Has anyone tried this? Does it work? I’ve got, but for some reason having trouble getting temp off it. But if it works it seems a pretty cost effective method of putting sensors in rooms (about $15USD each). They’re also battery operated.
Unless someone else has another similarly priced was of getting temp sensors in multiple rooms. Ive done a couple with raspberry pis, but by the time you buy the board, power supply, sensor, wifi etc you’d be at about 100 each.
Also (likely won’t apply to you) be aware that some iBeacons (don’t know which) cycle their ID quickly for security, which due to a bug can quickly break android Jellybean and kitkat devices’ bluetooth
So…it’s been a while. But blue maestro released a bit more information and an IOS app in the mean time.
The ios app allows you to view the disk and pull all the information. So I played a lot with GATTTOOL to try an and replicate this. Then finally I figured out how to wirteshark a bluetooth capture and I managed to find the data in the advertising data of the disk.
Hi, I’m curious as how did you manage to use python to pull the data from blue maestro. I’ve been playing with it for days, and it just not getting it. Thanks
