I made my own widget which is on the overview page and calls other widget.
How I configure variables (items) in the called widget ?
If I read this right, you want to set parameters of one widget from another widget.
I had the same request that was solved. Try this.
Accessing a Custom widget properties from a another Custom widget prop window - Add-ons / UIs - openHAB Community
no, when I click in the icon
I will call other widget :
action: popup
actionModal: widget:Details
which shows values from the items, but don’t know how to configure links in this second widget.
Where to open a widget configuration ?
When you call a widget in this manner, there is an additional property actionModalConfig
which allows you to set the parameter values for the called widget. If your widget has item
and label
parameters: it would look like this:
action: popup
actionModalConfig:
item: MyItemName
label: The Item's Details
Finally I did it other way. I placed a widget on the special page and I call this page
Then no problem configure
