i have updated to the unstable version of openhab and the binding is now working.
Thank you! Where do I find the newest Version/SNAPSHOT? Can I somehow create it myself from the repository: https://github.com/openhab/openhab2-addons/tree/master/addons/binding
Sorry if this goes to far off topicā¦
@martinvw managed to build the jar:
jar cvf org.openhab.binding.icloud.jar org.openhab.binding
chmod +x org.openhab.binding.icloud.org.jar
Deposited the file in the addons folder and restarted openHAB (a couple of times). Unfortunately the binding doesnāt seem to start.
It should work but you can maybe better try a real release jar: https://openhab.jfrog.io/openhab/libs-snapshot/org/openhab/binding/org.openhab.binding.icloud/2.4.0-SNAPSHOT/
Make sure to uninstall the binding first through paperUI and then dropping in the jar. Look at the log to see what is going on.
Great, thank you:
257 ā Active ā 80 ā 2.4.0.201811241129 ā iCloud Binding
Unfortunately in Paper UI all devices show as INITIALIZING or UNINITIALIZED. Restarted openHAB and cleaned cache/tmp, no change. What am I missing?
I would propose to check the logs and maybe there is also a status string next to INITIALIZING or UNINITIALIZED.
Otherwise you should enable logging and make sure to either enable / disable or store a real change.
Enable logging:
log:set DEBUG org.openhab.binding.icloud
Hi Marin,
I just installed the binding, but I get the following error message that I can see in the logs. Do you have any idea what that could be? I installed the latest openhabian image.
2018-12-14 16:43:23.947 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/net/http/HttpRequestBuilder
at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:70) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:65) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:84) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:81) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:61) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:141) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.net.http.HttpRequestBuilder cannot be found by org.openhab.binding.icloud_2.4.0.201812100737
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
... 13 more
Best wishes,
Ben
Hi who can help me pleaseā¦ moved from windows to ubuntu, on windows i was able to use the GUI
here i am kind of lostā¦
csplit -f cert /tmp/icloud2.crt ā/^-----BEGIN CERTIFICATE-----/ā {*}
1.do i need to put my certficate here?
2. where do i take it?
Hello!
After this binding stopped working (OH 2.3) I stopped using it but now with my fresh 2.4 installation i wanted to give it another go.
Is there still a certificate problem?
PaperUI finds my devices instantly but after adding them (with a things-file) every device is marked as offline (communication error).
Do i have to follow the steps above to get it working or is there a different problem?
Thank you
Hi!
I did some more work investigating my problems ā¦
I cant get the textual configuration to work ā¦ my account shows online and my devices are discovered in paper UI.
when i copy the device-id provided in paperui into my things-file it wonāt work.
if i add them via paperui a different channel number is created which i can link my items to ā¦
why does the textual configuration not work?
for backup reasons i like to use textual configuration a lot ā¦
Sorry for the late reply.
After setting:
All Iām getting is:
2018-12-20 10:41:36.448 [hingStatusInfoChangedEvent] - 'icloud:XXX' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
No more entries concerning the binding. When I remember correctly I had no Handler Error beforeā¦ strange.
It works now. just took some time.
No more SSH issues?
Binding is still not working. But I havenāt fiddled with it for some time. Still running openHAB 2.3, so maybe the update will fix my problems.
my entire migration depends on that
i switched all my stuff to Ubuntu VM, but i was not able to make icloud to work so i am still on my windows
if anyone knows how to make it work with Ubuntu 16.04
i will be really grateful ā¦
Just upgraded to openHAB 2.4 (running on a Diskstation) and installed the iCloud binding: finally everything works fine!
for me on 2.4 the bridge is getting disconnected, but i am able to do "find my iphone "so i am cool with that
Iāve been having very similar issues the past couple of days, intermittant and fixed by a reboot, but itās been working perfectly for a good few weeks / month or so nowā¦
2019-05-30 07:49:57.063 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
Iām still on 2.4 on a RaspPi.
Anyone else having the same issues, any ideas?
I also get an error when the iCloud things stop updating. I am on Pi3 with Openhabian OH 2.4.
It worked for months on OH2.3 and now on 2.4 it seemed stable but has stopped working this week.
When I uninstall the Binding and re-install it updates with locations and battery charge from all my devices but then stops. It may only update once.
I see Apple are combining the āFind Friendsā and āFind my iPhoneā apps into one new app in iOS 13 (in beta testing now) so could there be changes needed to the OH Binding?
Hi I have this problem with 2.5M1 ā¦ and I think since today. Anybody else?
