Sharpy
(Aaron Sharp)
1
Hi everyone hoping for a quick tip
how do you extract details from a string item
Blueiris sends its status over MQTT too OpenHAB as a string containing different statuses
signal=1 profile=1 lock=1 schedule=Default
how do use the profile status too turn a few of my switch items on/off
rossko57
(Rossko57)
2
Better to use multiple MQTT channels, each with a transformationPattern to extract the parts that you want.
General idea here -
You’d probably use REGEX though, as your message string is not JSON.
Sharpy
(Aaron Sharp)
3
Thank you yes Seperate items and regex did the trick
