Hue Emulation Alexa Not Responding after 2.2 Upgrade
The Hue Emulation has been rock solid for me for quite some time. I just recently upgraded to the 2.2 Snapshot build 1072 and am running into a new issue.
When asking Alexa to turn something on or off, she’ll respond that XXX device is not responding.
I looked in the openhab.log file and found the following…any suggestions would be greatly appreciated. This issue seems to be intermittent.
2017-11-05 01:24:39.427 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
java.lang.NumberFormatException: For input string: "All_Off"
	at java.lang.NumberFormatException.forInputString(Unknown Source) ~[?:?]
	at java.lang.Integer.parseInt(Unknown Source) [?:?]
	at java.lang.Integer.<init>(Unknown Source) [?:?]
	at org.openhab.io.hueemulation.internal.HueEmulationServlet.apiState(HueEmulationServlet.java:323) [225:org.openhab.io.hueemulation:2.2.0.201710292329]
	at org.openhab.io.hueemulation.internal.HueEmulationServlet.service(HueEmulationServlet.java:281) [225:org.openhab.io.hueemulation:2.2.0.201710292329]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [30:javax.servlet-api:3.1.0]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.14.v20161028]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:320) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.14.v20161028]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [76:org.eclipse.jetty.io:9.3.14.v20161028]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [76:org.eclipse.jetty.io:9.3.14.v20161028]
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.14.v20161028]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.14.v20161028]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.14.v20161028]
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.14.v20161028]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.14.v20161028]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.14.v20161028]
	at java.lang.Thread.run(Unknown Source) [?:?]
2017-11-05 01:24:39.428 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //10.5.1.50:8080/api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
2017-11-05 01:24:39.533 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
2017-11-05 01:24:39.534 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //10.5.1.50:8080/api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
2017-11-05 01:25:02.366 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
2017-11-05 01:25:02.367 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //10.5.1.50:8080/api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
2017-11-05 01:25:02.482 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/All_Off/state
Well I’m having the same problem. I just upgraded myself to 2.2 and when I start poking around it will usually start to work with no real conclusion and then I give up for a bit and shortly it will quit working again. You were at least able to get some resemblance of an error which gave me an idea to switch the tags on the device from Lighting to Switchable but that didn’t seem to improve the situation either. I believe that as more people start to use 2.2 we will get more information on this. I am going to continue to turn on other logs to see if I can’t find more information.
I just wanted @KidSquid to know - you are not alone! :face_with_raised_eyebrow:
Hey Jayson -
Great to hear that I am not alone!!!
Hopefully when @digitaldan resurfaces he can provide more insight.
Let me know if you uncover anything interesting.
Squid
Following up on the issue you are experiencing with the Hue emulation - it seems to be working ok for me now. The ONLY 3 things that I did..
  1. Login to the console and issue the openhab:install-service command (instead of letting it run in the foreground)
  2. Added debug logging (since turned back off) to the org.openhab.io.hueemulation & org.eclipse.jetty.server.HttpChannel
  3. removed/reset the actual Hue bridge that exists on my network for the zigbee bulbs. Alexa could see both OpenHAB and the Emulation and I suspect that could have caused an issue (even though bulbs were named differently)
It’s been working really well the past week. I don’t know if that saves you anything.
I have updated to Snapshot 1084 and am still experincing the same issue.
I have opened an issue at GitHub…
https://github.com/openhab/openhab2-addons/issues/2858
With the release of 2.2.0 I have the same issue as well: Alexa cannot control any more items shared via the hue emulation service. openhab 2.1.0 worked flawlessly. I hope this gets fixed very soon!
Hi Mario,
I had the same issue yesterday after upgrade to 2.2.0. The only thing I have done is to set the Hue emulation in the pairing mode and on the Alexa skill look for new devices. It is works fine now.
I hope it helps.
Tried that as well, did not work for me…
The frustrating thing is that this issue is intermittent for me. There are times where Alexa will work as intended and then she’ll respond with XXX isn’t responding.
I have not been able to determine a pattern for when it works versus when it fails.
I have reached out to @digitaldan the bindings author to ask for help. It’s my understanding he’s in the middle of moving and most of his gear is still in storage. Hopefully he’ll be able to investigate as soon as his situation settles down.
I’m still on one of the snapshots and have yet to upgrade to the new 2.2 stable.
Squid
Same problem here with 2.2.0. This is really disappointing since 2.1 worked absolutely flawless. :frowning:
@digitaldan Any news on this? Have you found some time to dig into this problem?
Try removing the device list cache file.
Can not remember where it was somewhere in der User Data folder.
I had the same problem. HueEmu changed the json and the unique IDs & keys inside it. You have to delete the old devices in the alexa App wich had the old (wrong) IDs and start discovery again.
If you start the discovery first all your devices should be doubled.
I too have the “device is not responding” feedback from Alexa, now and then, not always. For me it only started a few weeks ago, I’ve been on openhab stable release build 2.2 for quite some time since it was released. When it happens, it keeps on happening when I repeat the question, until maybe few hours later.
Same for me. Restarting amazon echo dot or just waiting some minutes/hours “solves” that problem.
I have been struggling with HUE Emulation and here’s what fixed it.
It finally worked when I asked Echo (the tower size unit) to discover vs. the Echo Dot. This took me over 3+ hours to figure out what I was doing wrong, hggg . . .
Echo = v2 (found 37 devices)
Echo Dot = v2 (didn’t find anything)
Hope this helps someone else.
Best, Jay
Yes, amazon is working with the team and is also taking the assistance of the developers of https://netgears.support/netgear-genie-support to resolve the bugs.
