How to messure rate of flow of water?
I´m thinking about to build a watering system for our garden. I would like to have control over the quantity of water which will be used for watering. So I´m looking for a feed water flow meter which I can integrate into openhab if possible using z-wave.
Any ideas?
Thanx for each ideas
Never used it myself but it seems to be sold many different places and is zwave…
Great, thank you!
doesn’t seem to be a European frequency version, unfortunately
Ah, yeah, I didn’t know where you are from. Have you considered a ready made irrigation system?
There are lots of discussions on here about integrating various systems into OH. I have a Hunter system and it isn’t integrated via zone control but I do trigger its rain sensor via arduino so that I can use internet based weather forecasts instead of their foolish rain sensor.
Point is, the hunter system supports typical non-zwave flow meters. Might be exposed via the api… other brands may have similar.
Hey dear. hope you are doing good. I am using a complete series of Paddle Wheel Flow Meters in my plant for water distributions, flow measurement of liquids and for some other measurements . It provides exact accuracy.Give it a try. I am sure it will help you a lot in your desired watering system.
Hi Misa_Amane, thank you, will check where I can get here in Spain.
I guess Omega engineers provide these meters as well. Not sure .
Check https://www.vesternet.com/smart-home/energy-1/water
They have several water meters. zWave, or Wifi (GreenIQ proprietary maybe?). It’s about £60 for the wave one. Valves are expensive though if you’re adding them as well…
