I have one HM-LC-Dim1T-FM (Dimmer) in my OH2-System and configured it with a switch On/Off and a slider.
Both are working exept that ON always goes to 100% Dimm-Value. This is different to the behaviour in Homematic where last dimm value is stored. Is it possible to implement this as well? @gerrieg?
Sure, i can implement a virtual datapoint (channel) with the function. But it’s independent of the setting in the CCU/device, the setting is also not persistent, it must be set after each binding/openhab restart.
I’ll think about it…
