Hoymiles HM Inverter
Hello
I installed openhab and it runs very well. I would like to display the data from my solar system in Openhab. There is a script for Homeassistant which I tried to build into my system, but it doesn’t really work. Maybe one of you has advice.
Sorry for the english, it was translated with google :smile:
It is probably too late, but have a look at that: GitHub - tbnobody/OpenDTU: Software for ESP32 to talk to Hoymiles/TSUN/Solenso Inverters
It works like a charm ! You just need to build the hardware device (easy to do), flash the firmware and
configure MQTT.
there is also a similar project:
https://github.com/lumapu/ahoy/tree/main/tools/esp8266
@gd35 do you know the differences in this projects? Both have the chip for WLAN and the other chip to receive the hoymiles data.
Bot can forward to MQTT
@timguy I do not know what are differences between these two projects. Both of them came from discussions from the same forum: Wechselrichter Hoymiles HM-xxxx 2,4 GhZ Nordic Protokoll? - Mikrocontroller.net
I saw that (in GitHub - tbnobody/OpenDTU: Software for ESP32 to talk to Hoymiles/TSUN/Solenso Inverters) the Ahoy tool is presented as a related project.
