Hey all, as I could not find anything on the integration of OpenDTU, i did this quick and dirty thing/item config for OH3. The Inverter needs to be powered on with at least one solar panel attached, otherwise it won’t send any data to the DTU. OpenDTU is a free implementation of the DTU-Protocol used for Hoymiles inverters. My config is based on a HM1200, possibly adjustable to other inverters aswell (mine has 4 Inputs, 2 MPPT trackers, similar to the HM1500, but i would recommend the MQTT-Explorer or similar, to figure that out)
Aready discussed in the forum
*.items-file:
Group OpenDTU
Number OpenDTU1_uptime "OpenDTU1 uptime" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:uptime"}
String OpenDTU1_ip "OpenDTU1 IP" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:ip"}
Number OpenDTU1_wifi_rssi "OpenDTU1 WiFi RSSI" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:rssi"}
// Inverters
String OpenDTU1_inv1_name "OpenDTU1 inv1 name" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_name"}
Number OpenDTU1_inv1_pow "OpenDTU1 inv1 power (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_pow"}
Number OpenDTU1_inv1_voltage "OpenDTU1 inv1 voltage (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_voltage"}
Number OpenDTU1_inv1_current "OpenDTU1 inv1 current (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_current"}
Number OpenDTU1_inv1_frequency "OpenDTU1 inv1 frequency (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_frequency"}
Number OpenDTU1_inv1_efficiency "OpenDTU1 inv1 efficiency (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_efficiency"}
Number OpenDTU1_inv1_powerfactor "OpenDTU1 inv1 powerfactor (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_powerfactor"}
Number OpenDTU1_inv1_reactivepower "OpenDTU1 inv1 reactivepower (AC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_reactivepower"}
Number OpenDTU1_inv1_pow_dc "OpenDTU1 inv1 power (DC)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_pow_dc"}
Number OpenDTU1_inv1_temp "OpenDTU1 inv1 temperature" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_temp"}
Number OpenDTU1_inv1_yieldday "OpenDTU1 inv1 yield (day)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_yieldday"}
Number OpenDTU1_inv1_yieldtotal "OpenDTU1 inv1 yield (total)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_yieldtotal"}
// String 1
Number OpenDTU1_inv1_s1_voltage "OpenDTU1 inv1 s1 voltage" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_voltage"}
Number OpenDTU1_inv1_s1_current "OpenDTU1 inv1 s1 current" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_current"}
Number OpenDTU1_inv1_s1_pow "OpenDTU1 inv1 s1 power" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_pow"}
Number OpenDTU1_inv1_s1_yieldday "OpenDTU1 inv1 s1 yield (day)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_yieldday"}
Number OpenDTU1_inv1_s1_yieldtotal "OpenDTU1 inv1 s1 yield (total)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_yieldtotal"}
Number OpenDTU1_inv1_s1_irradiation "OpenDTU1 inv1 s1 irradiation" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s1_irradiation"}
// String 2
Number OpenDTU1_inv1_s2_voltage "OpenDTU1 inv1 s2 voltage" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_voltage"}
Number OpenDTU1_inv1_s2_current "OpenDTU1 inv1 s2 current" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_current"}
Number OpenDTU1_inv1_s2_pow "OpenDTU1 inv1 s2 power" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_pow"}
Number OpenDTU1_inv1_s2_yieldday "OpenDTU1 inv1 s2 yield (day)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_yieldday"}
Number OpenDTU1_inv1_s2_yieldtotal "OpenDTU1 inv1 s2 yield (total)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_yieldtotal"}
Number OpenDTU1_inv1_s2_irradiation "OpenDTU1 inv1 s2 irradiation" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s2_irradiation"}
// String 3
Number OpenDTU1_inv1_s3_voltage "OpenDTU1 inv1 s3 voltage" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_voltage"}
Number OpenDTU1_inv1_s3_current "OpenDTU1 inv1 s3 current" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_current"}
Number OpenDTU1_inv1_s3_pow "OpenDTU1 inv1 s3 power" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_pow"}
Number OpenDTU1_inv1_s3_yieldday "OpenDTU1 inv1 s3 yield (day)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_yieldday"}
Number OpenDTU1_inv1_s3_yieldtotal "OpenDTU1 inv1 s3 yield (total)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_yieldtotal"}
Number OpenDTU1_inv1_s3_irradiation "OpenDTU1 inv1 s3 irradiation" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s3_irradiation"}
// String 4
Number OpenDTU1_inv1_s4_voltage "OpenDTU1 inv1 s4 voltage" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_voltage"}
Number OpenDTU1_inv1_s4_current "OpenDTU1 inv1 s4 current" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_current"}
Number OpenDTU1_inv1_s4_pow "OpenDTU1 inv1 s4 power" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_pow"}
Number OpenDTU1_inv1_s4_yieldday "OpenDTU1 inv1 s4 yield (day)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_yieldday"}
Number OpenDTU1_inv1_s4_yieldtotal "OpenDTU1 inv1 s4 yield (total)" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_yieldtotal"}
Number OpenDTU1_inv1_s4_irradiation "OpenDTU1 inv1 s4 irradiation" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_s4_irradiation"}
// Inverter info
Number OpenDTU1_inv1_bl_version "OpenDTU1 inv1 bootloader version" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_bl_version"}
Number OpenDTU1_inv1_fw_build_version "OpenDTU1 inv1 firmware version" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_fw_build_version"}
DateTime OpenDTU1_inv1_fw_build_datetime "OpenDTU1 inv1 fw build datetime" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_fw_build_datetime"}
Number OpenDTU1_inv1_hw_partnumber "OpenDTU1 inv1 hardware partnumber" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_hw_partnumber"}
Number OpenDTU1_inv1_hw_version "OpenDTU1 inv1 hardware version" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_hw_version"}
// Settings
Number OpenDTU1_inv1_limit "OpenDTU1 inv1 limit" (OpenDTU) {channel="mqtt:topic:default:OpenDTU1:inv1_limit"}
And the things-file:
Bridge mqtt:broker:default "MQTT Local" [host="localhost", secure=false, clientID="OH3_Inbuilt"]
Thing topic OpenDTU1 "OpenDTU-123456" @ "Network" [availabilityTopic="ESP/OpenDTU/dtu/status", payloadAvailable="online", payloadNotAvailable="offline"]
Channels:
// Technical things
Type number : uptime "OpenDTU uptime" [stateTopic="ESP/OpenDTU/dtu/uptime"]
Type string : ip "OpenDTU IP" [stateTopic="ESP/OpenDTU/dtu/ip"]
Type number : rssi "OpenDTU rssi" [stateTopic="ESP/OpenDTU/dtu/rssi"]
// First inverter, serial: <inverter-serial>
Type string : inv1_name "Inverter name" [stateTopic="ESP/OpenDTU/<inverter-serial>/name"]
// Main values
Type number : inv1_pow "Total (AC) power" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/power"]
Type number : inv1_voltage "I1 AC voltage" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/voltage"]
Type number : inv1_current "I1 AC current" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/current"]
Type number : inv1_frequency "I1 AC Frequency" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/frequency"]
Type number : inv1_efficiency "I1 AC efficiency" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/efficiency"]
Type number : inv1_powerfactor "I1 AC powerfactor" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/powerfactor"]
Type number : inv1_reactivepower "I1 AC reactivepower" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/reactivepower"]
Type number : inv1_pow_dc "DC Power (total)" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/powerdc"]
Type number : inv1_temp "Inverter temperature" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/temperature"]
Type number : inv1_yieldday "Yield day" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/yieldday"]
Type number : inv1_yieldtotal "Yield total" [stateTopic="ESP/OpenDTU/<inverter-serial>/0/yieldtotal"]
// Inverter 1 - String 1
Type number : inv1_s1_voltage "I1 S1 voltage" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/voltage"]
Type number : inv1_s1_current "I1 S1 current" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/current"]
Type number : inv1_s1_pow "I1 S1 power" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/power"]
Type number : inv1_s1_yieldday "I1 S1 yield day" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/yieldday"]
Type number : inv1_s1_yieldtotal "I1 S1 yield total" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/yieldtotal"]
Type number : inv1_s1_irradiation "I1 S1 irradiation" [stateTopic="ESP/OpenDTU/<inverter-serial>/1/irradiation"]
// Inverter 1 - String 2
Type number : inv1_s2_voltage "I1 S2 voltage" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/voltage"]
Type number : inv1_s2_current "I1 S2 current" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/current"]
Type number : inv1_s2_pow "I1 S2 power" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/power"]
Type number : inv1_s2_yieldday "I1 S2 yield day" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/yieldday"]
Type number : inv1_s2_yieldtotal "I1 S2 yield total" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/yieldtotal"]
Type number : inv1_s2_irradiation "I1 S2 irradiation" [stateTopic="ESP/OpenDTU/<inverter-serial>/2/irradiation"]
// Inverter 1 - String 3
Type number : inv1_s3_voltage "I1 S3 voltage" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/voltage"]
Type number : inv1_s3_current "I1 S3 current" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/current"]
Type number : inv1_s3_pow "I1 S3 power" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/power"]
Type number : inv1_s3_yieldday "I1 S3 yield day" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/yieldday"]
Type number : inv1_s3_yieldtotal "I1 S3 yield total" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/yieldtotal"]
Type number : inv1_s3_irradiation "I1 S3 irradiation" [stateTopic="ESP/OpenDTU/<inverter-serial>/3/irradiation"]
// Inverter 1 - String 4
Type number : inv1_s4_voltage "I1 S4 voltage" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/voltage"]
Type number : inv1_s4_current "I1 S4 current" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/current"]
Type number : inv1_s4_pow "I1 S4 power" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/power"]
Type number : inv1_s4_yieldday "I1 S4 yield day" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/yieldday"]
Type number : inv1_s4_yieldtotal "I1 S4 yield total" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/yieldtotal"]
Type number : inv1_s4_irradiation "I1 S4 irradiation" [stateTopic="ESP/OpenDTU/<inverter-serial>/4/irradiation"]
// Inverter info
Type number : inv1_bl_version "I1 bootloader version" [stateTopic="ESP/OpenDTU/<inverter-serial>/device/bootloaderversion"]
Type number : inv1_fw_build_version "I1 firmware version" [stateTopic="ESP/OpenDTU/<inverter-serial>/device/fwbuildversion"]
Type datetime : inv1_fw_build_datetime "I1 fw build datetime" [stateTopic="ESP/OpenDTU/<inverter-serial>/device/fwbuilddatetime"]
Type number : inv1_hw_partnumber "I1 hw part number" [stateTopic="ESP/OpenDTU/<inverter-serial>/device/hwpartnumber"]
Type number : inv1_hw_version "I1 hw version" [stateTopic="ESP/OpenDTU/<inverter-serial>/device/hwversion"]
// Settings
Type string : inv1_limit "Inverter limit" [stateTopic="ESP/OpenDTU/<inverter-serial>/settings/limit"]
Feel free to use it ![]()
Best regards,
Dominic
