First of all, I’m a complete beginner when it comes to home automation and openHAB. As a result, getting the z-wave binding to work took me a lot of hours with trial, error and an unhealthy blood preasure!
There is a lot of different tips and tricks around, but the one that worked for me at was pretty straight forward.
- follow the Quick Start instructions on https://www.openhab.org/docs/installation/openhabian.html
- when openhabian is up and running, connect to the raspberry pi via ssh. On Mac and Linux, you can use the terminal, on windows, I prefer Putty.
- Username: openhabian, password, openhabian (worked for me at least)
- run “sudo openhabian-config” (the sudo password is openhabian)
- choose system settings, serial port, check all 3 items and choose ok
- open the /boot/cmdline.txt file as sudo with your favourite editor and remove “console=tty1”. In other answers, it said to remove “console=serial0,115200”. If you have something else after “console=”, it shouldn’t matter, just remove it, that’s what I did at least. If in doubt, take a backup of the /boot/cmdline.txt file
- open the /boot/config.txt as sudo and change the line “dtoverlay=pi3-miniuart-bt” to “dtoverlay=pi3-disable-bt”
- reboot by typing “sudo reboot”
If you don’t know how to set up openHAB, this guy will explain you https://www.youtube.com/watch?v=R2T5Mg3RLq0.
The serial port under the port configurator section was /dev/ttyAMA0 on my device.
Good luck and enjoy!
