Hi There,
How could I get event update of items (via Openhub2 REST API) when changed their state?
Hi There,
What exactly do you want to achieve?
You could create a rule to react if the item gets updated and use the http binding for GET/POST/PUT etc.
For example: How to send http request? - #3 by Mikey
Hi Benjamin,
Thanks for your reply.
I want to get some response from openhab when its item status changed.
as example:
Currently, I m using a timer event to pull the status of item periodically as follow;
setInterval(function(){
$.get( “http://…/rest/items/zwave_device_eac0108b_node3_sensor_door/state”, function( data ) {
console.log(data);
}, 3000);
But I want to change that to get the response only item’s state changed.
Is there a way to implement that functionality by using subscriber or listener?
Don’t know so much about the server side evens/websockets and such but check out: SSE over REST-API , you might figure out something off that…
