iCloud Binding Communication Error
Is anybody else experience issues with the iCloud binding? I’ve been received COMMUNICATION_ERROR since the past few upgrades. I can’t recall if it started at 3.1M3 or before, but the same error has been occurring for a while and continues with the M4 as well as the latest snapshot.
I’m running the latest SNAPSHOT on openHABian with a Rasberry PI 4.
Error Header in UI:
java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
openhab.log w/debug on icloud
2021-05-09 17:55:04.236 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler initializing ...
2021-05-09 17:55:04.236 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge starting handler ...
2021-05-09 17:55:04.237 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge refreshing data ...
2021-05-09 17:55:04.237 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler started.
2021-05-09 17:55:04.238 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge initialized.
2021-05-09 17:55:04.412 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
	at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:260) ~[?:?]
	at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:155) ~[?:?]
	at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:130) ~[?:?]
	at org.openhab.core.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:90) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:71) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:94) ~[?:?]
	at org.openhab.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) ~[?:?]
	at org.openhab.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:161) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Caused by: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
	at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:730) ~[bundleFile:9.4.38.v20210224]
	at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:251) ~[?:?]
	... 15 more
Caused by: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
	at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:163) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:365) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.http.HttpParser.handleContentMessage(HttpParser.java:591) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1716) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1545) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:204) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:144) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:383) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) ~[bundleFile:9.4.38.v20210224]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) ~[bundleFile:9.4.38.v20210224]
	... 1 more
Same to me.
since this night, the account thing will not come ONLINE.
Error:
COMMUNICATION_ERROR
iCloud response invalid: null
I’m using OH 3.1 M3
Got the same since last night as @RalphSester
Same here since today. I’m using OH 2.5.12 on docker.
So it seems to be a general issue caused by a change on Apple side.
The same build as joergos and the same situation here.
Same here. My iCloud account stopped working at 10pm last night and my wifes iCloud stopped working at about 1am this morning.
I wasn’t even home, so it wasn’t me that broke it :slight_smile:
Status:
OFFLINE
**COMMUNICATION_ERROR**
same issue here
same here
SAME thing
same here … no clue why it happend
Well, I’m glad it’s not just me. I’ve been having this issue for weeks now.
Same here. Running on pi3 with openhab 3.0.2. Any news about it? Thanks
Same problem for me since yesterday. Running 3.0.2 on Raspi 4.
Think I´ll switch to GPSTracker instead…
Same here with M4 running on both a Mac and a rpi 4, just since last night
Might as well chime in with another, Same Here.
Both iCloud accounts I’ve set up are seemingly broke.
OH 3.1.0M4 running on CentOS8.
same here with 3.0.2 on docker. Any ideas?
Same here OH 2.5.12
+1 :worried:
Maybe this helps a little bit: I get two different errors trying to log in:
Error when using wrong password (app specific password on apple site):
“java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header”
Error when using correct apple password:
“iCloud response invalid: null”
Same here, 3.0.1 release build, macOS, since midnight May.12.
