iCloud SSL issue again
I have the same problem as ramon2k10 and a restart of openhab2 did not resolve the problem.
Anybody with ideas?
I followed Pali’s install method and my console shows this.
231 │ Active    │  80 │ 2.4.0                  │ Rfxcom Binding
233 │ Active    │  80 │ 1.13.0                 │ openHAB Expire Binding
234 │ Active    │  80 │ 2.4.0                  │ VoiceRSS Text-to-Speech
235 │ Active    │  80 │ 1.13.0                 │ openHAB Lgtv Binding
236 │ Active    │  80 │ 2.4.0                  │ LogReader Binding
237 │ Active    │  80 │ 2.4.0                  │ Samsung Tv Binding
238 │ Active    │  80 │ 2.4.0                  │ Exec Binding
243 │ Active    │  80 │ 1.0.6                  │ Californium (Cf) OSGi Bundle
244 │ Active    │  80 │ 1.0.6                  │ element-connector
245 │ Active    │  80 │ 1.0.6                  │ Scandium (Sc) Core
246 │ Active    │  80 │ 0.10.0.oh240           │ Eclipse SmartHome TRÅDFRI Binding
247 │ Installed │  80 │ 2.5.0.M2               │ openHAB Add-ons :: Bundles :: iCloud Binding
openhab> bundle:start 247
Error executing command: Error executing command on bundles:
	Error starting bundle 247: Could not resolve module: org.openhab.binding.icloud [247]
  Unresolved requirement: Import-Package: com.google.gson; version="[2.8.0,3.0.0)"
M2 version of iCloud binding need gson library, so if you don’t currently use any binding which have already installed it, you need to install it manually. Normally dependencies are automatically solved, but installing jar files manually, dependencies need to be installed manually as well.
bundle:install http://central.maven.org/maven2/com/google/code/gson/gson/2.8.5/gson-2.8.5.jar
You are the man-thanks a lot. All is working now:-) I was running a standard openhabian setup with no gson library required and had no idea.
Thanks again:-)
I upgraded my full openHAB install, not just iCloud binding, to 2.5.0M2 release and no longer getting SSL error but getting errors below. Guessing this is a code issue because a quick google search found posts to stack overflow about large http requests using jetty require extra steps to allocate a larger buffer for post requests. Curious if anyone else is having this error with the recent builds. Prior to SSL issue and subsequent troubleshooting I had not seen this error.
2019-08-10 09:30:42.697 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.ExecutionException: org.eclipse.jetty.http.BadMessageException: 500: Request header too large
	at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
	at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
	at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
	at org.eclipse.smarthome.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:88) ~[?:?]
	at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:69) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:88) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:97) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:68) ~[?:?]
	at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:145) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.util.concurrent.ExecutionException: org.eclipse.jetty.http.BadMessageException: 500: Request header too large
	at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
	at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
	at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:683) ~[?:?]
	at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:250) ~[?:?]
	... 16 more
Caused by: org.eclipse.jetty.http.BadMessageException: 500: Request header too large
	at org.eclipse.jetty.http.HttpGenerator.generateRequest(HttpGenerator.java:279) ~[?:?]
	at org.eclipse.jetty.client.http.HttpSenderOverHTTP$HeadersCallback.process(HttpSenderOverHTTP.java:231) ~[?:?]
	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[?:?]
	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[?:?]
	at org.eclipse.jetty.client.http.HttpSenderOverHTTP.sendHeaders(HttpSenderOverHTTP.java:62) ~[?:?]
	at org.eclipse.jetty.client.HttpSender.send(HttpSender.java:214) ~[?:?]
	at org.eclipse.jetty.client.http.HttpChannelOverHTTP.send(HttpChannelOverHTTP.java:85) ~[?:?]
	at org.eclipse.jetty.client.HttpChannel.send(HttpChannel.java:128) ~[?:?]
	at org.eclipse.jetty.client.HttpConnection.send(HttpConnection.java:201) ~[?:?]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP$Delegate.send(HttpConnectionOverHTTP.java:255) ~[?:?]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.send(HttpConnectionOverHTTP.java:122) ~[?:?]
	at org.eclipse.jetty.client.http.HttpDestinationOverHTTP.send(HttpDestinationOverHTTP.java:38) ~[?:?]
	at org.eclipse.jetty.client.HttpDestination.process(HttpDestination.java:346) ~[?:?]
	at org.eclipse.jetty.client.HttpDestination.process(HttpDestination.java:304) ~[?:?]
	at org.eclipse.jetty.client.HttpDestination.send(HttpDestination.java:294) ~[?:?]
	at org.eclipse.jetty.client.HttpDestination.succeeded(HttpDestination.java:228) ~[?:?]
	at org.eclipse.jetty.client.AbstractConnectionPool.proceed(AbstractConnectionPool.java:153) ~[?:?]
	at org.eclipse.jetty.client.AbstractConnectionPool$1.succeeded(AbstractConnectionPool.java:131) ~[?:?]
	at org.eclipse.jetty.client.AbstractConnectionPool$1.succeeded(AbstractConnectionPool.java:123) ~[?:?]
	at org.eclipse.jetty.util.Promise$Wrapper.succeeded(Promise.java:130) ~[?:?]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onOpen(HttpConnectionOverHTTP.java:130) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection.onOpen(SslConnection.java:283) ~[?:?]
	at org.eclipse.jetty.io.SelectorManager.connectionOpened(SelectorManager.java:324) ~[?:?]
	at org.eclipse.jetty.io.ManagedSelector.createEndPoint(ManagedSelector.java:268) ~[?:?]
	at org.eclipse.jetty.io.ManagedSelector.access$1900(ManagedSelector.java:61) ~[?:?]
	at org.eclipse.jetty.io.ManagedSelector$CreateEndPoint.run(ManagedSelector.java:922) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) ~[?:?]
	... 1 more
Caused by: java.nio.BufferOverflowException
	at java.nio.Buffer.nextPutIndex(Buffer.java:521) ~[?:?]
	at java.nio.HeapByteBuffer.put(HeapByteBuffer.java:169) ~[?:?]
	at org.eclipse.jetty.http.HttpGenerator.putSanitisedValue(HttpGenerator.java:932) ~[?:?]
	at org.eclipse.jetty.http.HttpGenerator.putTo(HttpGenerator.java:948) ~[?:?]
	at org.eclipse.jetty.http.HttpGenerator.generateHeaders(HttpGenerator.java:702) ~[?:?]
	at org.eclipse.jetty.http.HttpGenerator.generateRequest(HttpGenerator.java:250) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) ~[:?]
	... 1 more
Solved, uninstalling and re-installing the 2.8.5
Now I’m getting iCloud info. Congrats!!!
Thanks!!!
Nevermind nothing rebooting and clearing openhab cache several times didn’t eventually fix.
Hi!
mine stopped working as well.
can you tell me how to upgrade to the latest snapshot on a mac? apt update etc won’t work obviously :wink:
You mean whole openHAB or just iCloud binding? If just iCloud binding, same instructions work on Mac as well (see earlier posts)
Ok i just copy pasted the latest milestone data and it worked. Icloud is working again.
Thanks, I followed these instructions and iCloud seems to be working fine again.
Thank you everyone! I’m behind the curve again but I-Cloud is up and running!
My Telegesis Zigbee controller is Online but none of the devices work after the iCloud update…anyone else?
My Zigbee and Z-wave have been working great with 2.4 Stable
RPi 3b+ / Openhabian system.
Booting external SSD 120GB Hard drive.
Ok I restored from backup to 2.4 stable release and Zigbee works again! ICloud not.
My question is how does the iCloud 2.5 M2 binding or gson-2.8.5 update infect Zigbee?
Any ideas?
Mike
You don’t need to update OpenHAB to 2.5 to have the latest Version of iCloud Binding to work properly. Just install the latest version of the iCloud Binding to your 2.4 installation.
Thank’s f lot for your work : this solves perfectly my issue !
Great Job ! :smile:
  • Chic
I thought that’s what I did…I followed these instructions. Sorry I’m confused! Openhab is running version 2.4 Stable with iCloud binding 2.5.0.M2.
bundle:install https://openhab.jfrog.io/openhab/online-repo-milestone/2.5/org/openhab/addons/bundles/org.openhab.binding.icloud/2.5.0.M2/org.openhab.binding.icloud-2.5.0.M2.jar
Mike
Sorry to ask - but you did uninstall the 2.4 binding first?
with kind regards,
Patrik
Hi Patrik,
Yes sir! I uninstalled the 2.4 iCloud binding from paper UI and checked to the console to see that the bundle was not present before making the changes. Happy I backed up before trying to “fix” things! :slight_smile:
Seriously I’m mot casting any blame here just looking for the connection between the 2.5 M2 iCloud binding and Zigbee?
Mike
For anyone that is still having the same issue, check bundle:list to make sure you don’t have an older version of Gson installed.
The snapshot version of the icloud binding is looking for a version > 2.8.0
I had Gson 2.7.0 installed, after bundle:uninstall this package, icloud came online.
Whats the full command to uninstall the 2.7.0 Gson version?
Paul
