I have the following MQTT structure, and the item shows up in the Inbox.
Yet, after adding the thing and linking Items, the values are all NaN.
Is the structure missing anything?
Also, AFAIK OH2.4 used to show “BLEIO canvas” as name, now it just shows the topic id…
My homie items are read correctly, only thing which is changed from 2.4 is I believe heartbeat which was removed from next rls of homie if I recon correctly.
So most probably you have an slight error somewhere, do check it on homie website.
just practical note:
I do recommend to set it manually via files as this turned to be much more reliable than via paperUI. I’ve experienced issues when thing went offline or broker went offline, paperui autodiscovered things have had difficulties afterwards. Since I’ve changed everything to files, I’m running smoothly ever since
I have my own homie implementation that OH doesn’t like. No one has ever helped in stating what payloads are key or even used. Given the state of MQTT in OH2.5M1 I’ve stopped trying to get it to to work and always just assumed it’s broken. I’ve either had an unsupportive, dismissive or await next milestone fix response .. but it is still broken even now.
I’ve already spent too much time on homie3 trying to fix my end, when maybe it’s not broken. I don’t like homie3 and I’m now really a bystander until it stabilises. Then I might try again.
.. forgive me if I remain skeptical .. not that my homie implementation is flawed, it may be - but that homie works fine for you in 2.4 (or even 2.5M1). I am sure it is broken in both, especially 2.4
The validator was broken for me the last time I tried it (a couple of weeks ago), it indeed crashes on a perfectly valid homie device according to the spec. Not sure how it ever saw the light of day to be honest.
I would await 2.5M2 and try again assuming you’re willing to run 2.5. I don’t think the patches you want exist.
Part of the problem is that homie is so untested , OH being the only real application consuming it. It’s hard to know what and where any issues are.
There are a couple of other applications now on Athom Homey and Hubitat Elevation that support homie discovery and they work quite well together but they were written and tested to do that. Hopefully OH will become ‘the’ viable homie test device soon.
Daniel.. you don’t have an MQTT Explorer screenshot of your topic tree fully expanded do you. It’s much easier to interpret.
Or thinking … just publish to a public broker and I can connect to same for discovery and see if Homey or Elevation accept it. But they will be less stringent than OH I’m sure.
Some MQTT fixes (3 PR) were merged today, including homie bugs. Maybe try with the next snapshot and report back what is missing. There are still some issues on my list, but we can see if it already improved.
If you can point me to a complete (and correct) homie setup, I can try to see why the OH binding is not properly using it.
