I was wondering how to point OH2 to a different java version. With OH1.x, you could easily point to other binaries from start.sh/bat or within the launch scripts in init.d. How to do this with OH2?
Love to answer my own questions..
Just put alternating java versions wherever you want and fix the path like this:
update-alternatives --install “/usr/bin/java” “java” “/opt/java/hlft/jdk1.8.0_101/bin/java” 1
update-alternatives --install “/usr/bin/javac” “javac” “/opt/java/hlft/jdk1.8.0_101/bin/javac” 1
update-alternatives --install “/usr/bin/javaws” “javaws” “/opt/java/hlft/jdk1.8.0_101/bin/javaws” 1
update-alternatives --install “/usr/bin/jar” “jar” “/opt/java/hlft/jdk1.8.0_101/bin/jar” 1
update-alternatives --set “java” “/opt/java/hlft/jdk1.8.0_101/bin/java”
update-alternatives --set “javac” “/opt/java/hlft/jdk1.8.0_101/bin/javac”
update-alternatives --set “javaws” “/opt/java/hlft/jdk1.8.0_101/bin/javaws”
update-alternatives --set “jar” “/opt/java/hlft/jdk1.8.0_101/bin/jar”
In OH2.1 I recently did the following:
Download java from oracle and extract to /opt.
In my case this was jdk-8u152-linux-arm32-vfp-hflt.tar.gz that went into /opt/jdk1.8.0_152.
$ locate openhab2.service
/usr/lib/systemd/system/openhab2.service
The service definition defines the shell script /usr/share/openhab2/runtime/bin/karaf to start.
This script honors JAVA_HOME variable.
So I added it to the openhab2.service file:
Environment=JAVA_HOME=/opt/jdk1.8.0_152
Now reload configuration of systemd
systemctl daemon-reload
and restart OH2
service openhab2 restart
et voila:
ps wwaux | grep [j]ava openhab 754 71.5 1.3 329840 26968 ? Ssl 12:06 0:04 /opt/jdk1.8.0_152/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 ...
Alternatively you can just define JAVA_HOME in /etc/default/openhab2:
JAVA_HOME=/opt/jdk1.8.0_191
sudo update-alternatives --config java
Alston workshops well-known to the switch between versions.
Note that using update-alternatives will possibly affect other applications and services on the system. So you might end up in a situation where OH2 runs fine but another service does not start anymore.
When running OH2 as a service on Ubuntu servers, JAVA_HOME can be set specifically for OH2 as follows:
sudo systemctl edit openhab2.service
This will open an empty file. Add the following contents:
[Service]
Environment="JAVA_HOME=/usr/lib/jvm/zulu8"
Adjust your JRE/JDK path accordingly and save the file (CTRL + X, Y if nano is your editor). Then reload the services
wait a few seconds and then start or restart OH2:
sudo systemctl start openhab2
This solution is very similar to the one posted by @alex73. However, files in /usr/lib/systemd/system/ should not be modified manually. This location is reserved for vendor-distributed service configurations and should only be modified by package managers like apt.
Instead, user-specific modifications should go to /etc/systemd/system/openhab2.service.d/override.conf. This is where the file automatically ends up when using sudo systemctl edit openhab2.service.
