How to remove Caldav reload job?
I did delete a google calendar which I had configured in the CalDav binding on OH2. But even after removing it from caldavio.cfg I still get
[ERROR] [caldav.internal.job.EventReloaderJob] - error while loading calendar entries: Unexpected response (404 - Not Found)
entries in the openhab.log.
During an OpenHAB restart there is a log entry with
[INFO ] [.io.caldav.internal.CalDavLoaderImpl] - reload job scheduled for: deletedcalendarname
So for some reason the CalDav binding still tries to sync with the deleted calendar.
Even a deinstallation of the binding did not help. After reinstalling it the job is immediately scheduled again.
How do I get rid of the job?
Try to check the stored configs via the Karaf console.
See:
Maybe there are some stale configs in your OH2.
BR,
Dim
Hi Haus 24,
did you find out how to remove the reload job?
I have the same issue and I searched with the karaf console, but I dont know, how to delete these entries…
Maybe you found out how to fix this issue.
Thanks.
I have done this steps to solve this Problem.
  1. Remove the Binding with Paper UI
  2. Connect the console of your openHAB-Server (Uses Linus(ssh) Windows(putty)
  3. Now connect to Karaf Console (Password: habopen)
    #> sudo ssh openhab@localhost -p 8101
  4. Check the calDAV-config
    openhab> config:list “(service.pid=org.openhab.caldavio)”
  5. Delete the calDAV-config
    openhab> config:delete org.openhab.caldavio
    openhab> logout
  6. Install the CalDAV-Binding again.
Best wishes and good luck
