iCloud Binding Communication Error
Since OwnTracks doesn’t appear to be a reliable solution for iPhone users (I could never get it to update my location in the background and others seem to be in the same boat) and the iCloud binding appears for the time being at least to have been broken for us by Apple, I am switching approach. I had virtual presence devices which I was controlling using rules based on phone location from iCloud binding. Now I have published those virtual presence devices (switches) to HomeKit and using automations in HomeKit to switch them on and off based on people arriving and leaving home. Looks like Home app lets you set those up for other locations too.
Same error OPENHAB 3 platform.
java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
I have the same problem. A pity! Hopefully someone will figure out a solution
Yes, I have two iCloud accounts and both stopped working on Wednesday 12th May. Seeing the same error others have reported.
COMMUNICATION_ERROR
iCloud response invalid: null
Just opened Issue on github.
I’m going to give this a try - it sounds like it might work well. Do you know at what distance Homekit decides people are home or away and how often it poles?
I can confirm this - that’s my experience as well.
And actually I used a similar approach for presence like you (without homekit), which works well even though iCloud is not working:
Whenever one of our three phones are detected in the wifi (using Fritzbox TR064), the location will be set artificially to the home GPS location for presence ON.
If the phone hasn’t been seen for a while (or location changed to be out of the home zone - which is of course currently not working), the presence for this phone goes off.
That’s ok (temporary) - even without homekit.
Depending on the time frame for a fix, I might consider homekit though.
You should probably run all 3 checks - Homekit Location automation, iCloud location and checking wifi. Depending on your application you could use first past post or 2 of 3 to detect presence. In my experience, HomeKit automation is quick to detect arrival, slower to detect leaving. Occasionally, HomeKit drops and I don’t realise until I reset everything. iCloud location is good but lags. Wifi is good but status flaps a lot i.e. poor wifi in a room can mean presence is off.
Mine stopped as well. Jumping in hoping for a solution…
Bump
iCloud Account
iCloud Account
The account Thing, more precisely the account Bridge, represents one Apple iCloud account. You may create multiple account Things for multiple accounts.
Status: OFFLINE - COMMUNICATION_ERROR iCloud response invalid: null
i provided a version with a fix for the communication error.
Please test the fix and give a feedback, thanks.
“<= 3.1.0 M3” → (removed)
“>= 3.1.0 M4” → (removed)
“<= 2.5.?” → (removed)
br,
Trinitus01
The fix works for me OH 3.0.2.
Great work
Thanks for the fix.
Worked for me too.
OH 3.1 M4
I can’t get the fix working. I’m on OH 3.1.M4 running on a Mac. It appeared to work at first, when I added the iCloud bridge thing it initialised and then showed as online for a few minutes, then a bunch of my devices turned up in the inbox so I added one of them. Then that device couldn’t initialise and I noticed the bridge had gone offline, with a new error message:
Status:
OFFLINE
**COMMUNICATION_ERROR**
iCloud response invalid: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
I’ve not installed a snapshot of a binding before so not 100% sure I did it right. I uninstalled the iCloud binding, shut down OH, then copied the 3.1.x jar from the link above into the add-ons folder, then restarted OH and then finally when through the normal route to add the iCloud binding again from the bindings menu in Main UI. Is that how you’re meant to do it?
you added the iCloud binding again from the bindings menu in additional to the jar in the add-ons folder, right?
It is not possible to use a binding installed via ui and the same one in the add-ons folder parallel. So you should uninstall the one installed by ui.
After the fix is merged to openHAB and they release the new version 3.1.x you can install it via ui again. But for now, you can only use the jar in the add-ons folder to fix the problem.
br,
Trinitus01
Fantastic! Thanks a lot!
Works with 3.0.2 again.
Aha, thank you. Got it working now.
thanks for the fix.
The 3.1 binding does NOT work in my 3.1.M3
The 3.0 binding does WORK in my 3.1.M3
it’s a kind of magic ?
ralph
Spoke too soon. Again it worked briefly then the bridge device went offline again, this time with new error:
2021-05-17 20:11:51.551 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
	at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:260) ~[?:?]
	at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:155) ~[?:?]
	at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:130) ~[?:?]
	at org.openhab.core.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:90) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:71) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:94) ~[?:?]
	at org.openhab.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) [bundleFile:?]
	at org.openhab.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) [bundleFile:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:161) [bundleFile:?]
	at org.openhab.binding.icloud.internal.handler.ICloudDeviceHandler.refreshData(ICloudDeviceHandler.java:112) [bundleFile:?]
	at org.openhab.binding.icloud.internal.handler.ICloudDeviceHandler.initialize(ICloudDeviceHandler.java:103) [bundleFile:?]
	at jdk.internal.reflect.GeneratedMethodAccessor57.invoke(Unknown Source) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
	at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
	at org.eclipse.jetty.client.TimeoutCompleteListener.onTimeoutExpired(TimeoutCompleteListener.java:51) ~[?:?]
	at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:282) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
	... 3 more
==> /Users/Server/openhab-3/userdata/logs/events.log <==
2021-05-17 20:11:51.561 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:account:d926c10baf' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 15000 ms elapsed
that’s strange yes.
I was not able to test the 3.1.x because i don’t have an openHAB on this version.
But the fix is the same and both bindings are based on the current git-version.
This is why i ask for feedback.
br,
Trinitus01
