Hey there,
after painfull but goldenhours diving in openhab i came to the point to integrate homekit.
I have a little problem with my Dect 301 thermostates. This Thermostates support 5 stats (off,boost,eco,comfort,on(manual).
As I know, homekit thermostats support off, heat, cool, auto, on.
So, i did a rule to replace the Strings.
.items
/* Thermostate */
Group F2_thermostat_kueche_hk "Heizung Küche" (F2_room_kueche_hk) [ "Thermostat" ]
Number F2_thermostat_kueche_TEMP_hk "Temperatur" (F2_room_bad_hk,F2_thermostat_kueche_hk) [ "CurrentTemperature" ] ...
Number F2_thermostat_kueche_SOLL_hk "Temperatur Soll" (F2_room_bad_hk,F2_thermostat_kueche_hk) [ "TargetTemperature" ] ...
String F2_thermostat_kueche_HKS_hk "Temperatur Modus" (F2_room_bad_hk,F2_thermostat_kueche_hk)
.rules
rule "Thermostat Informationen Homekit Bad"
Item F2_thermostat_bad_HKS_hk changed
var String thermostat_bad_HKS_hk = F2_thermostat_bad_HKS_hk.state.toString
thermostat_bad_HKS_hk = thermostat_bad_HKS_hk.replace("COMFORT","auto")
thermostat_bad_HKS_hk = thermostat_bad_HKS_hk.replace("BOOST","heat")
thermostat_bad_HKS_hk = thermostat_bad_HKS_hk.replace("ECO","cool")
thermostat_bad_HKS_hk = thermostat_bad_HKS_hk.replace("OFF","off")
F2_thermostat_bad_HKS_hk.postUpdate(thermostat_bad_HKS_hk.toString)
The Thermostat is importing in Home, shows actual and set Temp. But wenn I chose a mode, it goes to “no responding”
In the log an entry appears.
2018-10-29 18:50:42.020 [ERROR] [al.accessories.HomekitThermostatImpl] - Unrecognized heating cooling target mode: cool. Expected cool, heat, auto, or off strings in value.
So what? I am wrong or do i have a logical fail in my head?
Thanks ![]()
