I want to exercise push notification from openhab to mobile phone.
Here is what I did so far:
- created a BasicUI with a virtual switch
- installed mqtt binding
- installed mqtt broker (mosquitto) that runs externally to openhab
- added some rules to send an mqtt message, when the switch changes states between off/on.
- installed an mqtt client program (MQTT-Explorer) on my PC
– MQTT-Explorer is external to openhub.
– It subscribes to the topic that openhab sends (e.g. testswitch001 ON, testswitch001 OFF)
– verified that MQTT-Explorer receives the message when I change the switch state between on/off - connected to myopenhab.org in the cloud from a mobile phone:
– in openhab - installed openhab cloud connector
– downloaded the openhab app from Google Play
– connected from a mobile phone to myopenhab.org, via the openhab app
– verified that when e.g. changing the switch between on/off, in BasicUI from the PC, the state changes in the mobile phone as well.
These activities are summarized in here and here.
Now I want to enable notifications such that when changing the switch between on/off, in BasicUI from the PC, I get a notification in the phone.
Here is what I did:
- In the openhab app in the mobile phone, enabled notifications (Settings → Notification)
I see the status Notification registration completed successfully.
I also turned all notification related settings to On: e.g. Show Notifications, Pop on Screen, Override Do Not Disturb) - From myopenhub.org I verified that I can send a message to my mobile phone device (in Device → Send Message), and a notification shows up in my phone as expected.
But when I change the state of the switch I don’t see a notification.
I guess that this is because I need to add some sendNotification command ?
My rule for “change switch on” is:
triggers:
- id: "1"
configuration:
itemName: TestSwitch001
command: ON
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: actions.get("mqtt","mqtt:broker:3186791669").publishMQTT("testswitch001","ON")
type: script.ScriptAction
What command should I add to the rule to send a notification for this event?
Thanks,
Avner
