Homematic and Jeelink (prevent hotspots)
after configuring Jeelink (Weather Station) and Homegear (Heatingcontroll) i see all devices in PaperUI. In FHEM it was possible to connect both devices to avoid a hotspot behind the couch. In OpenHab i cannot set this value.
Using Openhab2.2.0-1 on openhabien on RPi 3.
Don’t know what to try next… maybe someone can help me :slight_smile:
You can’t do that with openHAB. AFAIK, FHEM is emulating an Homematic temperature sensor and is also faking a direct link between the virtual temp sensor and the real wall radiator.
AFAIK, there is no such virtual device layer outside of FHEM.
so there is nothing i can do? Maybe a rule with manuel value-control?
Have a look here.
But have in mind Homematic <> HomematicIP.
If you have specific questions feel free to ask.
