Icon Set with Theme
As discussed in this topic:
I felt like the icons in my UI have become disjointed over the years with classic icons and different sets from iconify. While I’ve never placed a high value on icon presentation, it did seem like an opportunity for some uniformity. While unlikely to be accepted at iconify given the strict guidelines, they have been submitted anyway. I will report back with prefix if accepted. As always they can be placed in your icons/classic folder.
Many icons use the same name as the classic icon set, but with a ‘26’ prefix. Others are my personal additions, also with a ‘26’. The icons are direct inspiration from the classic icon, an interpretation from the classic, or something new. There are also the usual dynamic icons. Claude started drifting toward a brass steampunk theme, so I just went with it. Some samples:
Switch:26switch26switch-off26switch-on
Light:26light26light-off26light-on
Dimmer:26light26light-off26dimmer-126light-on
Slider:26light26slider-026slider-1026slider-2026slider-3026dimmer-126slider-5026slider-6026slider-7026slider-8026slider-9026slider-100
Battery:26battery26battery-026battery-1026battery-2026battery-3026battery-4026battery-5026battery-6026battery-7026battery-8026battery-9026battery-100
Climatemode:26climate_mode26climatemode-auto26climatemode-cool26climatemode-dry26climatemode-fan_only26climatemode-heat26climatemode-off
Temperature:26temperature26temperature-cold26temperature-hot
Screen:26screen26screen-off26screen-on
Outlets:26poweroutlet_us26poweroutlet_eu26poweroutlet_uk
Door:26door26door-closed26door-open
Rollershutter:26rollershutter-026rollershutter-1026rollershutter-2026rollershutter-3026rollershutter-5026rollershutter-6026rollershutter-7026rollershutter-7026rollershutter-8026rollershutter-9026rollershutter-100
Soundvolume:26soundvolume26soundvolume-026soundvolume-3326soundvolume26soundvolume-100
Soundvolume_mute:26soundvolume_mute26soundvolume-10026soundvolume_mute-on
Humidity:26humidity26humidity-026humidity-1026humidity-2026humidity-3026humidity-4026humidity26humidity-6026humidity-7026humidity-8026humidity-9026humidity-100
Colorpicker:26colorpicker
Bedroom:26bedroom26bedroom_blue26bedroom_orange26bedroom_red
Laundry:26washingmachine26dryer
CMYK Ink:26ink26ink_c26ink_m26ink_y26ink_k
Fans:26fan26fan_ceiling
Window:26window26window-ajar26window-open26window-closed
Floors:26cellar26groundfloor26firstfloor26attic26garage
Sun:26sun26sun_clouds26sunrise26sunset
Water:26water
Misc:26bath26camera26decoraswitch26gate26motion_126office26printer26solarplant
Plus more that fit in the theme. I’ll be adding more as needed, and if you like the theme and need an additional icon, let me know.
