HOWTO: Integrate doorPi [SIP based Raspberry doorbell] into openHAB
Some time ago, I wanted to have a SIP based doorbell to nicely integrate with my smarthome and while searching, I came across doorPi.
https://www.doorpi.org/forum/
With my below described config, one will be able to turn on the lights on your doorPi based on openHAB Astro Binding, have your Alexa say something like “Doorbell is ringing” and hangup when the door is opened.
Prerequisits
You need to have a up and running doorPi.
Instructions can be found here (German only, sorry)
https://www.doorpi.org/forum/lexicon/entry/1-installation-doorpi-mittels-pypi-auf-einem-raspberry-pi-raspbian/
doorPi.ini - piFace config
[keyboards]
prodsystem = piface
[prodsystem_InputPins]
0 = sleep:0		// doorbell pushbutton
1 = sleep:0		// Lights ON
2 = sleep:0		// Lights OFF
3 = hangup:0	// Receive openHAB command to hangup when door is opened
[prodsystem_OutputPins]
0 = Sound
1 = Lights
Usually, you would use your input pins directly to make a call in doorPi. Defining just a sleep command lets us use the event system to take further action.
The output pins present piFace outputs to switch the relais for the soundcard or the lights.
doorPi.ini - Event config
[EVENT_OnKeyPressed_prodsystem.0]
10 = os_execute:curl --header "Content-Type: text/plain" --request POST --data "ON" http://192.168.0.112:8080/rest/items/doorPiCall
20 = call:**611#622#623
When the doorbell button is pressed, this event is triggered, sending a REST call to a openHAB Switch Item, indicating an active call. The call will be initiated in line two.
[EVENT_OnKeyPressed_prodsystem.1]
10 = out:Lights,1
[EVENT_OnKeyPressed_prodsystem.2]
10 = out:Lights,0
The unused piFace inputs 1 and 2 are used to receive a trigger from openHAB to switch ON/OFF the lights.
[EVENT_OnMediaNotRequired]
10 = out:Sound,0
20 = os_execute:curl --header "Content-Type: text/plain" --request POST --data "OFF" http://192.168.0.112:8080/rest/items/doorPiCall
Switch off the amplifier and send information to openHAB that the door call has ended.
[EVENT_OnMediaRequired]
10 = out:Verstaerker,1
Switch on the amplifier when a call will be initiated.
openHAB Items
Switch doorPiCall "doorPi call active"	<soundvolume>
String Echo_Living_TTS "Text to Speech" {channel="amazonechocontrol:echo:148fa16d:B0F00715603600UB:textToSpeech"}
openHAB Rules
rule "Switch ON doorPi lights"
	Channel 'astro:sun:local:set#event' triggered START
	sendHttpGetRequest("http://user:password@doorPi.local/control/trigger_event?event_name=OnKeyPressed_prodsystem.1&event_source=doorpi.keyboard.from_piface")
rule "Switch OFF doorPi lights"
	Channel 'astro:sun:local:rise#event' triggered START
	sendHttpGetRequest("http://user:password@doorPi.local/control/trigger_event?event_name=OnKeyPressed_prodsystem.2&event_source=doorpi.keyboard.from_piface")
rule "Hangup doorPi call when frontdoor is opened"
    Item ContactFrontDoor changed to OPEN
    if (doorPiCall.state == ON) {
        sendHttpGetRequest("http://user:password@doorpi.local/control/trigger_event?event_name=OnKeyPressed_prodsystem.3&event_source=doorpi.keyboard.from_piface")
rule "doorPi calling"
	Item doorPiCall changed to ON
    Echo_Living_TTS.sendCommand("Doorbell Is Ringing")
What is missing ?
A fancy widget for HABpanel to receive the video stream with integration of a JavaScript SIP client.
Did not forget about it! I will provide in the next few days!
This was not mentioned to push you George.:smiley:
Hello dear,
Can doorPi work with any SIP intercom like 2N, Dahua without needing of SIP server? And it is ok to run doorPi on raspberryPI that hosts openHAB?
No, it can’t as it is using a SIP client for communication, so you need a SIP Server like Asterisk.
I would not recommend to run it on the same PI as openHAB, as you ideally locate it next to your doorbell.
Is there an updated instructions for Doorpi in english ? Would like to try this as it seems really cost effective compared to eg. Doorbird
Hi George,
any news on the SIP intercom widget?
Best
Hans-Jörg
DoorPi is a complete different project, so please ask specific questions on their community.
Hey,
i used the doorPI in a different way. But this here sounds like i will integrate it anyways.
My usage was:
doorPI has “AdminNumbers” so if one of these Numbers call, you can trigger an event.
I did hook up a relais and made a door opener with that.
That would integrate nicely with openhab (to actually have the door opened by openhab as well)
