Long time ago I used the caldav binding (and even longer i implemented it).
Now i want to use the new icalendar binding but my filtered events are not loaded and (maybe because of this) the cpu load increases a lot.
Without the icalendar binding my cpu load is somewhere at 70%. With the icalendar binding it’s at nearly 130%. The complete oh3 instance is getting very slow. Even when i disable the binding again it stays slow, just after a restart (without icalendar) it’s fast with low cpu usage again.
Yes maybe you are running into an issue with endless recurrences (already fixed, will be released in 3.1, already merged if you want to try a snapshot). Maybe you are not filtering not what you’d expect. Yesterday i wrote a small guide:
Especially the section about filters should be interesting for you.
