I have seen only one post -Wyze $5 Door/Motion Wireless Sensors
which ended with no solution or a final thought.
I want to check if there is any which way we can integrate wyze sense (not wyze cam) with OH? Or is there any hack to use with OH?
I have bunch of sensors from wyze, but I really do not want to switch to homeassistant for this only reason
I have integration b/w Googlehome and wyze tought if I can use it for creating rules..
No worries.
I just received a bunch more contact sensors as well which I’m going to integrate this weekend.
Note you need to put the sense dongle into a rpi or something, which means you can’t have it plugged into the wyze cam. This means you can’t use the sensors as camera triggers.
I have wondered if I could have one in a wyze camera and another in a pi to allow the best of both worlds, but i’m not sure if a sensor can report to two sense dongles…
Happy to post items etc if needed.
didn’t think like this, nice I might try sometime later.
Also I am curious what are use cases to integrate those many sensors.
Oh boy , I somehow missed this response. It did not work . Its not recognizable sadly. I was trying to go through other posts or blogs in internet. Surprisingly there is none available or I should admit, do not know how to use a search engine ..
