iCloud binding, authentication problem
I have an authentication problem with an iCloud account.
After installing the binding everything worked perfectly. Then after restarting OH 4.2.2 there was a warning:
[WARN ] [l.handler.ICloudAccountBridgeHandler] - iCloud authentication failed. Invalid credentials.
Unfortunately, re-entering the user ID and password did not improve the situation. If I log in directly via the browser at https://www.icloud.com/, the login details work perfectly, so they are definitely correct.
Reinstalling the binding did not improve the situation, what else can I do?
Regards
Hans-Jürgen
Same here
perhaps the 2fa code? could be that it needs to be re-entered after a reboot.
The problem is that the iPhone doesn’t even display a 2FA code that you could enter.
I have this exact problem after reboot. Created an issue on GitHub.
Same problem here (originally posted on the 4.3.0M2 thread). This is on openhabian/pi4. I updated to the new milestone and immediately found icloud no longer connects. It will trigger a 2fa prompt that I’ll see on my apple devices and I do get the automated ‘we’ve received a password login from this address, if this was you do nothing’ email note from apple. ie. Apple seems to think there was a valid login. But the icloud account thing never gets updated to ‘Online’ and will end up in status ‘ERROR: CONFIG.’ Log shows invalid 2fa token.
Not sure how to fix, but I’m happy to help test a solution.
Cheers
2024-10-15 06:09:42.255 [WARN ] [l.handler.ICloudAccountBridgeHandler] - iCloud authentication requires 2-FA code. Please provide code configuration for thing ‘icloud:account:872293b897’.
2024-10-15 06:09:42.256 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘icloud:account:872293b897’ changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Please provide 2-FA code in thing configuration.
2024-10-15 06:10:26.757 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘icloud:account:872293b897’ changed from OFFLINE (CONFIGURATION_ERROR): Please provide 2-FA code in thing configuration. to UNKNOWN
2024-10-15 06:14:40.235 [WARN ] [l.handler.ICloudAccountBridgeHandler] - ICloud token invalid.
2024-10-15 06:14:40.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘icloud:account:872293b897’ changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): Invalid 2-FA-code.
Also my trace logs if that’s of any help:
2024-10-19 13:51:23.766 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler initializing ...
2024-10-19 13:51:23.775 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler initialized.
2024-10-19 13:51:23.793 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - Starting iCloud authentication (AuthState=INITIAL, Thing=icloud:account:63f7cfe3c6)...
2024-10-19 13:51:23.797 [DEBUG] [inding.icloud.internal.ICloudService] - Checking session token validity
2024-10-19 13:51:23.802 [DEBUG] [inding.icloud.internal.ICloudSession] - iCloud request POST https://setup.icloud.com/setup/ws/1/validate.
2024-10-19 13:51:23.810 [TRACE] [inding.icloud.internal.ICloudSession] - Calling https://setup.icloud.com/setup/ws/1/validate
Headers -----
java.net.http.HttpHeaders@db4184c6 { {Origin=[https://www.icloud.com], Referer=[https://www.icloud.com/]} }
Body -----
null
2024-10-19 13:51:24.551 [TRACE] [inding.icloud.internal.ICloudSession] - Result https://setup.icloud.com/setup/ws/1/validate 421
Headers -----
java.net.http.HttpHeaders@f86910c7 { {access-control-allow-credentials=[true], access-control-allow-origin=[https://www.icloud.com], access-control-expose-headers=[X-Apple-Request-UUID,Via], cache-control=[no-cache, no-store, private], connection=[keep-alive], content-length=[1403], content-type=[application/json; charset=UTF-8], date=[Sat, 19 Oct 2024 10:51:24 GMT], server=[AppleHttpServer/b866cf47a603], strict-transport-security=[max-age=31536000; includeSubDomains;], via=[xrail:mr42p00ic-qujn09141701.me.com:8301:24R504:grp20,631194250daa17e24277dea86cf30319:8f0ada2b7d17e60a1728f24fa3127b29:deber3], x-apple-edge-response-time=[147], x-apple-request-uuid=[b9781658-24b1-4161-9e9d-f7cb9df5f690], x-apple-user-partition=[60], x-responding-instance=[setupservice:36001001:mr51p60ic-qukt04081502:8001:2426B654:a2ab3064ebcf]} }
Body -----
{"success":false,"requestInfo":[{"country":"NL","timeZone":"GMT+1"}],"configBag":{"urls":{"accountCreateUI":"https://appleid.apple.com/widget/account/?widgetKey=d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d#!create","accountVerifyUI":"https://id.apple.com/identity?widgetKey=d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d","accountLoginUI":"https://idmsa.apple.com/appleauth/auth/signin?widgetKey=d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d","accountLogin":"https://setup.icloud.com/setup/ws/1/accountLogin","accountRepairUI":"https://appleid.apple.com/widget/account/?widgetKey=d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d#!repair","downloadICloudTerms":"https://setup.icloud.com/setup/ws/1/downloadLiteTerms","repairDone":"https://setup.icloud.com/setup/ws/1/repairDone","accountAuthorizeUI":"https://idmsa.apple.com/appleauth/auth/authorize/signin?client_id=d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d","vettingUrlForEmail":"https://id.apple.com/IDMSEmailVetting/vetShareEmail","accountCreate":"https://setup.icloud.com/setup/ws/1/createLiteAccount","getICloudTerms":"https://setup.icloud.com/setup/ws/1/getTerms","vettingUrlForPhone":"https://id.apple.com/IDMSEmailVetting/vetSharePhone"},"accountCreateEnabled":true,"isEnhancedProtectionRegion":false},"error":"Missing X-APPLE-WEBAUTH-TOKEN cookie"}
2024-10-19 13:51:24.557 [DEBUG] [inding.icloud.internal.ICloudService] - Token is not valid. Attemping new login.
org.openhab.binding.icloud.internal.ICloudApiResponseException: Request https://setup.icloud.com/setup/ws/1/validate failed with 421.
	at org.openhab.binding.icloud.internal.ICloudSession.request(ICloudSession.java:148) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudSession.post(ICloudSession.java:98) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudService.validateToken(ICloudService.java:190) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudService.authenticate(ICloudService.java:94) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.checkLogin(ICloudAccountBridgeHandler.java:338) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.callApiWithRetryAndExceptionHandling(ICloudAccountBridgeHandler.java:164) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$2(ICloudAccountBridgeHandler.java:127) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2024-10-19 13:51:24.575 [DEBUG] [inding.icloud.internal.ICloudService] - Authenticating as censored@gmail.com...
2024-10-19 13:51:24.581 [DEBUG] [inding.icloud.internal.ICloudSession] - iCloud request POST https://idmsa.apple.com/appleauth/auth/signin?isRememberMeEnabled=true.
2024-10-19 13:51:24.587 [TRACE] [inding.icloud.internal.ICloudSession] - Calling https://idmsa.apple.com/appleauth/auth/signin?isRememberMeEnabled=true
Headers -----
java.net.http.HttpHeaders@bf3ef8e0 { {Accept=[*/*], Content-Type=[application/json], Origin=[https://www.icloud.com], Referer=[https://www.icloud.com/], X-Apple-OAuth-Client-Id=[d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d], X-Apple-OAuth-Client-Type=[firstPartyAuth], X-Apple-OAuth-Redirect-URI=[https://www.icloud.com], X-Apple-OAuth-Require-Grant-Code=[true], X-Apple-OAuth-Response-Mode=[web_message], X-Apple-OAuth-Response-Type=[code], X-Apple-OAuth-State=[auth-b80ca0e1-6cad-4dcf-9f77-f7e1405b96bf], X-Apple-Widget-Key=[d39ba9916b7251055b22c7f910e2ea796ee65e98b2ddecea8f5dde8d9d1a815d]} }
Body -----
{"password":"censored","accountName":"censored@gmail.com","trustTokens":["HSARMTKNSRVXWFlalyxsgDULFpQsKJ6EMb0EZMimYMVwGthfCbBqFtPVMNSZf1o7loXhq/PobYU1kZ1c11XrjRPeERbJ2zAlsW0MgwmsxpxgaWCQJBZGddsFPKrla/ntlNu+bnw9yRf8Q5ZUzEYtCBaV4GN04+kFJMuM4+zEYMDXwPXvQascqsftN/Tq75BqKU/6twbzWWTo8HF+rdmLEFS21i4xidaHrWujl6OV01X/ARE\u003dSRVT"],"rememberMe":true}
2024-10-19 13:51:25.423 [TRACE] [inding.icloud.internal.ICloudSession] - Result https://idmsa.apple.com/appleauth/auth/signin?isRememberMeEnabled=true 503
Headers -----
java.net.http.HttpHeaders@260031ae { {connection=[keep-alive], content-length=[190], content-type=[text/html], date=[Sat, 19 Oct 2024 10:51:25 GMT], server=[Apple]} }
Body -----
<html>
<head><title>503 Service Temporarily Unavailable</title></head>
<body>
<center><h1>503 Service Temporarily Unavailable</h1></center>
<hr><center>Apple</center>
</body>
</html>
2024-10-19 13:51:25.429 [WARN ] [l.handler.ICloudAccountBridgeHandler] - iCloud authentication failed. Invalid credentials.
same here - today´s restart of OH broke authentication - running on 4.2.2 release build.
Had a restart of Openhab yesterday around lunch time CET (short power outage) no issue seen.
Same here after reboot.
same here
same here
Same here
@maihacke
Could you help at this issue?
This issue is likely due to a change on Apple’s side. Home Assistant and others are having the same issue. It looks like Apple switched to SRP-6a (Secure Remote Password) protocol.
Assuming that’s the cause, presumably something needs to change in the cloud server to work with that protocol, right? If so can someone please file an issue with the cloud server repo with all the details.
Hello Colleagues, did someone have find a workaround about it?
Hello
I updated to openhab 4.2.2 and now the 2fa code is no longer displayed on the cell phone. Is there already a solution or should I reinstall the binding?
thanks for your tips
I had same issue on 20th of october, yesterday I was able to disable thing and enabled again: Bridge came directly up online without asking for a new 2FA.. Today I needed to restart openhab, now bridges are again offline with invalid credentials.
Not sure if it just was an old server or it’s a caching issue in the background? Not sure if this information helps anyone.
Thanks. In that issue someone posted a link to a solution based on pycloud.
So the fix needs to be done in binding too.
My yesterday disable / enable was only a moment of luck.
Have you ever used pycloud?
