writeStart="5", writeValueType="bit", writeType="coil" ]
Bridge poller coils [start=6, length=2, refresh=1000, type="coil" ]
Thing data bathroom2on [ readStart="6", readValueType="bit" ]
Thing data light3on [ readStart="7", readValueType="bit" ]
Bridge poller coils [start=8, length=1, refresh=1000, type="coil" ]
Thing data terminalroom3on [ readStart="8", readValueType="bit", writeStart="8", writeValueType="bit", writeType="coil" ]
Bridge poller coils [start=9, length=1, refresh=1000, type="coil" ]
Thing data bathroom3on [ readStart="9", readValueType="bit" ]
Bridge poller holding [ start=0000, length=1, refresh=1000, type="holding" ]
Thing data uilight1 [ readStart="0000", readValueType="uint16", writeStart="0000", writeValueType="uint16", writeType="holding" ]
Bridge poller holding [ start=0002, length=1, refresh=1000, type="holding" ]
Thing data uibathroom1 [ readStart="0002", readValueType="uint16", writeStart="0002", writeValueType="uint16", writeType="holding" ]
Bridge poller holding [ start=0004, length=1, refresh=1000, type="holding" ]
Thing data uilight2 [ readStart="0004", readValueType="uint16", writeStart="0004", writeValueType="uint16", writeType="holding" ]
Bridge poller holding [ start=0006, length=1, refresh=1000, type="holding" ]
Thing data uibathroom2 [ readStart="0006", readValueType="uint16", writeStart="0006", writeValueType="uint16", writeType="holding" ]
Bridge poller holding [ start=0008, length=1, refresh=1000, type="holding" ]
Thing data uilight3 [ readStart="0008", readValueType="uint16", writeStart="0008", writeValueType="uint16", writeType="holding" ]
Bridge poller holding [ start=0010, length=1, refresh=1000, type="holding" ]
Thing data uibathroom3 [ readStart="0010", readValueType="uint16", writeStart="0010", writeValueType="uint16", writeType="holding" ]
Thing data uilight1lo [ readStart="0000.0", readValueType="uint8" ]
Thing data uilight1hi [ readStart="0000.1", readValueType="uint8" ]
Thing data uibathroom1lo [ readStart="0002.0", readValueType="uint8" ]
Thing data uibathroom1hi [ readStart="0002.1", readValueType="uint8" ]
Thing data uilight2lo [ readStart="0004.0", readValueType="uint8" ]
Thing data uilight2hi [ readStart="0004.1", readValueType="uint8" ]
Thing data uibathroom2lo [ readStart="0006.0", readValueType="uint8" ]
Thing data uibathroom2hi [ readStart="0006.1", readValueType="uint8" ]
Thing data uilight3lo [ readStart="0008.0", readValueType="uint8" ]
Thing data uilight3hi [ readStart="0008.1", readValueType="uint8" ]
Thing data uibathroom3lo [ readStart="0010.0", readValueType="uint8" ]
Thing data uibathroom3hi [ readStart="0010.1", readValueType="uint8" ]
modtest.items
Group Room1
Group Room2
Group Room3
Switch internalrelay "Internal Relay [%d]" <energy> { channel="modbus:data:localhostTCP:coils:internalrelay:switch" }
Switch terminalroom1on "Terminal Room 1 [%d]" (Room1) { channel="modbus:data:localhostTCP:coils:terminalroom1on:switch" }
Switch terminalroom2on "Terminal Room 2 [%d]" (Room2) { channel="modbus:data:localhostTCP:coils:terminalroom2on:switch" }
Switch terminalroom3on "Terminal Room 3 [%d]" (Room3) { channel="modbus:data:localhostTCP:coils:terminalroom3on:switch" }
Switch uilight1 "Light Room 1 [%d]" <light> (Room1) { channel="modbus:data:localhostTCP:holding:uilight1:switch" }
Switch uibathroom1 "Light Bathroom 1 [%d]" <bath> (Room1) { channel="modbus:data:localhostTCP:holding:uibathroom1:switch" }
Switch uilight2 "Light Room 2 [%d]" <light> (Room2) { channel="modbus:data:localhostTCP:holding:uilight2:switch" }
Switch uibathroom2 "Light Bathroom 2[%d]" <bath> (Room2) { channel="modbus:data:localhostTCP:holding:uibathroom2:switch" }
Switch uilight3 "Light Room 3 [%d]" <light> (Room3) { channel="modbus:data:localhostTCP:holding:uilight3:switch" }
Switch uibathroom3 "Light Bathroom 3 [%d]" <bath> (Room3) { channel="modbus:data:localhostTCP:holding:uibathroom3:switch" }
modtest.sitemap
sitemap modtest label="modtest"
Frame {
Switch item=internalrelay
Group item=Room1 label="Room 1" icon="bedroom"
Group item=Room2 label="Room 2" icon="bedroom"
Group item=Room3 label="Room 3" icon="bedroom"
Here for TeslaScada UI (sorry I can’t attach my TeslaScada files bcs it’s not supported
In this project, OpenHAB will act as Interface for the Cloud Control and TeslaScada as the Manual Switch Interface to replace the house miniature.
There is some question I want ask :
- About my addressing for coils and holding register in the things coding, is there any mistake ?
- Can anybody give me some clue about configuration in the modbus.cfg ? I don’t really get about that
- Is there another bindings I should use for this project ?
Sorry for my bad english and grammar. I hope you can understand what I mean ![]()
Thank you so much
