I own the beautiful Spirit thermostat (ZWave Thing | openHAB) and I would like to set the temperature via Echo/Google Assistant voice commands. I found those recommendations from the Echo binding thread:
… and from Homekit binding:
What is the relation between the 13 modes the thermostat is able to run (see device page above) and the “homekit:HeatingCoolingMode” setting?
And how will I use it? Will the user call these Homekit modes (how?) and I should translate it to the corresponding operation mode of my valve? Or what is the exact approach? Maybe someone has an example?
I’ve started using node red to control ny thermostats. That works pretty well. Currently I only use the setpoint part. But I have plans to implement the option to turn them on and off as well. I can post a screenshot later tonight if you want?
I tried to get an overview. Must people follow the approach you proposed - @Celaeno1, thanks again!
However, others modify a file called homekit.cfg, see [SOLVED] Configure Google Home with Homatic Thermostat. But I don’t know if the file would be considered as I did not install the Homekit binding (I am on Android).
Another approach seems to be to create a map file to “translate” from Homekit’s strings to the strings describing the valve mode. Not sure if this would allow me to avoid writing a rule? See [SOLVED] MAP function or oder to connect Max! Thermostat "Mode" to Dummy item for Google Home interaction - in this example, map files and rules are used where I would prefer to use only the first and avoid the latter. Would that work?
It’s up to you. I think you have a sitemap, too. There are mapped items. And you need a rule anyway. Choose the solution you feel most comfortable with.
I got it running. But I would like to switch the valve to the certain modes (Auto, off, …).
What is the voice command to switch the HeatingCoolingMode? Thanks.
“Alexa, turn the heating to 22 degrees” - > “Thermostat heating is set to 22 degrees”
“Alexa, switch the heating off” → “Thermostat heating does not support this”
(from German)
