Thanks @TommySharp. It might be worth looking for some larger tablets, especially for wall placement. I have Nexus 7 (not mounted) and while it larger than the phone it is not as roomy as some 10" screenshots other people posted. Just a suggestion
Yeah the Nexus 9 would be super cool! Though with so much real estate it would be begging for charts
Iāve bought a Nexus 7 (2012) on ebay for 50 Euro and wall mounted it. Indeed there could be more space for widgets, but I didnāt want to have a 10" monster on the wall. Since the display has 1280x800 its ok for several widgets.
Also Rotinis slide left/right feature to move to the next tab is neat. So I dont have any concerns about too less space on the screen.
BR
Hi, why does the app need access to the microphone?
It is for voice commands
Hello
Any plans for adapting your sonos music player to work with the openhab Denon binding?
What is missing is that the denon binding do not have a play pause setting since it is only an receiver. However it could be adapted to work with a Favorite setting instead.
This could maybe work
Switch item=DenonCommand label=" " icon="favorite" mappings=[ZMFAVORITE1="Fav 1", ZMFAVORITE2="Fav 2", ZMFAVORITE3="Fav 3"]
Thank you again.
I was also going to ask if some Squeezebox integration was on the roadmap for us poor people without sonos speakers
I will check out the Denon binding.
Btw, music widget wasnāt intended for Sonos directly (I donāt even have Sonos system ), it is just naturally a good example for music player.
What is the issue with using Squeezebox with current music widget? I looked at it a bit, and it seems to have correct data.
Haha, the example had sonos stuff so I just assumed you had to have a sonos speaker⦠Will try set it up for my squeezebox speakers!
I am using music widget with my squeezeboxes. All works well.
@marklavercombe
Awesome, could I be lazy and ask to see what it looks like in your sitemap???
Okay Iāve got it sort of working but am finding that if I pause/play the music via some other means then the state in Rotini is not up dated. Iām guessing this is related to a few mentions of items not being updated properly in Rotini with OpenHAB 1.x?
Hi Igor, this widget below for my garage door used to work until I upgraded last night. I get an Invalid Config error saying the state of āCLOSEDā is not valid.
Iām guessing youāre doing some changes on this widget?
Frame label=āGarage 1 {widget:garage-door}ā {
Switch item=Contact_B_GarageDoor1
FYI - This is still an issue on my HTC M7 - the widget state/text is partially cut off at the bottom.
@TommySharp I responded in github
Iāve got it setup to control one of my squeezeboxes and it sort of works⦠The first issue I notice is that if I press PLAY in Rotini then the music starts playing. If I then stop the music using the squeezebox controller then the status is not updated in Rotini⦠Iāll have to have a bit more of a play around.
@igor
Does the background image option refresh after a certain time?
Iām trying to see if I can have a dynamic background based on the current CommonID of the weather binding in OpenHAB.
Iāve actually got a String item updating nicely with a URL to the appropriate image but I thought Iād just check to see how often Rotini might check to see if the background has changedā¦
So cool! I now have dynamcc backdrops showing based on the current weather⦠Both in Landscape and Portraitā¦
So now I need to waste a few hours gathering some images for all the different weather conditions Itās working for āsunnyā and āclearā at the moment.
These are my OpenHAB itemsā¦
String WTH_CommonId "Common id [%s]" (Weather){weather="locationId=home, type=condition, property=commonId"} String WTH_CommonIdImageURL1 "Common id [%s]" (Weather) String WTH_CommonIdImageURL2 "Common id [%s]" (Weather)
The WTH_CommonId is updated by the weather binding.
Then I have this in my rulesā¦
rule āGenerate image URL for latest weather conditionā
Item WTH_CommonId changed
postUpdate(WTH_CommonIdImageURL1, āhttp://192.168.1.90:8080/images/weather/ā + (āā + WTH_CommonId.state) + ā_landscape.jpgā)
postUpdate(WTH_CommonIdImageURL2, āhttp://192.168.1.90:8080/images/weather/ā + (āā + WTH_CommonId.state) + ā_portrait.jpgā)
On my OpenHAB server I have a āweatherā folder with the images.
And then this is at the top of my sitemapā¦
Text item=WTH_CommonIdImageURL1 label=ā{item:backdrop-landscape}ā
Text item=WTH_CommonIdImageURL2 label=ā{item:backdrop-portrait}ā
I probably still need to work out if the sitemap backdrop will refresh in the Rotini app after x amount of time⦠Hopefully it does!
UPDATE Doh⦠the weather has just changed to partly cloudy and the weather widget is showing the new icon for partly cloudy but my backdrop did not change⦠Changed my phone to portrait and then it grabbed the latest backdrop⦠Will have to see if @igor can work in some sort of backdrop refresh if the dynamic URL changesā¦
That is very cool Tommy!
+1 @TommySharp , and thanks for sharing!
