How do you add the hue motion sensor too OH (SOLVED)
im thinking about adding my Hue Motion Sensor to OH im mainly interested in the temp readings but might aswell have ago at just adding it all
all help appreciated i haven’t got a clue all links , help ,chat
whats the basic process
i have not created any item files or sitemaps yet im still new too this so as much detail as possible
TIA
Hi Aaron,
Have a look over there
thanks for the link i have followed it to the best of my ability, im unsure what any of the files do im getting this error now
19:36:28.132 [ERROR] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getHueMotionEvent.js)' threw an exception. [response=[{"error":{"type":3,"address":"/sensors/3","description":"resource, /sensors/3, not available"}}]]
org.openhab.core.transform.TransformationException: An error occurred while executing script.
        at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:62)[190:org.openhab.core.compat1x:2.1.0]
        at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:189)[219:org.openhab.binding.http:1.10.0]
        at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:157)[190:org.openhab.core.compat1x:2.1.0]
        at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169)[190:org.openhab.core.compat1x:2.1.0]
You first have to check if the ID 3 is the correct one for your sensor. This differs in every setup. How it works see Philips Hue Motion Sensor OpenHAB2 - #2 by StefanH.
thanks i will have alook through there
Thanks for that i have managed too add both of my sensors now both the Motion and Temps are added im now receiving a different error
posted in this thread
the error is
22:29:00.255 [ERROR] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getHueDark.js)' threw an exception. [response={"state":{"daylight":null,"lastupdated":"none"},"config":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Philips","swversion":"1.0"}]
org.openhab.core.transform.TransformationException: An error occurred while loading script.
I think its because i only have the two scripts from a different post no script called JS(getHueDark.js) any ideas
Yes, that’s exactly what the error message tells you. I suggest to create the getHueDark.js script in your transform/ folder and put the desired logic inside.
Hi there
I got the same error but i cant get it working. The errors are on every Sensor idlike to get. i already checked if the Sensors (2/3/4) are working and matching my programming. Aswell i can access the Sensor with my Userpass and the IP provided. What am i missing?
I followed the tutorial and rechecked it twice now.
Binding configuration of type ‘http’ of item ‘GF_Stairwell_HueTemp’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig ‘http://192.168.20.166/api/qW8YTbOAFY********************BHe-rRjof/sensors/2:30000:JS(getHueTemperature.js)]’ doesn’t contain a valid binding configuration
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:51) [211:org.openhab.core.compat1x:2.2.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:294) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.addBindingConfigReader(GenericItemProvider.java:131) [135:org.eclipse.smarthome.model.item:0.10.0.b1]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:658) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:372) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:999) [?:?]
at org.openhab.core.binding.internal.BindingConfigReaderFactory.registerDelegateService(BindingConfigReaderFactory.java:70) [211:org.openhab.core.compat1x:2.2.0]
at org.openhab.core.binding.internal.BindingConfigReaderFactory.activate(BindingConfigReaderFactory.java:38) [211:org.openhab.core.compat1x:2.2.0]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-04-02 12:19:37.011 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘http’ of item ‘GF_Stairwell_HueMotion’ could not be parsed correctly.
Hi Reto,
did you install all needed bundles? E.g. the HTTP binding and the JavaScript transformation?
Hi Christoph
Yeah. HTTP Binding and JavaScript Trans is installed. JSON aswell.
Could it be a problem, that the HUE Bridge was discovered automaticly without any “Item” Binding? As i Said username with link works. Bulbs working perfectly but the Sensor is a pain :frowning:
Ok, can you please post your complete item and service configuration (*.items and http.cfg files)?
Number GF_Stairwell_HueTemp “Temperatur Sensor [%.2f °C]” { http=“http://192.168.20.166/api/qW8#######1PPwSRtECbidbxBHe-rRjof/sensors/2:30000:JS(getHueTemperature.js)]” }
Switch GF_Stairwell_HueMotion “Bewegungssensor [MAP(home.map):%s]” { http=“http://192.168.20.166/api/qW8Y#########OlMZdz1PPwSRtECbidbxBHe-rRjof/sensors/3:30000:JS(getHueMotion.js)]” }
Number GF_Stairwell_MotionLight “Lichtstärke [%.0f]” { http=“http://192.168.20.166/api/qW8YTb#######dz1PPwSRtECbidbxBHe-rRjof/sensors/4:30000:JS(getHueLight.js)]” }
Number GF_Stairwell_HueBattery “Batterie [%.0f %%]” { http=“http://192.168.20.166/api/qW8Y##############wSRtECbidbxBHe-rRjof/sensors/5:30000:JS(getHueBattery.js)]” }
Battery:
(function(i) {
var json = JSON.parse(i);
return parseInt(json[“config”][“battery”]);
})(input)
light:
(function(i) {
return Math.pow(10, (parseInt(json[“state”][“lightlevel”]) - 1) / 10000);
})(input)
Motion:
(function(i) {
return (json[“state”][“dark”]) == true ? “ON” : “OFF”;
})(input)
Temperature:
(function(i) {
return parseFloat(json[“state”][“temperature”]) / 100;
})(input)
http.cfg is empty.
There is a closing bracket at the end of each item - directly after the JS part - which doesn’t belong there. Please remove them.
Number GF_Stairwell_HueTemp “Temperatur Sensor [%.2f °C]” { http=“http://192.168.20.166/api/qW8#######1PPwSRtECbidbxBHe-rRjof/sensors/2:30000:JS(getHueTemperature.js)” }
May I ask you to use code fences the next time? To provide better readability.
Thanks for the help
I just restartet the Openhab Server but sadly, i got still the same errors.
Sorry about the code.
It still cant parse
2018-04-02 17:30:12.791 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getHueLastChange.js)' threw an exception. [response={"state":{"temperature":1687,"lastupdated":"2018-04-02T15:29:41"},"swupdate":{"state":"noupdates","lastinstall":null},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"pending":[]},"name":"Hue temperature sensor 1","type":"ZLLTemperature","modelid":"SML001","manufacturername":"Philips","productname":"Hue temperature sensor","swversion":"6.1.0.18912","uniqueid":"00:17:88:01:03:28:82:92-02-0402","capabilities":{"certified":true}}]
	at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) [211:org.openhab.core.compat1x:2.2.0]
	at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:194) [219:org.openhab.binding.http:1.11.0]
	at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144) [211:org.openhab.core.compat1x:2.2.0]
	at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166) [211:org.openhab.core.compat1x:2.2.0]
2018-04-02 17:30:13.812 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getHueLastChange.js)' threw an exception. [response={"state":{"temperature":1687,"lastupdated":"2018-04-02T15:29:41"},"swupdate":{"state":"noupdates","lastinstall":null},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"pending":[]},"name":"Hue temperature sensor 1","type":"ZLLTemperature","modelid":"SML001","manufacturername":"Philips","productname":"Hue temperature sensor","swversion":"6.1.0.18912","uniqueid":"00:17:88:01:03:28:82:92-02-0402","capabilities":{"certified":true}}]
Thats what i get when i run your script with the config seperated in http.cfg and items
Edit
fuck its working. I guess the warning/error is because there wasnt any “past Temperature”
Hey there again. Everything still working.
One more question. I had to reset the Hue Bridge coz 1 buld wouldnt get recognized after i deleted it (not a Hue Bulb)
And after the Reset i added 4 Sensors.
Can anyone tell me how i do know, wich Temperature Sensor belongs to wich Motion Sensor? The Problem is, only on one Sensor (number) the name of the Motion Sensor is written down. All others are kinda the same.
Can i just take the Sensor Numbers bevore and after the Named Sensor and hope for the best or is there a way to figgure this out?
EDIT
If someone faces the same Problem.
Just deactivate all Motion Sensor beside 1! Then you can check the Sensor Page of the HUB and you will have “Null” Values at the deactivated Motion Sensor and some Real values on the Active one!
Cheers
