dmit2k
(Dmit)
1
Hi all!
Is it possible to render html elements stored in an item into a < div > element of HABPanel widget?
I have an item which stores html code (actually it is an SVG image), which I want to be rendered in the HABPanel.
For example, the item value is
<b<test</b>
When I use ng-bind-html it does not work as expected:
<div id="wrapper" ng-bind-html="{{ itemValue('Weather_GIS_ConditionIcon') }}"></div>`
results in
<div id="wrapper" ng-bind-html="<b>test</b>"></div>
Any help?
MDAR
2
Does this help you at all?
Or are you thinking of something else?
Could your Item value be used to influence the state of the item in the SVG file?
I have a dimmer item that causes different states in an SVG.
dmit2k
(Dmit)
3
No, I’m not using it as a floorplan. I just have a weather svg icon itself stored in the item and need to make it render in HABPanel.
MDAR
4
Yes, I was thinking that you could insert an SVG file with multiple states, that are determined by the Item.
Rather than load different SVG files.
It’s only an idea.
dmit2k
(Dmit)
5
Problem solved, ng-bind-html must not have values enclosed in {{ }}
Also, according to this post
some HTML values are treated as unsafe by default so must be processed with $sce.trustAsHtml(html)
