@proyleg Can you confirm which version you used for OH3.0.2
3.1.0M3
3.1.0M4
or
2.5.
Please can someone upload the new jar files with this fix? I am on 2.5.9.
Hey Peter, the files have been uploaded 6 Days ago. Have a look few posts above…
The files all have old time stamps. I don’t think the new snapshots with the fix is there for any 2.5.x versions
Hello Together,
did someone are facing issues like below?
COMMUNICATION_ERROR
Reported offline by iCloud webservice
I could not find v2.5.x corrected binding, so i patched it myself based on the change i found on github. App version 2.0 to 3.0, added 2 lines to code with product type, then i compiled it with Maven. Im running OH v2.5.12, iCloud is working now with this binding. I have checked and the binding version v.2.5.13 did not have any change since v2.5.9, so this can be considered the latest, unfortunately i dont know how to change the version in the code. Hope this helps others.
If you want to do it then look under: src/main/feature.xml
Will list the binding name, description and version.
Does anyone have 2.5.12 patched yet? The latest jar file is from January on this link:
https://openhab.jfrog.io/ui/native/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.icloud
I’ve just faced a similar issue.
Status:OFFLINE
COMMUNICATION_ERROR
iCloud response invalid: null
it seems apple returned a a kb entry that describes which devices can use the Icloud service.
Anyone face the same issues?
/Franz
2021-11-16 08:52:47.083 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:device:00fcbbb629:db367a24' changed from INITIALIZING to UNINITIALIZED
2021-11-16 08:52:47.116 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:device:00fcbbb629:db367a24' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-11-16 08:52:47.120 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:account:00fcbbb629' changed from OFFLINE (COMMUNICATION_ERROR): iCloud response invalid: null to UNINITIALIZED
2021-11-16 08:52:47.208 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:account:00fcbbb629' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-11-16 08:52:47.211 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:device:00fcbbb629:db367a24' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2021-11-16 08:52:50.963 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:account:00fcbbb629' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-11-16 08:52:50.982 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler initializing ...
2021-11-16 08:52:50.984 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge starting handler ...
2021-11-16 08:52:50.989 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge refreshing data ...
2021-11-16 08:52:50.994 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge handler started.
2021-11-16 08:52:50.996 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge initialized.
2021-11-16 08:52:51.317 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:account:00fcbbb629' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): iCloud response invalid: null
2021-11-16 08:52:51.327 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'icloud:device:00fcbbb629:db367a24' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-11-16 08:52:51.307 [TRACE] [l.handler.ICloudAccountBridgeHandler] - json: {"url":"https://support.apple.com/en-us/HT204230"}
2021-11-16 08:52:51.336 [DEBUG] [internal.handler.ICloudDeviceHandler] - initializeThing thing [icloud:device:00fcbbb629:db367a24]; bridge status: [OFFLINE]
2021-11-16 08:52:51.340 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge refreshing data ...
2021-11-16 08:52:51.344 [TRACE] [l.handler.ICloudAccountBridgeHandler] - json: {"url":"https://support.apple.com/en-us/HT204230"}
2021-11-16 08:57:51.317 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge refreshing data ...
2021-11-16 08:57:51.664 [TRACE] [l.handler.ICloudAccountBridgeHandler] - json: {"url":"https://support.apple.com/en-us/HT204230"}
2021-11-16 09:02:51.668 [DEBUG] [l.handler.ICloudAccountBridgeHandler] - iCloud bridge refreshing data ...
2021-11-16 09:02:51.969 [TRACE] [l.handler.ICloudAccountBridgeHandler] - json: {"url":"https://support.apple.com/en-us/HT204230"}
Yes, the binding also stopped for me this night
Thanks a lot @rkrisi for your feedback!
This makes me feel better because I already thought I’m the only one
Me too…
I had a quick look and it returns the same for me, which I don’t know why, but I can clearly see that the certificate of the API used by this binding is incorrect (though not expired). I think this is the root cause of the issue (as it happened before multiple times).
The binding also stopped working for me. The last update was just before 3am.
I have the same problem since today …
Same problem here since this morning
Same here, please let‘s know of there is a Solution
Same here ![]()
Same here ![]()
i think, it’s general problem…like the ssl-problems in the past
@hmerk : Do you know something about it?
Sorry, no clue. I am not at home atm, so cannot check my logs. Will check tomorrow…
