If you want to do that in a own developed binding you migth look into the Tankerkönig binding. It uses a http request (with an API, which you probably don’t need) to get a JSON string. How much you can use of it depends on the depth you want to integrate the returned data.
You posted two different requests, are there other requests as well? Should all those requests be used by the binding automatically? …
Thanks for reply. I check it out but i try to use JSONpath transformation at first because i never developed a java application before so i need to unserstand the binding construct at first.
My first post belongs to the same solution what i’m looking for.
But one more question:
I want to create 6 items for 6 power sockets. but the last request “/?cmd=511” contains informations for all items. Do you know an example how i can work with this one request to update all item informations?
Regards, Web.
BTW: you can answer in german if you want.
I’m sorry for the misunderstanding, your “i created a example binding” pointed into the development direction.
On your question concerning the data for several sockets in one JSON-string:
You can extract the data for each socket seperatly from the JSON, as an intial try I would use the http binding to do the request and update all items seperatly using the cached reponse.
Sorry, no german answers in this forum, because other shall be able to use the answer as well!
